Old 05-09-2019, 02:52 AM   #1
yeah_yeah_na
Fuel tank relocation question
I'm wanting to do a fuel tank relocation to a 61 GMC short bed step. The only kit I can see online for the 60-62 is a welded alloy one with a bed fill. What have others out there used or can the 63-66 kits be easily modified to fit?
yeah_yeah_na is offline   Reply With Quote
Old 05-10-2019, 10:39 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fuel tank relocation question
There is a write up here about a 69 tank being wider that a 66 frame. May work for the 61's? - http://67-72chevytrucks.com/vboard/s...d.php?t=448386
Also - http://67-72chevytrucks.com/vboard/s...d.php?t=370496
There is a whole conversion thread here - http://67-72chevytrucks.com/vboard/s...d.php?t=558629
Old 05-12-2019, 02:01 AM   #3
yeah_yeah_na
Thanks for that, I'd found the conversion thread using the search function but not the others. Any idea what the difference is between the frame rails on the 60-62 vs 63-66.
Old 05-12-2019, 03:59 AM   #4
yeah_yeah_na
Old 05-12-2019, 08:45 AM   #5
The Rocknrod
Moderator
There are people on this site who have the frame dimensions info, I do not. If they see this thread your golden. If not keep bumping it.
Old 05-12-2019, 10:21 AM   #6
Clyde65
Clyde65's Avatar
The difference is 60-62 are 8” wider than 63-66
I believe it’s 34” and 42” but I’m not sure if that is outside or inside measurement
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-12-2019, 11:47 PM   #7
Captainfab
60-66 Nut
Those are the outside frame rail measurements. The '63-'72 frames have room for a tank 26.5-27" wide inside the rear frame rails.
Old 05-13-2019, 11:56 AM   #8
Clyde65
Clyde65's Avatar
Thanks Captn, I’ll make a note.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-14-2019, 02:40 AM   #9
yeah_yeah_na
Thanks for that, I've got a '60 with an under bed tank but I can't for the life of me figure out what its from.
Good to know that the 61 will have a little more wiggle room to fit a tank than the '63.
Old 05-22-2019, 08:20 PM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
I've tried to talk to some of these guys about the french door access. Then i ask why can't you fill from Both sides of the tanks you know what hassle it is when your running on empty and every one4 is on the driver side is full. But if you had a french door on either side of your truck it would make filling your truck so much more easier. To me it would solve most of your problems at the Pump.
stsalvage is offline   Reply With Quote
