02-08-2015, 05:04 PM | #1 |
Disassembly of cab... HELP!
Hey guys, finally been able to get some stuff done on the truck. She is a 1951 3100. I am trying to separate the inner panels so I can get all the rust cleaned up behind the panel, but I have run into some problems getting the rear panel out. I can't figure out what I'm missing. I have cut all the spot welds and have removed those bolts under the lip. I can feel the thing moving around but it isn't budging. I have a factory assembly manual and I can see where the parts are supposed to separate, but the manual gives me just a small image that is less than helpful. I was hoping for some advice from some of you guys with experience with getting this piece out.
02-08-2015, 06:02 PM | #2 |
Re: Disassembly of cab... HELP!
The panel around the window? What about spot welds at the belt line? The verticle ribs spot weld on the belt line and may be securing the rear panel.
02-08-2015, 06:23 PM | #3 | |
I don't know, please do educate me. If you are veteran with this work, I'll follow you blindly. So I need to separate the belt line from the panel? |
02-08-2015, 06:48 PM | #4 |
02-08-2015, 07:03 PM | #5 |
Nice work. Glad you got it.
02-08-2015, 07:39 PM | #6 |
Slow day on the assembly line, or change made during production that was not documented. QC may have noticed problems and the quy said "they want more welds, well here you go..."
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-08-2015, 09:50 PM | #7 |
Or sometimes the guy who is behind the welder decides to go rogue and add some to their liking !
04-06-2015, 06:14 PM | #8 |
So how things go'in Gearhead? The rear outer panel was the same on mine. Frick'in million spot welds.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
