03-13-2007, 11:15 AM | #1 |
What motor oil do you use?
Hey all, I am trying to make a final choice on which oil to run in my 06 5.3 2wd Silverado.
I know that everyone will have their favorite and/or opinions, but I just wanted to compile a list and see which brands stick out. Do you run Conventional or Synthetic? What brand? Thanks
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
03-13-2007, 07:25 PM | #2 |
Re: What motor oil do you use?
i have always been a fan of the mobile one fully synthetic its a little more expensive but it pours almost clear even after almost 7000 miles in a newer engine
1971 c10 350ci long bed fleet side |
03-13-2007, 10:34 PM | #3 |
I use mobil one 5w30 synthetic in my 5.3. I am extremely paranoid so I don't let it get much over 3000 before I change it but it always comes out lookin good. I always use a napa gold(wix) filter too. I have thought about switchin to royal purple but $2 more a quart is alot when mobil is already almost $6
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver) 1970 c10 short step just gettin started on it (project) |
03-14-2007, 12:16 PM | #4 |
67 is sold
Mobil 1 5w-30 in my 5.3l GMC with the Mobil 1 filter - all I run
I change it around 8K miles or so, two cycles of the GM OLM.
Joe - Formerly 67c10step ------------------------------- 1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD gr8lakes - My ebay auctions Click here to order forum apparel :: Click here to become a subscribing member Last edited by Joe67; 03-14-2007 at 12:17 PM. |
03-26-2007, 09:50 PM | #5 |
mobil 1 is great, Castrol is also good. Pennzoil is definetaly the WORST crap ever put in a bottle!!!!! Synthetic is great but not for high miler motors, and you cant break a motor in on it either
04-01-2007, 07:27 PM | #6 | |
I would do a flush firast but thats just me. Also I run Mobil 1 filters and or K&N. Bill Last edited by wildebill308; 04-01-2007 at 07:29 PM. |
04-02-2007, 02:28 AM | #7 |
Not exactly sure but I think it says in the manual to not use synthetic for the first 5k or so.
I heard or read that somewhere?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
04-04-2007, 10:52 PM | #8 | |
Bill |
04-05-2007, 12:31 PM | #9 |
Next project: 1970 K10
I run Amsoil in everything I own (my 02 GMC, mama's Monte Carlo, both motorcycles, tractor, and both snowmobiles).
In the 02 GMC 6.0L, I run Amsoil synthetic 5W-30 (ASL) with the Amsoil filter. Change filters at 5000 miles, change oil at 10,000 miles.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-07-2007, 06:16 PM | #10 |
I use GM , because it is the oil sold and installed by the Mr. Goodwrench guys that change my oil, filter and do the lube.....Three Trucks and two cars ago I started doing this and so far...knock on wood.....480,000 miles without having any of the engines repaired.
04-27-2007, 12:43 AM | #11 | |
Are you sure you are getting Goodwrench oil? I have worked at two large dealers, and the bulk oil is not Goodwrench oil at either one. It is decent oil, but not actual Goodwrench oil, although we do carry that in bottles.
04-27-2007, 07:42 AM | #12 |
lucas 5/30
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
05-05-2007, 09:49 AM | #13 |
STILL PLAYS WITH TRUX
OKay here's the deal all oil out there has to meet strict Goverment and Mfg. Spec's. & Reg's. and pass many test just to be bottled and sold to the public Soooooo.
With that said i know theres gonna be a few guys say yeah but! this that and the other thing. If you change your oil regularly and for me that's every 5k not 3k you will never have any kind of an eng. failure. I buy the conventional Wally world oil it's called Super Tech i use the 5w30 in the '99 Hoe and the 10w30 in the '87 Stepper. It's Quaker State in a wally world bottle @ 1/2 the price. Say what you want but for something that your gonna throw away anyway's why pay out all that money it's false insurance. As for Synthetic that's another line of BS the conventional oil's of today are so refined and well engineered to provide the best protcetion ever you don't need to run this stuff unless you have a car that the Mgf. requires it or if you just like to waste your money. Now if this is a rece engine then you need to use the proper oil for that application. |
10-16-2007, 09:23 PM | #14 |
Not a bad nut after all..
Can you share your source? I'd like to confirm this.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
11-01-2007, 05:03 AM | #15 |
I use Royal Purple Synthetic in my trucks.
Earl 68 2500 4x4 GMC Burb |
11-01-2007, 10:32 PM | #16 |
MOBILE 1 USER HERE........
But, check your oil level at least once a month when you pay your car insurance or something. It is normal for a chevy engine to use a full quart every 3000 miles!!!!!! That was printed out for me by my Grease Monkey guy when I asked if I could be burning oil (56K miles). Good thing my Impala has a low oil level light! I should know better to check more often, but now I will for sure. As for conventional oils being as good as synthetics......I've seen too many State Fair Demonstrations comparing the two to believe that all that research and science was for nothing! A.......
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
11-01-2007, 11:49 PM | #17 | |
oil not be used during the "break-in" period of an engine. The reason for this is that synthetics, possessing extraordinary lubricity and lubricant film strength, do not permit the metal wear necessary for the seating of piston rings. A change to synthetic motor oil should wait until you new or rebuilt engine has completed the break-in period of six to eight thousand miles." According to Mobil, this is no longer an issue with the engines of today, but who knows... For the record, I use Mobil 1 in both trucks. After breaking them in on convetional.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
11-08-2007, 05:36 PM | #18 |
we use mobil one at my work for full synthetic we run and oil system cleaner before frist synthetic oil changer and after that oil comes out just as clear as when it was put in after 6000 miles running powerflow filters (puraltor)
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
11-09-2007, 08:19 PM | #19 |
Right turn Clyde
Is the oil system cleaner an additive or machine?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
11-09-2007, 09:33 PM | #20 |
In the Forgotten far North.
Correction Wildebill308......... BMW's use 5W30 full synthetic CASTROL OIL OIL exclusivly in all their models with the exception of the M3 M6 & Alpina7 which all use CASTROL 10W60 OIL . I've worked the parts counter @ BMW for 8 yrs.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
11-10-2007, 12:31 PM | #21 |
Mobil 1 synthetic 5w-30 in my 04 silverado 5.3L
11-11-2007, 09:39 AM | #22 |
clay
Mobil 1, in my trucks, car & Motorcycle, never had motor failure 25 years and 1 million plus miles (pure luck). In addition to LUCK any good oil regulary changed is good insurance, But, i think we all know bad things can and still do happen no matter how well we take care of our cars, trucks etc... my 2 cents worth
