Old 04-06-2014, 06:53 PM   #101
Matt21lutz
Matt21lutz's Avatar
Re: 1991 1 Ton Crew Cab 4x4 Build
Originally Posted by 91V3500 View Post
I ordered a sample of "torch red" colored seatbelt from seatbeltsplus.com, it matches perfectly! I'm gonna order enough to do all of the seatbelts. Thanks for the link!
Can't wait to see the final product! Looks bad ass! But was wondering, are you doing the seat belts yourself or having someone else do it for you?
My current ride: 1983 C10 Silverado LWB - Work in Progress
Matt21lutz is offline   Reply With Quote
Old 04-06-2014, 08:30 PM   #102
y5mgisi
Second Chance Program
y5mgisi's Avatar
Keep at it. Worst case scenario, you finish it and sell it. At least then you can say you finished.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-06-2014, 09:31 PM   #103
91V3500
Originally Posted by nekkidhillbilly View Post
kept it longbed.....i love you for this
Ha ha, I thought about it but I don't like the look of the 4x4 crew shortbeds as much as the longbeds. To me the shorbeds don't look proportional with the lift and big tires. Plus I want to be able to haul my Polaris RZR in the back (with the tailgate down) which is about 9 feet long!
91V3500 is offline   Reply With Quote
Old 04-06-2014, 09:41 PM   #104
91V3500
Thanks! I ended up buying all new seatbelts/mechanisms for several reasons. I was going to let my upholstry guy install the red material into my old mechanisms but after looking at my old mechanisms, they were in bad shape. The plasic covers had cracks in them and some of the release buttons were rusted stuck. Plus, just the seatbelt material was going to cost around $100 and I had to pay my guy to install it. I got all 4 complete seatbelts for less than $300. I highly recommend seatbeltsplus.com, they have about any color you would need.
Old 04-06-2014, 09:45 PM   #105
91V3500
Originally Posted by Greenlee View Post
Slow and steady wins the race. Can't wait to see it with some paint!
That's me, slow and not so steady lol. I can't wait to just see it all 1 color!
Old 04-16-2014, 09:34 PM   #106
91V3500
I've been working on the rust repair, I stripped the interior out of the truck so I can weld in the rocker panels. Also removed the doors and frontend so I can put a good coat of paint on the jams and inner doors. I have the driver's rocker almost fully welded in and the driver's rear lower bed panel is welded in. I also replaced all of the seals in the AC system and pressure tested it for leaks, so far so good. Still need to replace the low pressure switch, pull a vacuum on it and charge it up, it will be nice to have AC this summer.
These repair panels from LMC truck suck, they're not even close, some of the measurements are off and the bend radius' are different. I made them work but is there a better place to buy repair panels? These have "Key Products" name brand on them and "Made in Taiwan".
Old 04-17-2014, 10:00 PM   #107
silverbear
silverbear's Avatar
I used a cab corner from Summit on my 86 regular cab. Since I was only using a portion of it, the fit worked well. My buddies have used some panels from Top Banana and they seemed to be better quality but still needed a bit of tweaking to fit just right. LKQ/Keystone have two lines of panels, a high end and a low end quality. Again, the high end ones seem good but not 100% all the time.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 04-17-2014, 10:21 PM   #108
90crew
Question you don't still have the grill from that suburban do you? I have a 90 Crew that is your twin and wanted the double light set up and the GMC Grill. If you still have it let me know if you would be willing to sell it to me. Love your set up my build will start soon. Like I said mine is like yours when you first got it.
90crew is offline   Reply With Quote
Old 04-18-2014, 08:30 AM   #109
91V3500
Sorry, I don't have any of those parts anymore. I sold everything that I didn't use because I don't have anywhere to store extra parts.
Old 04-18-2014, 08:39 AM   #110
91V3500
That's good to know. The main problem with these rocker panels is the measurement on the top step plate (from the lip for the wetherstrip to where it turns down for the door opening) is about 1/4" short. The only way to fix that is to cut it and weld in an extra 1/4". Also they didn't bend the bottom lip inward 1/8", so it was just a raw edge across the bottom which made the new rocker panel hang down 1/8" lower than it should and didn't line up with the cab corner. Luckily we have a full sheet metal shop at work and I just bent that 1/8" myself.
Old 04-18-2014, 09:05 AM   #111
silverbear
silverbear's Avatar
I found that same issue when I was patching my driver side rocker. I ended up using some 18ga sheet metal and making my own patch and seal lip.
On an Astro van that I replaced a rocker panel with an aftermarket panel, I had the same issue with the bottom lip. After I welded it into place, I used a body hammer and bent the lip over the inner panel. Having a sheet metal shop available sure would make things easier.
1996 GMC Yukon GT
Old 07-05-2014, 11:25 PM   #112
91V3500
I finally got all of the welding and the patch panels done on the truck. It's getting sanded, bodywork, and primed now. We should have some some color on it next week. I'll post pics when I get some good ones.
Old 07-07-2014, 10:45 AM   #113
1968vetL-71
Junior Member
1968vetL-71's Avatar
Can't wait to see that beast with some paint. Gonna look killer!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 07-14-2014, 10:52 AM   #114
91V3500
Working on getting all the panels back together.
Old 07-14-2014, 12:31 PM   #115
arrover
arrover's Avatar
Looking great!
1982 GMC Crew Cab 4x4 - "River Truck" build thread
1973-1987(91) Chevy/GMC How-To Videos
arrover is offline   Reply With Quote
Old 09-22-2014, 10:03 PM   #116
91V3500
Still working on getting it all back together but it's driveable again.
Old 09-23-2014, 12:27 AM   #117
y5mgisi
y5mgisi's Avatar
Certainly come a long way!
Old 09-23-2014, 10:02 AM   #118
carboncrew
carboncrew's Avatar
wow....looking good. I like the lift, wheel/tire and now color combo.
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 09-23-2014, 09:26 PM   #119
COS399
COS399's Avatar
Sweet. Looking great!
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 09-24-2014, 08:24 AM   #120
Greenlee
Greenlee's Avatar
Looks great with paint!
Greenlee is offline   Reply With Quote
Old 09-24-2014, 09:23 PM   #121
silverbear
silverbear's Avatar
Truck looks awesome. Can't wait to see some more part pics of it as you wrap up the details. Excellent job!
1996 GMC Yukon GT
Old 09-25-2014, 12:08 PM   #122
Flatpat
Flatpat's Avatar
Looking good! More motivation to jump on mine when I get back to it. Keep it up.
Flatpat is offline   Reply With Quote
Old 09-25-2014, 02:31 PM   #123
NewMexCrew
NewMexCrew's Avatar
WOW.... Truck looks good. This just might inspire me to lift and paint my 90 Cummins conversion. I'm looking to put a 10" or 12" lift but might need to have springs made to hold the weight of the Cummins.
NewMexCrew is offline   Reply With Quote
Old 09-29-2014, 08:52 PM   #124
1968vetL-71
Junior Member
That looks awesome! You've done a great job on that thing. It is a beast!
Old 01-14-2015, 02:35 PM   #125
91V3500
Thanks guys!
Progress has been slow but I have been trying to get the interior all back together
