Old 02-01-2014, 05:33 AM   #76
fabguy
Elev8r Man
fabguy's Avatar
Re: My Wife's 55.2 Carryall / Suburban build
Not much progress yesterday as my parts came in I spent time gathering all the needed hardware to make it all work.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 02-01-2014, 01:11 PM   #77
Kabwe
Certified Car Nut
Kabwe's Avatar
Looks like someone's been busy. Good job man good job.
Kabwe is offline   Reply With Quote
Old 02-01-2014, 09:54 PM   #78
fabguy
Elev8r Man
fabguy's Avatar
Thanks man, I appreciate that.
Btw, what color IPhone did you get? Lol
1939 2 door sedan
Old 02-05-2014, 07:34 AM   #79
fabguy
Elev8r Man
fabguy's Avatar
I was able to spend a little time grinding welds on the frame front C notches. Did a little layout / mock up on trying to support the front frame area ahead of the crossmember.
Pics to follow soon.
1939 2 door sedan
Old 02-06-2014, 12:01 AM   #80
Flames97
Flames97's Avatar
Can't wait to see the pics.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 02-06-2014, 02:32 PM   #81
fabguy
Elev8r Man
fabguy's Avatar
Not gonna be able to work on the frame this weekend as I happened to stumble into some tickets for the Winternationals this weekend in Pomona and get to show my truck there in the pits from what I was told,.... woo hoo.
1939 2 door sedan
Old 02-06-2014, 03:08 PM   #82
lowrodderchev
lowrodderchev's Avatar
come back with some pix if you can.
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 02-06-2014, 04:57 PM   #83
fabguy
Elev8r Man
fabguy's Avatar
Ok will do
1939 2 door sedan
Old 02-09-2014, 11:22 PM   #84
BC Toy chest
BC Toy chest's Avatar
You got some mad skills man, gr8 work, keep the photos coming.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 02-09-2014, 11:41 PM   #85
fabguy
Elev8r Man
fabguy's Avatar
Thank you and will do.
It was a pleasure to meet you out at the races, you should have hung out a little later with us, a pretty well known frame builder showed up who is a friend of mines ex boyfriend (they are still good friends). I cant mention his name but he is going to stop by my shop in the next 2 weeks to check out the suburban frame and I also hit him up about apprenticing in his shop for a bit to sharpen some skills and experience. Hopefully I can take my experience to the next level with his help and knowledge.
1939 2 door sedan
Old 02-11-2014, 07:33 AM   #86
fabguy
Elev8r Man
fabguy's Avatar
Re: My Wife's 55.2 C4 Carryall / Suburban build
Well, yesterday I managed to acquire almost all the small hardware needed to finish the rear suspension mounting. I started tack welding the 4 link brackets into place and should have those done in the next couple days. After that it will be prepping or the first of many body fitting sessions. I will post pics very soon, as I wanted to have several of them so I could show the steps I took. New to get some DOM tubing today to finish the 4 link setup.
1939 2 door sedan
Old 02-14-2014, 08:59 PM   #87
fabguy
Elev8r Man
fabguy's Avatar
Ok UPDATE:
I tack welded the 4 link bars up and dropped them off to my buddy who was going to TIG weld them up tonight for me ( you can see them in the top left of the 1st photo ). I thought about TIG welding them myself but his look really good, as Mine would look really NOT so good. plus I am out of ARGON>
I also welded the rear wing support brackets, 4 link front brackets and then ground them down.
I also thought I would post a couple pics from the pomona drag races this last weekend.
My truck, My buddy Lenny's Panel, then a friend Carol's 55 with chameleon paint job. This 55 looks beautiful, I am not a fan of that paint, but the work in the body shows.
And one of my truck through my friends hubcap, really bad pic but I thought it looked cool.
and occasionally I got the question " how do you drive it SO low? aren't you worried you'll scrape? " I just smiled and told them about it being bagged.
1939 2 door sedan
Old 02-15-2014, 12:21 PM   #88
Kim57
Kim57's Avatar
Welds look good.
Nice pics from Pomona.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-15-2014, 07:49 PM   #89
fabguy
Elev8r Man
fabguy's Avatar
Originally Posted by Kim57 View Post
Welds look good.
Kim
Thanl You very much KIM57.
Todays UPDATE:
So I get to the shop and my bars are waiting for me WOO HOO so I started to get to work in tapping them out and installing them. I then went on to fabricate the shock mounts and attach them to the frame. Here are few pics of what I did.
I wanted to keep the same look as the other brackets I made, hopefully to help them flow together:
1939 2 door sedan
Old 02-16-2014, 01:50 AM   #90
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 02-16-2014, 07:34 PM   #91
fabguy
Elev8r Man
fabguy's Avatar
Looks good.
Kim
Thank You Km57
1939 2 door sedan
Old 02-16-2014, 10:47 PM   #92
sqrlnts
Damn you do great metal work. The large hole saw did the trick notching the frame for the rack, any tips on doing it this way or just have at it?
Thanks for sharing.
sqrlnts is offline   Reply With Quote
Old 02-16-2014, 11:48 PM   #93
fabguy
Elev8r Man
fabguy's Avatar
Thanks for sharing.
Thank you for the kind words sqrlnts.
As for using the hole saws it works great, a really great wrist and drill bit saver is to drill a 1/4" hole all the way through 1st. then use the hole saw to finish it out. If you don't pre drill the 1/4", when the bit pops through and the hole saw teeth grab, it binds and either twists the heck out of your wrist or the bit just breaks.
Then I took a cut off blade on a grinder to get the vertical cuts just right.
I hope this info helps you
1939 2 door sedan
Old 02-16-2014, 11:57 PM   #94
Flames97
Flames97's Avatar
I like the brackets, they look good.
-Aaron
Old 02-17-2014, 07:52 PM   #95
fabguy
Elev8r Man
fabguy's Avatar
Thank you, Flames97
Update:
Today I was able to finish a few small things and finaly got the frame onto the ground. I measured and my rockers will be.
Front: 6-1/2"
Rear 8-1/4" (that is going off of corvette ride height)
1939 2 door sedan
Old 02-17-2014, 08:48 PM   #96
Kim57
Kim57's Avatar
That looks real sharp.
Kim
My build thread
Old 02-17-2014, 09:57 PM   #97
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Looks awesome!
ChuckDriver is offline   Reply With Quote
Old 02-17-2014, 11:08 PM   #98
Flames97
Flames97's Avatar
Oh man......don't ya just wanna hoist the body on there to see what it looks like????
-Aaron
Old 02-18-2014, 12:39 AM   #99
oldman3
oldman3's Avatar
Sweeeeet...Jim
oldman3 is offline   Reply With Quote
Old 02-18-2014, 01:49 AM   #100
79azc10
Nice
79azc10 is offline   Reply With Quote
