06-19-2019, 05:35 PM | #1 |
Stock reproduction engine wiring harness?
The only one I can seem to find is for HEI. Anyplace reproducing just the stock style harness?
06-19-2019, 09:19 PM | #2 |
Moderator
Re: Stock reproduction engine wiring harness?
This place sells the most stock I have seen - http://www.wiringharness.com/
LMC sells wiring harness in sections - http://www.lmctruck.com/icatalog/CBE/full.aspx?page=120
06-20-2019, 09:00 AM | #3 |
American Autowire . 100% best in the business. The people in the actual making of the harnesses are true car/truck people. One is a judge in many of the bigger clubs. Ive sent them many NOS wire harnesses to get them exact plus they have all the Packard and GM GMC schematics for building them
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
06-20-2019, 09:43 AM | #4 |
Truck is completely rewired from AAW, every factory clip was exactly where it was supposed to be.
06-20-2019, 11:48 AM | #5 |
Truck and car shop sell someones. I've bought them for many projects and have had no issues.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-23-2019, 08:10 PM | #6 |
Junior Member
Have used Lectric Limited with no complaints.
06-24-2019, 11:47 AM | #7 |
I used the factory style AAW harnesses from Classic Parts. Everything fit perfect and had all of the correct plugs, clips, etc. They sell different versions for stock, HEI, whatever you prefer. Not cheap, but totally worth it.
06-25-2019, 11:39 AM | #8 |
Thanks for all the replies! Is Classic parts the only one selling the AAW harness?
I just looked at CP site and this is what they had for 64-66 V8 with gauges. Is this the AAW harness you all are running? https://www.classicparts.com/1964-66...info/52%2D130/ I dont remember my 65 having plastic corrugated wire protector or crimp connectors. Is there is a source for new plug and terminals? Anyone have a pic of factory original harness? |
06-25-2019, 12:28 PM | #9 |
It looks like they carry an "OE" series that appears to be more like the factory harness (without the plastic split loom). I think this is what you are looking for:
https://www.classicparts.com/1964-66...fo/52%2D130B/# I used the HEI version of this "OE" harness on my '66. I don't know if this particular harness uses crimp connectors, and can't remember what mine has on it. If that's an issue for you, call em up and ask (either AAW or CP). Keep in mind that unless you solder and heat shrink a harness from scratch, pretty much any way you go will likely use crimp connectors. No idea who else sells AAW; Classic Parts is local to me so I didn't look much further. AAW is a big company, and I'm sure there's other vendors online if you prefer. |
06-25-2019, 02:44 PM | #10 |
Thanks for that, my search skills seem somewhat lacking these days.
As far as crimp connectors I meant the generic insulated type that you get from the part store. The pic of the OE is more what I remember. Found AAWs site and looks like I can order directly from them. Thanks again for all the guidance, the ol girl deserves the best |
06-25-2019, 04:22 PM | #11 |
No worries, glad to help. That thing is sweet! You won't regret replacing the wiring.
06-25-2019, 09:14 PM | #12 |
Order from Matt’s Bow ties, they are a sponsor and I believe in Cali. Maybe he can get you a good price.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-29-2019, 05:47 PM | #13 |
brothers truck
