Closed Thread
Old 03-13-2017, 11:13 PM   #5101
funkyT
Re: What did you do to your truck today? Chapter II
Bolted the steering gear and linkage up to the frame.
funkyT is offline
Old 03-15-2017, 09:51 AM   #5102
iriereggaeman
iriereggaeman's Avatar
Originally Posted by kilrcady View Post
I went 3/4" to nothing wedge
Thanks kilrcady. I tried the same but didn't have great results, so I went a different route. I put a decent gauge piece of black copper wire at the bottom - figured it wouldn't rot or rust. But, what really made a difference was cutting away a piece of the mirror swivel ball to allow for more adjustment range. I just used a metal cutting wheel on my dremel.
picture to get some perspective:
closeup of the cut:
closeup of the cut, 2:
the result, from the driver's seat:
I'll probably have to keep a good coat of grease in there to keep it from rusting, but at least it's useful now.
iriereggaeman is offline
Old 03-15-2017, 03:52 PM   #5103
kilrcady
Originally Posted by iriereggaeman View Post
thanks kilrcady. I tried the same but didn't have great results, so i went a different route. I put a decent gauge piece of black copper wire at the bottom - figured it wouldn't rot or rust. But, what really made a difference was cutting away a piece of the mirror swivel ball to allow for more adjustment range. I just used a metal cutting wheel on my dremel.
Picture to get some perspective:
Attachment 1632545
closeup of the cut:
Attachment 1632546
Attachment 1632547
Attachment 1632548
i'll probably have to keep a good coat of grease in there to keep it from rusting, but at least it's useful now.
nice!
kilrcady is offline
Old 03-15-2017, 10:20 PM   #5104
ekgguy
ekgguy's Avatar
I knew that this new to me cab that I bought was going to need cab corners when I bought it, most do.
Also, being a member and a lurker for a while, I have seen quite a few interesting things that have been found in our trucks that was done by PO's.
This has to be up there on the list
Not only the spray foam, but they threw the cap in for good measure!
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline
Old 03-15-2017, 10:31 PM   #5105
jdalexa84
Changed from a stepside to a fleet bed
jdalexa84 is offline
Old 03-15-2017, 10:57 PM   #5106
clint'71c10
Talking Re: What did you do to your truck today? Chapter II
Stripped the truck down to the frame
clint'71c10 is offline
Old 03-16-2017, 10:08 AM   #5107
Metaldoc
Metaldoc's Avatar
It's scary to think what people have done and thought they had done a good job.
Metaldoc is offline
Old 03-16-2017, 02:45 PM   #5108
rustytruck50
rustytruck50's Avatar
Nice...I bought a '68 C10 a few years back that had similar issues....the rusted through trailing arms were masterfully covered with plasti-dip, dust & whatever else...good enough that I didn't catch it until I jacked up the truck one day & both rear springs fell out...it was a clean realistic job...best I've seen in a long time.
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 03-16-2017, 10:49 PM   #5109
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
I thought you were having lunch with some Ham hock or some kind of pot roast. That is up on the list.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline
Old 03-16-2017, 11:15 PM   #5110
OregonNed
OregonNed's Avatar
Yeah - it looked pretty creepy at first!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-17-2017, 12:29 PM   #5111
RGT
finally measured the mileage since installing the 200R4 trans, got 16.5 in a mix of highway and around town(more highway to be sure) and I love the fact that I can hear the radio while running 65-70 down the road. Sppedo rolled over today so I ma back to zeros
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering.
RGT is offline
Old 03-17-2017, 01:43 PM   #5112
Metaldoc
Metaldoc's Avatar
Door logo in progress
Metaldoc is offline
Old 03-17-2017, 05:33 PM   #5113
RodnRudy
RodnRudy's Avatar
Scored two arm rests to replace my "reupholstered" ones. They're not color coordinated but my elbow doesn't know the difference. LOL
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 03-17-2017, 09:07 PM   #5114
Nomadicflyer
Nomadicflyer's Avatar
I installed new caliper hoses from Speedway Motors. It took cutting off the original brackets and welding the new ones on, but they look like the answer to a week of searching, parts returns and frustration!
1972 C20 Fleetside "Miss Olive"
http://67-72chevytrucks.com/vboard/s...d.php?t=721563
Nomadicflyer is offline
Old 03-17-2017, 09:46 PM   #5115
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Finished dismantling the cab less the front & rear windows and doors. I'll probably pull the hump as well, but space is a premium, so I'll save it for another day.
That and finished the first manual I'll be writing. At 75 pages it got too large (edit, reduce, standardize, edit, reduce, standardize.....Yikes).........so I figure one manual for body & windows, one for chassis & drive train, and the one I finished for all else. The next two should be much easier.
Boring I know, but for me it's an adventure..........In 5-6 months I post actual restoration. The rebuild will be MUCH quicker....promise. I've received a TON of guidance through this website, and it's always appreciated,
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 03-17-2017, 11:35 PM   #5116
Nomadicflyer
Nice Job, ShortBed!
Old 03-18-2017, 12:07 AM   #5117
71CHEVYSHORTBED402
Originally Posted by Nomadicflyer View Post
Nice Job, ShortBed!
Ha, thanks. Sure have learned a lot. Can't wait for suspension and the rest of the e-brake. Haven't the slightest idea how the Ebrake cable it's connected at the frame. I'll figure it out after I pull the body. Can't wait to start painting something, starting with the frame. Still haven't settled on body color. That's been a constant since I bought it.
Tony
Old 03-18-2017, 08:35 AM   #5118
flashed
Shortbed ,I love the current color ,dont see many like it anymore .
flashed is offline
Old 03-18-2017, 08:58 AM   #5119
Nomadicflyer
If you want pics of the parking brake, I can send you what my 72 has on it. If you want a slick upgrade, look at what Notsolo did on his build page.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605
Makes a lot of sense. Using a hook to apply pressure to the cable seems like it belongs on a Ford tractor.
Don't worry about the color until after you've gotten along in the project. I'll bet it comes to you.
Old 03-18-2017, 11:57 AM   #5120
71CHEVYSHORTBED402
May not be my favorite, but I like it a lot. The first image would be to the SPID, only sport mirrors and moldings added. That and a chrome rear bumper. The original owner liked all things recreational. This little short bed had a step bumper.............and boat launching hitch, CB, fifth wheel, aux. tanks, camper mirrors............For what it's worth, this truck will be "original" less the camper business, adding some value to orchre.
The second pic is another option.
Third pic has become a recent ponder.
If I had a 67 color would be easy........ Light blue and white.
Tony
Old 03-18-2017, 12:41 PM   #5121
71CHEVYSHORTBED402
Cool pulley. I know the layout, though haven't visited the brake drum yet. It's this piece that gave me trouble. I don't know how it detaches from the frame.
Tony
Old 03-18-2017, 12:47 PM   #5122
SatinSeventy2
Been hard it this morning. Install stereo and speakers last night and finally installed seat this morning; interior is done Except maybe a different steering wheel. Painted headers this morning and primer-etched valve covers. Lots of daylight left
SatinSeventy2 is offline
Old 03-18-2017, 03:18 PM   #5123
71CHEVYSHORTBED402
Doesn't take you all day to do a day's work. What did you use on your headers?
Tony
Old 03-18-2017, 03:40 PM   #5124
SatinSeventy2
They are old Hooker Competitions that already had the textured coating. I sanded, cleaned with mineral spirits and sprayed with 3 coats of 2,000degree High Heat Rust-Oleum.
Old 03-18-2017, 05:05 PM   #5125
rustytruck50
Installed plugs, wires, cap & rotor, changed the oil & filter & laid down some rubber! Gotta love old dried out tires!
-Doug
'05 RCSB Sierra 2WD
Closed Thread
