07-18-2016, 08:48 PM | #26 |
Re: Anyone have this original in-bed spare tire carrier mounted?
Redline novdog, sorry nothing interesting stamped on the head of the bolt.
07-18-2016, 08:49 PM | #27 |
I haven't been able to find the correct nuts for the bolt or the mounting screws.
07-18-2016, 09:15 PM | #28 |
Wow Cericd, those photos are amazing.. bet there aren't too many of those OEM in-bed spare tire mounting bolts floating around at the dealers around the whole USA - especially with the GM part number sticker still on them.. very helpful though.. I might be able to find an equivalent at Fastenal now that I've seen that - for ten times the price..
Just a statement in general and on a related topic regarding these spare carriers - I do think there are two improvements needed: 1.) Locking feature - because even stock steelies are hard to find these days and if you have a brand new $125 balanced tire on your recently powdercoated spare steel wheel you don't wanna just go off and leave it sitting there in the bed tempting people. 2.) A quick release - to pop that spare off and on for cleaning or for loading large items in the bed. |
07-18-2016, 09:34 PM | #29 |
I was thinking about using some sort of locking lug nut when I install mine.
07-18-2016, 10:07 PM | #30 |
That's similar the one in the illustration. And bonus too, you helped locate another bolt for 67-72. That is, it's the right bolt for a carrier type for 67-72. This is the 399714. I found the part days ago, but the number doesn't come up on wiki for 71-72 on search, so wasn't able to confirm. Does anyone know if this nut and bolt is for the carrier on topic, and if so, how does it work?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-18-2016 at 10:34 PM. |
07-18-2016, 10:21 PM | #31 | |
I guesse I;m wrong about whether its monted inward or outward as shown in the fam. Mine has been mounted that way from new, Ditto for several others I have seen. |
07-18-2016, 10:24 PM | #32 |
Good, Glad to see my hardware chart clip made it here as it supports what I said about the carriage bolt. Being a pretty typical hardware store staple it should be easy to find one.
There are a number of questions running through the thread so I am just going to hit what I can without a lot of quotes. The spare rests on the floor, the illustration could be clearer in that regard. But the floor in fact is the primary load bearer. The simple fact the tire retention bolt slides freely in the slot should make that plain. The carrier mounts as shown in the drawing. Tucking under the upper lip, the lower end swoops outboard (away from the centerline) to pickup the fastener line along the edge of the bed floor. Since the wheel is retained with a lug nut, the provided wrench is all you need to tighten or loosen the wheel for installation or removal. The second back up nut... see post #71. If you want to lock it, you have two period options. A keyed spare tire lock with a special nut you tightened then a cover f keylocked to, to prevent theft. They were once common as dirt but I am sure years of neglect and lost keys have seriously reduced their number. The other of course is a chain (or cable) through the center hole around the carrier and one half of the wheel tire assembly. You could even do a full turn around the carrier if you wish. Since peple seem really hung up on hardware just use what you can and keep looking. Like I said above a hardware store carriage bolt and a lug nut will get you started.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-22-2018 at 12:05 PM. |
07-18-2016, 10:43 PM | #33 |
Good, Glad to see my hardware chart clip made it here as it supports what I said about the carriage bolt. Being a pretty typical hardware store staple it should be easy to find one. That's what I was thinking.
Since peple seem really hung up on hardware just use what you can and keep looking. Like I said above a hardware store carriage bolt and a pair of lug nuts will get you started just add a washer behind the wheel. Washer between the bracket and wheel?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-18-2016, 10:43 PM | #34 |
If you look above on the parts clip, that part number is used on the Suburban which used an inside mounted spare. It was also apparently used on Blazers. They had several different mounts including screwing it flat to the floor! As far as I know that wing nut/bolt has no place on a fleetside P13 carrier.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-18-2016, 10:46 PM | #35 |
Thanks for the additional info Tim. I should have known I saved that pic from one of your posts. You're always quick to respond with great info on the specifics of these trucks.
07-18-2016, 10:50 PM | #36 |
Not to hijack, but does anyone have pics of their truck with the spare tire mounted in the bed using one of these?
07-18-2016, 11:10 PM | #37 | |
I would add a thick washer between the back up nut and the wheel to reduce point bending loads on the wheel. No point in messing up a wheel.
07-18-2016, 11:14 PM | #38 | |
I should have done a shout out there. Help when I can but now is not a good time with my kids howling for their dinner. Later..... :-)
07-18-2016, 11:26 PM | #39 |
If I understand you right, Suburban had a service 10? Didn't know that, I thought that was marked for a c-10, course it doesn't say fleetside etc like the 1023, which doesn't show for 1971, but it's likely correct anyway. Fun!
Here's the 1022, which shows for 69-72 service 10-30. Couldn't tell you what it's for, but I bet it works. Manual says cut to fit.: http://shop.docrebuild.com/1955-1991...GM3991022.aspx Edit, I found this illustration for a 1022. http://www.discontinuedspares.com/in...ucts_id=435385
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-18-2016 at 11:42 PM. |
07-19-2016, 05:54 AM | #40 |
I agree! Can't believe nobody has the factory wheel bolt & nut. I have a 71 with this option- but no bolt or nut
07-19-2016, 09:03 AM | #41 |
subscribed.
07-19-2016, 10:53 AM | #42 |
I'd be interested to see pics of the wheel in the bed on our trucks too. I moved to an under the bed gas tank so I carry no spare right now. Would be nice to have one just in case but not sure about the look.
Here is a spare tire mount thread for the 58-59 fleetsides on this site: http://67-72chevytrucks.com/vboard/s...d.php?t=606556
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
07-19-2016, 10:59 AM | #43 |
Google image search results.
If you want to hack up your bed...
07-19-2016, 11:43 AM | #44 |
OH I like the sunken deal there. Is that just an upside down wheel tub? My small spare does come up a bit past the bedside. Not real pretty but stuck on the side of the road is uglier.
When I got in an accident and my spare tire was just loose in the back of the Blazer it took out my passenger seat. Luckily no one was sitting there or they would have been hurt. All the crup in the back of the truck was strewn across the highway as I spun to a stop. I no longer carry anything but that spare in the bed of my pickup unless it is strapped down good and have a bed toolbox for my jack and such. The tire rests on the bed and wheel tub. Not sure it would hold up in an accident. But it does keep the tire out of the way.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-19-2016, 11:44 AM | #45 |
Pics I have found here in the forum.
07-19-2016, 05:52 PM | #46 |
We pretty well beat this to death and thanks to all for the information. Especially the walking GM encyclopedia in SS. Still curious if the top and bottom screws differ, and if anyone believes this is an original bolt for the carrier. It may be for carrier under the bed. It's definitely a 67-72 serv 10-30 part.
07-19-2016, 07:35 PM | #47 |
that origonal bolt... a carrige bolt... is what Gm called for. I got almost exactly the same bolt from ACE. same threads as a lug nut for a half ton. interesting that it calls for two of them. maybe three or even six for my 72c10. with my luck. interetsting
07-19-2016, 09:31 PM | #48 |
07-20-2016, 10:05 PM | #49 |
Makes sense they'd reuse the bed bolts for the bottom. That carrier looks awfully close to the wheel housing, but if I recall, mine was the same and likely factory. Apparently the tire rests a tad against the wheel housing?
07-20-2016, 10:29 PM | #50 |
Holy crap 100% Chevy - those photos are end of story as far as the in-bed spare topic.
In my own mind I am a better man for having seen those pictures, no joke. Thanks for posting and will be interested to see if anyone can top your post with that original SPID and photo of the factory installation. I had a funny (to me anyway) thought - where someone installs four (4) spare carriers in each of the four corners of their bed; and puts a fifth one under the bed... rolling with five spares - take that triple A! |
