Old 02-11-2018, 12:09 AM   #1
Curt - TN
1950 Side Glass Not going to the top when up
I a finally getting back on the 50 project and I just installed new reproduction window regulators and new side glass. The issue I am having is no matter how I adjust the regulator positioning the glass is about 1/2 inch to an inch form the top when cranked all the way up.
Any ideas on what might be causing this?
Did I mention how much I hate installing doors and glass
Thanks,
Curt
Brentwood TN
1950 Chevy 5 Window 3100 - Check out my Build Thread: http://67-72chevytrucks.com/vboard/showthread.php?t=724260
1957 GMC 100
Curt - TN is offline   Reply With Quote
Old 02-11-2018, 12:26 AM   #2
mongocanfly
mongocanfly's Avatar
Re: 1950 Side Glass Not going to the top when up
"Did I mention how much I hate installing doors and glass"......amen brother...
can you physically push the window all the way if unhooked from the crank?....is it both sides or just one..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-11-2018, 05:33 AM   #3
MiraclePieCo
MiraclePieCo's Avatar
There is a screw near the top of the window channel that secures the felt channel in place - is that screwed out and interfering with your glass?
If you can't find the problem, just have a longer window glass cut that will reach the top. I've done it, it works fine.
MiraclePieCo is offline   Reply With Quote
Old 02-11-2018, 08:53 AM   #4
Curt - TN
There is nothing interfering with the glass going up, did it with and without the felt. Everything is new and nothing is binding, it seems like the window regulator is stopping before the glass hits the top.
A longer glass would be a good idea, the glass is new reproduction, will have to see how it might effect the chrome trim around the glass.
Curt
Brentwood TN
1957 GMC 100
Old 02-11-2018, 09:55 AM   #5
mongocanfly
did you compare new to old on your regulators?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-11-2018, 10:26 AM   #6
Curt - TN
I bought the truck as an unfinished project, it did not have glass or the original regulators
Curt
Brentwood TN
1957 GMC 100
Old 02-11-2018, 04:44 PM   #7
MARTINSR
MARTINSR's Avatar
I HATE reproduction parts! OMG I will do ANYTHING but use reproduction parts. There is almost no adjustment on those windows because it's not needed it's not a hard top for goodness sakes it's not rocket science! Geeez the damn thing should work without much thought. I HATE reproduction parts!
Brian
ps: did I mention I am not real fond of reproduction parts?
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-11-2018, 07:48 PM   #8
Advanced Design
Advanced Design's Avatar
Curt where have you been? Can you show a pic or video of the regulator? Probably can't really see it in the door. Maybe a tooth timing issue with the gears?
I agree with Brian on reproduction parts. Seems like there is no effort to make them correctly....just to make something that looks right and make money from it...wether it works correctly or not. Very frustrating!
Advanced Design is offline   Reply With Quote
Old 02-12-2018, 12:20 AM   #9
mr48chev
mr48chev's Avatar
Thinking back 45 years when I had just bought my 48 and was changing windows to replace the broken ones one arm on the regulator may have caught on something inside the door not allowing the window to go all the way up. I can't remember much more about it but remember that something was hanging up.
You do have the roller that goes in the track in the door in that track right. I fought that deal once or twice.
My ongoing truck projects:
Old 02-12-2018, 12:52 AM   #10
MARTINSR
MARTINSR's Avatar
Maybe the bolt in that holds the window frame to the channel? It's too big or something originally it was a round headed clutch head screw, maybe you put a bolt so the roller can't get past it?
Brian
1948 Chevy pickup
