07-14-2020, 01:29 PM | #26 |
Re: Looking for advice - wood bed 63 C20
Only question is about the wood selection - you say not to go to a Home Depot; I get this, however, is there really much difference? Especially if you're going to leave your truck outside most of the time? Your last paragraph says to not spend a lot of money on wood/stain if it is going to be outside. How much different is Whitewood from Home Depot vs Ganahl Lumber? EDIT: Also, you mention "tubs" - are these the inner fenders? If so, I don't think the 63 pickups had inner fenders.
1963 C20, small window, long bed 292, 4-speed |
07-14-2020, 02:45 PM | #27 |
Moderator
Wheel tubs: the black things in the pics that go over the tires.
Wood: yes, if your truck is going to sit outside, get cheap wood wherever, pick the straightest/clearest (no knots) boards you can from the pile. Then, seal it up well. Or, do Trex/other synthetic and never worry about stain. |
07-14-2020, 02:55 PM | #28 |
Here's the difference of about 3 years. First pic was a couple days after putting the wood in. Second pic was about 3 years after that. I used a stain/sealer combo, and obviously it wasn't up to the task of sitting outside 24/7 365. I still have plenty of the same stain, but this time, I'll be adding an additional sealer on top of the stain
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
07-14-2020, 10:11 PM | #29 |
Everyone seems to swear by Mar-K but I was disappointed with my bedwood kit. Maybe it was my fault for taking whatever couple of days to paint in the middle of summer but the boards warped during the few days I was painting them, and they didn't come drilled for the sides. If I was handy enough to drill these accurately, I would have just cut the wood myself. Wish I had tried that route, probably would have turned out just as good. Now I'm some $800+ into a bed that's just okay.
I really like the practicality of the Trek beds in terms of zero maintenance. If I was to do it over again, I might try that route.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. |
07-16-2020, 05:27 PM | #30 |
Since I need two boards that are actual 5-7/16” width, I wonder if I could get away with using 1x6 boards for these two center boards. These 1x6 boards are actually 3/4x5-1/2... that 1/16” should make a difference, should it?
07-16-2020, 05:33 PM | #31 |
You can do any width boards you want as long as the final result fills the bed. You would need to adjust the other boards accordingly...some people have put an equal width all the way across. Otherwise, I would not use 2 boards 5 1/2" and the rest the correct width...but that is just me.
07-16-2020, 05:48 PM | #32 | |
07-16-2020, 07:22 PM | #33 |
Still have a question regarding length of boards. The website states 97”, however, my bed is an actual 97.5”. Should I cut the boards to 97.5” to fit the bed length?
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 07-17-2020 at 12:19 PM. |
07-17-2020, 11:21 AM | #34 | |
I figure that the strips will be exactly 97", so maybe the wood should match this, even thought the bed may be slightly longer? EDIT: I looked at the freight cost for the wood kit and the strips alone, OMG. For the whole kit, the freight is almost as much as the cost of the wood. The freight cost for the strips alone is $237. I might just keep my strips and just clean them up.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 07-17-2020 at 11:40 AM. |
07-17-2020, 11:39 AM | #35 | |
I don't have that truck though, so take this for what it's worth. Random dude on the internet.
07-17-2020, 12:21 PM | #36 |
As you can see, my bed is 97-1/2", and the rail is 97".
I guess I'll just cut the wood to 97" to match the rail. Maybe it is supposed to have 1/4" gap at each end.
07-17-2020, 12:44 PM | #37 |
Moderator
How are you measuring at the front of the bed? Pic?
07-17-2020, 12:46 PM | #38 |
The rail and tape measure are pushed up against the edge of the bed.
07-17-2020, 01:01 PM | #39 |
Moderator
You definitely need some expansion room on each end but I would think 1/8" would be enough on each end.
07-17-2020, 02:58 PM | #40 |
Moderator
Yes, you leave room for expansion... and for drainage! I actually drilled two holes in the front corners of the wood for drains. The 67 up beds have drains added.
I know you are very concerned with costs here. Why not just grab some plywood, throw it in, bolt your original strips on top, and call it a day? |
07-17-2020, 03:19 PM | #41 | |
We'll see how it goes. I noticed MAR-K has a lot of help-files on their website. I printed them out today, now I have some reading to get to.
07-17-2020, 03:52 PM | #42 |
Moderator
Good work! Get cutting. Measure twice, lol
07-17-2020, 09:54 PM | #43 |
Measure three times! I had the tape measure sitting wrong on one of my boards and cut it about a 1/4 inch shorter than all the others... oops
Good luck on it!
07-17-2020, 10:10 PM | #44 |
The original bolts for the bed were splined. Anyone know if these splined bolts are still available? It seems all the new kits and rails have square holes.
Always some sort of road-block working on these old trucks.
07-18-2020, 04:04 AM | #45 |
Moderator
The only ones I found - https://www.ebay.com/itm/67-72-Chevy...ke%3AChevrolet
07-18-2020, 12:21 PM | #46 |
Well, I bit the bullet and just purchased some SS Polished rails and a set of hardware from the Car and Truck Shop in Orange. Saved a bunch of money in shipping too. Good thing they are so close to me.
And, better pricing than Brothers Truck Parts. $273 and I’m done; I just need to pick up stain and Polyurethane.
07-18-2020, 01:20 PM | #47 |
Moderator
And you'll probably get them faster if your shipping em.
07-18-2020, 01:42 PM | #48 |
I have them, drove over there this morning.
07-18-2020, 01:58 PM | #49 |
Moderator
Put those old strips up for sale, someone will need them.
07-18-2020, 02:14 PM | #50 |
Really? Ok.
I didn’t think anyone would want old ones except me.
