12-21-2017, 04:33 AM | #1 |
Caliper and Spindle ???
Ran into another problem on lowering my 69 GMC. I ordered CPP 2 1/2 inch Drop spindles and when I went to install I noticed the Calipers mounting bolt holes seemed to look different.
The bolt holes on the spindle now on the truck were 5 3/4 inches center to center and the new spindle mount holes were 7 inches apart. No fit on these ? I called CPP and they said it looked like according to the measurement that I had S10 spindles and Calipers. The Tie Rod hole is not the same size and no fit also on new Cpp spindles. Did not check Ball Joint fitment. Anyone heard of this before and best way to resolve. Get S10 spindles or start all over. Front suspension was supposed to be from 82 model. 1 1/4 rotors fit both spindles OK. Thanks for any ideas JR |
12-21-2017, 07:47 AM | #2 |
Re: Caliper and Spindle ???
Post pictures of what you have and we may be able to better identify them for you.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-21-2017, 09:02 AM | #3 | |
67-72 parts collector,…
12-21-2017, 10:18 AM | #4 |
The ones on the truck now have 15649948RH CFD7 17 GM and 15649947LH CF010 GM
I can't find if these are part numbers or casting numbers. I tried to look up on Google but no luck converting them. |
12-21-2017, 10:52 AM | #5 |
I meant the CPP spindle part number,...
12-21-2017, 12:41 PM | #6 |
12-21-2017, 01:00 PM | #7 |
That is the correct part number for 73-87 spindles.
Posting pics would definitely help.
12-21-2017, 03:16 PM | #8 |
test attch
12-21-2017, 03:17 PM | #9 |
This is the on on there now. Not the CPP spindle
12-24-2017, 01:33 AM | #10 | |
Thanks JR |
12-24-2017, 09:43 AM | #11 |
S10 spindles are
totally different. Change your upper ball joint and outer tie rod to the 71-72 version. The lower ball joint should fit. Did you check the lower ball joint for fit?
12-24-2017, 07:09 PM | #12 | |
Thanks a bunch for the info - JR, doing this job for my son, I am getting too old 74 to lay under these things |
12-24-2017, 07:46 PM | #13 |
You need 73-87 ball joints and outer tie rods.
1-1/4” rotors and calipers.
12-24-2017, 07:53 PM | #14 |
I’m pretty sure the spindles on your truck now are 92-98 c1500 spindles.
NOT S10 spindles. There’s a lot of people that shouldn’t be working on these trucks. Here’s a 92-98 drop spindle. Same caliper mount.
12-24-2017, 11:06 PM | #15 |
Moderator
Those are 88-98 spindles. Someone swapped them to do a six lug disc brake conversion on your 69. It was commonly done years ago, and there is an faq here on it. You have a c20 lower control arm as such, and that will complicate any other 1/2 ton spindle you try to swap in as those arms will not accommodate the c10 ball joint.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-24-2017, 11:12 PM | #16 |
Moderator
IF you want to hit the easy button, just buy 88-98 c1500 dropped spindles, as they will bolt right up to what you have already and return all other parts you bought.
12-25-2017, 10:59 AM | #17 | |
Maybe its just with drop spindles, but I still don’t recommend it.
12-25-2017, 11:03 AM | #18 |
12-25-2017, 09:51 PM | #19 |
Moderator
Thanks for posting that. Just goes to show you can’t believe everything you read on the internet. I found two replies in the FAQ where they said it worked, but I’ve never seen any pics posted. I picked up a set of 4” fabtech lift spindles from a 92 in the junkyard and was planning on using them, based on the FAQ I read here on the board. After reading the above linked thread I feel like it will be a waste of time and money to continue that project.
