Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-28-2018, 05:16 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
LED Doesnt Work Incandescent Does
Anyone else have any experience with an LED light bulb not working and a incandescent bulb working in the same socket?
I have a AAW courtesy light kit I installed recently that works fine if I use a regular bulb but not if I use a recently purchased LED bulb.
Old 05-29-2018, 01:31 AM   #2
The Rocknrod
Moderator
Re: LED Doesnt Work Incandescent Does
Yes I checked, shown here.
Old 05-30-2018, 11:35 PM   #3
phat69
Install the bulb and see if the base shows +12v with a tester. The shoulder on the base may be interfering with the socket and not allowing contact at the bottom.
phat69 is offline   Reply With Quote
Old 06-01-2018, 01:14 PM   #4
Dead Parrot
Double check that the polarity of the wiring you are connecting your kit to matches what the kit wants. Possible a PO made some modifications.
Are the LED bulbs even polarity sensitive? Some are some aren't. Don't want to be chasing a polarity problem if the bulbs don't care.
Could be the circuit you are getting power from wants a certain current draw to go active. The old style turn signal blinker for example. Don't know why a courtesy light circuit would care but stranger things have happened.
Dead Parrot is offline   Reply With Quote
Old 06-01-2018, 01:34 PM   #5
The Rocknrod
Moderator
Polarity of the wiring is good.
I plugged in an incandescent it works.
See post #3 again, thats the LED bulb, the Incandescent was done the same way. It works both in the plug and on the bench the same as the LED bulb.
I tried 3 LED bulbs (from the same seller though).
Old 06-01-2018, 02:34 PM   #6
DLW
Only thing I can really think of is if for some reason the the nubs on the side of LED are not contacting the ground wire after twisting them in. Is the side nubs shorter or anything different? You could try to just use a test wire from bulb body to ground while in the socket to see. I would just start troubleshooting like that, do the same for power if ground is ok.
DLW is offline   Reply With Quote
Old 06-03-2018, 12:18 AM   #7
Robznob11
Robznob11's Avatar
Just checking....you do know that a regular bulb will light up either way the wires are hooked. (Not polarity sensitive) just because it lights with the wires the same direction as the led ....does not mean the polarity is correct. The quickest and easiest test is to reverse the wires on the socket. If that does not work check it is making good connection on the ground. Only other thing to check is if you have a true 12+volts. A regular bulb will light with very little current , many leds will not. They are built for a specific voltage/current flow.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-08-2018, 12:53 PM   #8
The Rocknrod
Moderator
The same voltage shown in post #3 is used on the sockets in the truck, thats an LED being lit in post #3 with the same power used on the truck to light an incandescent. Also I bumped up the amps on the truck just to make sure.
I checked polarity from the socket + and - to the fuse/ground panel. It's dead on, ground to ground, power to power, not switched there. I'm stumped. All I can think of is the little tabs arent making contact well enough in the American Autowire socket on the LED bulbs from China. Not that you can even buy them made in America so thats a mute argument.
Old 06-08-2018, 03:50 PM   #9
DLW
As I said in my other post, there is only power and ground, it's not getting one of them while plugged into the socket it seems. You can simply take a separate wire and run it from a good ground, to the bulb body (while LED is in the socket) to test the tab being to short or mis-aligned to contact the white wire tab theory. If it lights up its the ground issue. I just got a similar setup from Ron Francis the other day, doubt I use LED's, but I think I have a couple I can try out.
Old 06-08-2018, 03:52 PM   #10
Robznob11
Robznob11's Avatar
You say you bumped the amps up on the truck???? Is the battery dead? Are you testing with a dead battery and charger on it? The only reason I ask is because I had a fellow say his led tails would not light. Come to find out his battery was low so he attempted to check them in the truck and use a battery charger for a little boost. The problem is there is a significant voltage drop in the wiring...especially if it is stock. Leds are also voltage sensitive too. Meaning they need close to full voltage to light. It sounds crazy but I saw first hand ....with a new battery they worked perfect. With that said some leds are more forgiving than others. The square superflux I use now will light with 1/2 to 3/4 voltage. The little cheap 2 leg ones usually do not.
LED TAILS
Old 06-08-2018, 05:32 PM   #11
The Rocknrod
Moderator
I'm going to use the wire idea from the ground to ground.
I have other LED's light up on the truck, Cab light etc. Suffice it say I'm not using a "battery".
Let you know on the wire.
Old 06-08-2018, 06:30 PM   #12
Robznob11
Robznob11's Avatar
Looking at the plastic housing and bulb you are using. It really can only be 3 things...
1. Prong in middle is not contacting prong on bulb.
2. You are not getting a good ground to the housing of bulb.
3. You have the wires backwards.
Your bench test eliminates everything else!
LED TAILS
Old 06-10-2018, 06:41 PM   #13
toolboxchev
and the top rated cause of LED lighting not working is wiring is backwards. This applies specifically to DC voltage systems.
toolboxchev is offline   Reply With Quote
Old 06-12-2018, 09:03 PM   #14
Ramjet51
Ok Master Chief...I note that you’ve got alligator clips during bench test...so if you’ve got power on the wires, I agree with others, it’s the metal housings that’s the issue. Eliminate them at the end of the wire .... run with temporary clips...it’s got to be simple..EMC(SS)...
You'll never know unless you try
Ramjet51 is offline   Reply With Quote
Old 06-12-2018, 09:09 PM   #15
Ramjet51
Old 06-13-2018, 06:42 AM   #16
The Rocknrod
Moderator
Well I'm in Ohio right now so I will be home in a month and figure this out. Thank you for all your help on this. I will check the 'wires backwards' thought on this right away when I get home. It could happen.
Old 06-13-2018, 08:51 AM   #17
DLW
If the regular bulb works fine as you said, it is not wired backwards ..
From your test, you know power is bottom, ground is body on both bulbs, and the AA courtesy light kit is wired the same way.
LED just is not getting power or ground from the socket, or, as was mentioned, insufficient voltage for LED, which I only bring up because you mentioned you are not using a battery so I assume you are using a battery charger for all this and that is what the alligator clips are? Just an idea there.
Old 06-13-2018, 09:14 AM   #18
Robznob11
Robznob11's Avatar
Ummmm... this is wrong information....the regular bulb does not care which way the wires are...it will light if you swap it either way. Now if it was a stock housing on a single pole bulb it would be safe to assume that they were correct because if they weren't there would be a short since most stock housing ground to the body some how. But since it is a plastic housing with wires...someone could easily swap them wrong. Everyone said check polarity in the first few post. This did not mean polarity of the bulb it ment polarity of the socket. That is what matters. There is no polarity on a regular bulb!
LED TAILS
Old 06-13-2018, 03:40 PM   #19
DLW
I hate putting wrong information, you are definitely correct, thanks for correcting, my bad. You would think I would know better after just rewiring my whole truck.
I guess what I should of said is if the orange wire is ran to power and white is to ground as it should be (it's written right on the wire), then it is not backwards ..
Old 06-13-2018, 04:54 PM   #20
GOPAPA
"Tail Gate Best Seat In House"
GOPAPA's Avatar
They make flashers for Led and flashers for incandescent. if not mentioned above ..this may be the problem
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 06-13-2018, 05:05 PM   #21
Robznob11
Robznob11's Avatar
You are correct but those are for blinkers and flashers. Probably not for a courtesy light. But while we are on the subject ....those are polarity sensitive as well and many may find they need to reverse the wires on those as well for them to work. It just depends on the flasher you buy....I had to on my turn signal side using an EZ wiring kit...
LED TAILS
