Old 02-19-2014, 09:44 PM   #51
Hankster
Hankster's Avatar
Re: Shucks First Build
Just read your thread, You got a good start.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-19-2014, 10:13 PM   #52
Austin.Landers
Looking good, wish i could of done this in my hs auto class.
Austin.Landers is offline   Reply With Quote
Old 02-19-2014, 11:55 PM   #53
Shucks
Shucks's Avatar
Well my teacher is pretty laid back and has built many cars himself, so he's basically all over this project with me. He's always anxious for the next part to the truck I bring in.
Shucks is offline   Reply With Quote
Old 02-24-2014, 11:51 PM   #54
Shucks
Shucks's Avatar
Heres 3 bags of sand blasting, Ran out and need a couple more to finish the inside.
Control arms will be blasted when I take them off for bushings. Ill run to town soon and grab a couple more bags to finish the inside frame. The axle will get cleaned and blasted when I do my flip kit.
Old 02-25-2014, 12:14 AM   #55
Cape Codder
Cape Codder's Avatar
Is that bale of hay getting some sand for flavor? Looking good you are getting right to it.
Cape Codder is offline   Reply With Quote
Old 02-25-2014, 12:30 AM   #56
Shucks
Shucks's Avatar
Hah, I debated getting the tractor out and moving it, figured the horses eat things that are worse. I just wanted to get started!
Old 02-25-2014, 07:53 PM   #57
Shucks
Shucks's Avatar
Wire wheeled the fire wall and got rid of some rust and left over rubber gasket stuff from the heater, also got rid of some bubbly stuff that was caked all over the firewall, not too sure what it was.
Also, where the battery tray was on the core support had rotted out the bottom of it, is there a replacement patch for that, or is it something where I just find another or just make a little patch plate and weld it in?
Old 02-25-2014, 09:33 PM   #58
Cape Codder
I would use the core support problem as a good spot to get experience fabricating and welding in a patch. It is not real visible and is a fairly easy patch to make. You will have better skills and more experience when it is time to deal with more difficult areas.
Bob
Old 02-27-2014, 08:10 PM   #59
Shucks
Shucks's Avatar
Well I tried anyway, first time ever making a patch panel. Criticism welcome, sometimes I need it to learn.
to the left on this picture, the white which looks like is a gap, its just the paint reflection.
Now some professional patch panels came in today too!
Old 02-28-2014, 09:05 AM   #60
Cape Codder
Experience comes when you begin. That is a start your skills will improve as you go. You now have metal where a hole used to be. To bend a piece of sheet metal without a brake try clamping a piece of angle iron on both sides of it in a vise and then hammer it over in small increments or even with a block of wood and you will get a cleaner bend.
Old 02-28-2014, 10:38 AM   #61
TheBlueBomber
TheBlueBomber's Avatar
It's going to be interesting to see what my first patches will look like. Keep up the good work!
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 02-28-2014, 08:35 PM   #62
Shucks
Shucks's Avatar
Nothing huge but..
Old 02-28-2014, 09:51 PM   #63
Greenlee
Greenlee's Avatar
Nice work!
Greenlee is offline   Reply With Quote
Old 03-06-2014, 04:44 PM   #64
Shucks
Shucks's Avatar
Finished up the core support.
Moved onto the body work. The cab mounts are insane to get out. Using an air chisel to do it. Anybody have any tricks?
Quick question to the bagged guys.
The one thing I want to do to the truck but cant afford is putting the truck on bags. Now a lot of the cost in it is the 4 link set up, How much could I save if I built my own 4 link in my welding class next year for a class project? My welding teacher knows how to make just about anything work and I know he could help me out and get it done right. I just dont have 4 grand to spend...
C H E V R O L E T
Check out my build thread!
Shucks First Build
Old 04-01-2014, 07:18 PM   #65
Shucks
Shucks's Avatar
Well it's been awhile since an update just because I hate my upload method, it takes too long but I finally found a better way.. Here's what I've gotten done since its been nice out.
Epoxy Primed
I only have a picture of it tacked in, its a solid weld now.
Cleaned and you can see my new cab support mounts are in
New tumbler installed, got the keys to it now!
Painted
As of today in the shop.
Just got a shipment in of new rotors, calipers, 5/6 lowering kit in. So tomorrow bushings go into the control arms and I'll reassemble the front end and paint the back end when I take it apart to flip it.
C H E V R O L E T
Shucks First Build
Old 04-13-2014, 05:38 PM   #66
Shucks
Shucks's Avatar
5 inch drop
Started this afternoon on the rear end before the rain showed
C H E V R O L E T
Shucks First Build
Old 04-13-2014, 10:44 PM   #67
TheBlueBomber
Looks sweet!
Austin
Old 04-14-2014, 09:40 PM   #68
Shucks
Shucks's Avatar
Here it is actually installed.
C H E V R O L E T
Shucks First Build
Old 04-16-2014, 11:54 PM   #69
Shucks
Shucks's Avatar
Well half of it's rolling now!
Are the shocks upside down? Teacher wasn't there today and the wording embedded on the shock was right side up that way, but it looks goofy. I honestly don't know!
C H E V R O L E T
Shucks First Build
Old 04-17-2014, 10:00 AM   #70
aggie91
I'm just glad to be here!
aggie91's Avatar
Loooks good. Shock are on correctly.
You are doing a great job. Will you have it finished/running & driving by the end of the school year?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-17-2014, 11:30 AM   #71
Shucks
Shucks's Avatar
Thank you. And I hope to have the motor and transmission placed in the truck with the cab on too. Driving, maybe not because I still need a fuel supply and cooling system. I only have 30 or so days left of school
C H E V R O L E T
Shucks First Build
Old 04-18-2014, 10:20 PM   #72
Shucks
Shucks's Avatar
Motor going in it's new home
C H E V R O L E T
Shucks First Build
Old 04-22-2014, 12:57 PM   #73
Shucks
Shucks's Avatar
C H E V R O L E T
Shucks First Build
Old 05-06-2014, 11:20 PM   #74
Shucks
Shucks's Avatar
Slowly but surely... Frames on the ground with new brake lines front to back, flipped rear end, 700r4, Hedman headers, full dual exhaust minus the mufflers, havent bought them yet.
C H E V R O L E T
Shucks First Build
Old 05-08-2014, 11:28 AM   #75
aggie91
aggie91's Avatar
Nice job on the brake lines.
Karl
The LST Challenge:
