05-14-2018, 05:57 PM | #1 |
84' 3/4 lowered advice
I have a 1984 Chevy Scottsdale long bed 3/4 ton.. I want to lower my truck but not get crazy... I would think 5/7 would be too much. Whats a good compromise between height and function..
] : - 71' burb,5.3,4wd 02' f350.7.3 00' F250-powerstroke 00' Roadstar 84' Eagle model 10 72' GMC 18' camery 12' ZX14R- |
05-14-2018, 06:33 PM | #2 |
Re: 84' 3/4 lowered advice
Shackles and hangers with drop spindles. 2/4 drop. You can cut the springs later if you want lower.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
05-14-2018, 09:56 PM | #3 |
I am trying to find the best deal for those right now.... Thanks Im think on it..
05-14-2018, 10:01 PM | #4 |
Is it possible to do a 6inch drop in the back and not cut into my frame??
05-15-2018, 12:02 AM | #5 |
if you change your front brakes, you can run 1 ton dually spindles. wasnt sure if you knew that or not. That is how I lower my 3/4tons.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
05-15-2018, 09:48 AM | #6 |
You saying that would be cheaper... easier?
05-15-2018, 10:17 AM | #7 |
check the costs. If I remember right, when I did a c20, I looked at drop spindles for the c20 and the c30 were cheaper. I used BellTech. Just use c30 front calipers. Look up ball joints for both. I believe they are the same.
05-15-2018, 12:00 PM | #8 |
I lowered mine 6 in the rear by doing shackles/hangers and pulling the bottom 3 leafs. There was enough room without a notch at that point. POL makes drop spindles for the front.
05-15-2018, 07:21 PM | #9 |
I know doing it that way is alot cheaper would you say its a better ride then doing a 6 inch axle flip?? or about the same? what do you think..
05-15-2018, 08:54 PM | #10 | |
I didn't drive mine much with the lowered rear. I ended up tearing it apart to do more work to it and haven't driven it since.
05-15-2018, 09:37 PM | #11 | |
05-15-2018, 09:39 PM | #12 |
I dont think they would. I believe the perches are in different spots.
05-15-2018, 09:44 PM | #13 |
so what you saying i should do? lol
05-15-2018, 09:56 PM | #14 |
05-15-2018, 10:46 PM | #15 | |
05-16-2018, 12:02 AM | #16 |
Again, measure the width of the springs. Look at BellTechs website and see if they are the same as a 1t dually. If so, order the shackles and hangers.
05-16-2018, 10:31 AM | #17 |
ok sooo i looked at BellTechs website and they did not have any shachles o hangers for either a c20 or c30? so i went to IdCarid and found a BellTech 6907 4 inch drop shackle and hanger kit but its for a c30... so I just need to see if this will work.... its funny its a bigger deal with the back of the truck then the front.
05-16-2018, 01:26 PM | #18 |
For the rear, if you have a welder. You can get a new spring perch (axle tube) and weld it opposite of the current perch and your flip kit is done. At the same time you can weld a shock stud onto the ubolt bracket and your spring mount is done. This is what I did with one of my c10's and it worked nicely. Cost me maybe $20.
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
05-16-2018, 02:17 PM | #19 | |
05-16-2018, 02:24 PM | #20 |
Yep, just on the opposite side (bottom) of axle housing.
05-16-2018, 02:34 PM | #21 |
The link I posted should fit a C20. Click on the application tab.
05-16-2018, 03:47 PM | #22 | |
05-16-2018, 03:54 PM | #23 |
Like jrpontiac indicated, a flip-kit can be done on the cheap by adding (welding) new leaf mounting pads under the axle tube vs. on top & using fresh/new U-bolts/nuts (don't re-use U-bolt hardware; you can re-use the original plates). But, you'll get more than 6" of drop (closer to 8" depending on how thick the spring pack is). You would need to source the pads & U-bolts for the correct OD of your axle tubes.
The shackles/hangers will get you 4" drop. You could remove some leafs to play around w/additional drop. There is also another possibility that doesn't require welding but would require some modification (cutting, trimming, drilling, & measuring because you won't have specific instructions). You could use a 98-00 3/4 ton 8-lug flip/c-notch kit. They're similar in design. The axle tube OD should be the same (14bolt GM housings). The main difference is in the frame-rail profile but the 98-00 c-notch could be trimmed to fit where necessary.
05-16-2018, 04:30 PM | #24 |
that truck is badass! thanks
05-16-2018, 04:31 PM | #25 |
ok ill make sure i dont mess the pinion angle up..
