06-23-2019, 05:42 PM | #26 | |
Re: Bucket Seat Gas Tank Carpet
Regarding the "clips", can someone can provide all dimensions? Unfortunately, all but one of mine are still attached, but not used. I'd prefer to not remove everything to get at them. |
06-23-2019, 06:09 PM | #27 | |
I'm trying....
And just to be clear Jim, you want the dimensions of the oval brass rings-correct?
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
06-23-2019, 06:15 PM | #28 |
06-23-2019, 06:25 PM | #29 | |
Could be. This page from the assembly manual shows it in the driver side (#193) and apparently glues the carpet to the tank. My carpet fits very tightly into that gap and doesn't really need the adhesive. I also didn't glue it on the passenger side and will see if I can get a look for residue without damage within the next week. |
06-23-2019, 09:24 PM | #30 |
The Older Generation
The corner piece in my '68 CST is attached to a piece of heavy backer board shaped to fit in the corner. It is a separate piece. I will take some pictures of it tomorrow if it isn't raining cats & dogs.... LockDoc
06-24-2019, 07:43 AM | #31 | |
I'm trying....
I know exactly what you are talking about Leon. A pic would be great. I was with member SouthernParts yesterday and he had just that piece out of a 68. I don't know if Dirt's72's example is missing it or if there is a difference between 67-68 and the 69-72 (maybe buddy buckets vs. sport buckets). Maybe Jim can shed some more light when he checks his passenger side B pillar.
06-24-2019, 08:35 AM | #32 |
SWB 4x4 Collector
I can dig out my sets of the carpet retainer and take some measurements.
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
06-24-2019, 11:20 AM | #33 |
Thank You Brad for all your efforts to get us some proper carpet to put in out trucks. I wanted to add a few pics of observations I've come across. First is a measurement of the carpet clips from my 69.
Next is more pics from inside my truck where the carpet was glued. The driver side: More passenger side and not sure if this was just a repair to keep the carpet tucked in later some years after new or not? Ten years ago I removed original carpet from a 67 buddy bucket seat truck. I recall it had the backing that LockDoc mentioned but the carpet came out in peices. Heres the piece I belive was on the backing on the passenger side: |
06-24-2019, 11:27 AM | #34 |
Pictured are the screws I removed from the 67 with buddies that were used to hold up the carpet. There were no clips just these screws.
Recenty I removed some buddy bucket seats from a 68. The carpet was far gone but was just like the 67 carpet I removed. I retrieved what screws were there and they were different to the ones from the 67. They too did not have any clips. Last edited by Dirt's72; 06-24-2019 at 11:38 AM. Reason: Add more pictures |
06-24-2019, 12:28 PM | #35 | |
Incidentally, here's a link to a post I made in a recent thread about my method of fastening the carpet. http://67-72chevytrucks.com/vboard/s...12&postcount=3 It's more complete than the post I made that was referenced in post 19 above. Last edited by FirstOwner69; 06-24-2019 at 06:29 PM. |
06-24-2019, 08:04 PM | #36 |
I'm trying....
Derrick....thank you for donating your carpet to the cause! I think we might officially be able add tank carpet to the list of things that are different between MYs 67/8 and 69-72. Derrick do you think that the 67 carpet you removed was made in two pieces or just wore against the edge of the tank. I don't think it's a coincidence that SouthernParts had just that segment with the backing out of a 68. It was loose either because it was manufactured that way or because it's against a natural wear surface.
06-24-2019, 10:48 PM | #37 |
Here are the pictures of the corner carpet in my '68 Custom Sport Truck with Buddy Buckets. My tank carpet is identical to Dirt's72's carpet he posted. My battery went dead in my camera when I got to the main tank carpet. Mine also had the oval brass grommets. The cardboard backer on the corner carpet is between 3/32nds and 1/8th inch thick and stiff. The lighter colored area on the back was back in the corner and the dirty area was against the back of the cab. The notch in the top is where it transitioned from behind the inner cab panel to over it. This piece was separate from the tank carpet. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-24-2019 at 10:55 PM. |
06-25-2019, 08:51 AM | #38 |
Brad, when I removed that carpet from the 67 I thought it was just tore up from being close to fifty years old at the time and had no idea that it might have been two pieces. I was disappointed at the time because I wanted to keep it intact as one piece. I do recall that cardboard backing there on the passenger side and thought a previous owner must have put that in and thought it was just garbage.
06-25-2019, 09:06 AM | #39 |
I'm trying....
I texted with Woody (SouthernParts) and he confirms that the tank carpet in his buddy bucket truck was two separate pieces...it didn't break.
Also Derrick, in looking at the pics...it seems that the "tack strip" at the top of the 67 was a different material from the 69. And it looks like davepl's carpet didn't have a tack strip at all. EDIT: Do you think the tack strip in yours was added at the same time the zinc screws and washers were placed? Maybe the 69-72s had no tack strip at all.
06-25-2019, 12:32 PM | #40 | |
06-25-2019, 04:08 PM | #41 | |
I'm trying....
06-26-2019, 08:58 AM | #42 |
Brad yes I think that tack strip was added later. None of it was attached to the carpet in any way other that with the screws and washers. It all fell off and had no stitching or glue. I'm not including it with the carpet that I am shipping to ACC. I will be shipping that out today after work.
06-26-2019, 11:21 AM | #43 | |
I think the tack strip on your carpet was original so you should probably send it with the carpet.. Here are the pictures of my tank carpet with the same exact tack strip. The strip is stapled to the carpet and the staples are hard to see. In the 3rd picture you can see part of the original carpet ID tag that was fastened to the tack strip. (White arrow) I am sure I have the rest of the tag but was unable to locate it this morning. I am the second owner of this truck and pretty much everything is original on it. LockDoc
06-26-2019, 01:29 PM | #44 |
Leon I apologize for any confusion I was referring to the carpet that was specifically removed from my 69 chevy on post #26 and the carpet in post #16.
06-26-2019, 02:11 PM | #45 |
I'm trying....
Leon we're only working to replicate the 69-72 version at this time. (Because I've got a build going and I'm trying to make it happen for that truck). And frankly until we started this process I didn't even know there were two different carpet designs. I have no doubt that yours is original/correct with the tack strip. But I'm also fairly certain that 69-72 didn't have it. As Derrick noted, he's got pics of two different carpets in this thread. Once ACC has this one in hand, I will talk to them to see what options there might be for a 2 piece 67-68 version as well.
06-26-2019, 02:15 PM | #46 | |
OK, Sorry. I was referencing post #33, 34, & #42 where you were talking about the '67 & '68 carpet. LockDoc
06-26-2019, 02:18 PM | #47 | |
OK, I will leave my posts for now but if you want me to delete them so another thread can be started for the '67-'68 let me know. Thanks, Leon
06-26-2019, 02:23 PM | #48 |
I'm trying....
No reason to delete. Good conversation and collective discovery. I think it's better to consolidate info in one thread on this topic. Thanks for posting pics and helping out.
07-18-2019, 08:34 PM | #49 |
I'm trying....
I think we are far enough along in this process for a safe update. ACC received Dirt's72's factory '69 gas tank carpet. Their feedback was that to reproduce it well it needed to be a molded piece. After a bit of discussion, we agreed that we'd make a fiberglass mold of a gas tank and B pillars. We've got a '71 inflation fighter special that's been such a willing donor in other aspects of our build...that we went to it as our model for this. I figured that we should do it on a vent/return line truck. A molded carpet that fits 71-72 will fit previous years, but not vice versa. ACC said they should have some factory correct carpet for us in a couple of weeks. I'll post another update then.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 07-18-2019 at 10:04 PM. |
07-18-2019, 10:00 PM | #50 |
That looks great. They shouldn't have any problem with that. LockDoc
