Old 02-28-2016, 08:28 AM   #76
Advanced Design
Advanced Design's Avatar
Re: Great Grandads '53 3100
Nice progress, looking really good!
Advanced Design is offline   Reply With Quote
Old 02-28-2016, 02:13 PM   #77
iowaboynca
iowaboynca's Avatar
Did you need another u joint down by the rack or were you able to get away with the 2 pictured?
Thanks!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-28-2016, 11:50 PM   #78
Tesone
Thanks!
Yes sir. There's a 3rd down on the rack. Unfortunately I'm going to have to weld that one to the shaft as the set screw was hitting the motor mount.
Tesone is offline   Reply With Quote
Old 03-07-2016, 08:15 PM   #79
Tesone
Took a couple days off work and spent a long weekend on the truck. Got my fuel lines run, wiring harness finished up, new battery box mounted and most important of all. . .
http://vid469.photobucket.com/albums...01F12A51B4.mp4
Had a little help from Molly "the not so shop dog"
Old 03-07-2016, 08:34 PM   #80
Advanced Design
Congratulations, sounds good!
Old 03-07-2016, 10:11 PM   #81
joedoh
joedoh's Avatar
why is the video named "bent valves"? sounds healthy!
Old 03-07-2016, 10:18 PM   #82
jeff.d
that thing fired up in a hurry! very cool build!
jeff.d is offline   Reply With Quote
Old 03-07-2016, 10:26 PM   #83
Tesone
Ha! Well "20BentValves" is my username for Photobucket. It came from back in my VW days when I blew up my 20 valve turbo motor. That's just part of the URL i guess.
From what I can tell the 5.3 is nice and healthy, but then again its so dang loud I cant hear anything.
Old 03-07-2016, 10:29 PM   #84
Tesone
Right?! it was that good from the first time I hit the key too. Couldn't be happier.
Old 12-05-2016, 01:47 AM   #85
Tesone
First update in several months. That being said I've still been working on the truck quite a bit. I've been keeping my instagram page current so feel free to request to follow me if you'd like to follow along. My username is stesone11
This is fairly abbreviated so forgive me. After I got the engine running, I got the the ECM and Throttle control box mounted under the dash. Managed to get it done reusing some parts from the fuel tank straps.
From there i moved on to mocking up the bed.
And discovered I would indeed need to add some tubs.
Built the tubs from a trailer fender. It was a single fender I split in half and narrowed a bit and filled in with sheet metal.
and got them welded into the bed
From there I moved on to building the frame for the bed floor. The floor will tilt up to access the fuel tank and allow you to see into the chassis. One of my main objectives was to keep the floor near the stock height and I was able to come within 2 inches of that.
From there I moved on to filling the stake pockets, plug welding all the holes in the bed and filling the ends of the bed rails
That wrapped up the fab work on the bed so from there I moved onto repairing some rust on the front fenders.
First the drivers side
Then the passengers side. For this one I was able to drill out the spot welds and remove the inner piece
Today I spent the better part of 9 hours stripping sheet metal hoping to have some primer on them here soon.
Old 12-05-2016, 10:35 AM   #86
oldman3
oldman3's Avatar
Nice update, doing some great work...Jim
oldman3 is offline   Reply With Quote
Old 12-05-2016, 11:16 AM   #87
iowaboynca
iowaboynca's Avatar
Nice progress!
Old 12-07-2016, 03:19 PM   #88
69CST-V
69CST-V's Avatar
Nice work....some big hurdles being over come here.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 07-19-2017, 10:48 PM   #89
DueWest
updates?
DueWest is offline   Reply With Quote
Old 01-01-2018, 12:10 AM   #90
Tesone
Lots of work completed since the last update. I'll let the pictures speak for themselves. Happy New Years guys!
Heres a little then and now with 2 years in between.
Old 01-01-2018, 09:14 AM   #91
Advanced Design
Nice update! Truck is looking good. Thanks for sharing.
Old 01-01-2018, 01:38 PM   #92
fisherman420
Wow great work! You've definitely made my new years resolution to finish my 50
My 1950 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=720858
fisherman420 is offline   Reply With Quote
Old 01-01-2018, 08:21 PM   #93
oldman3
oldman3's Avatar
Looking super, nice job...Jim
Old 01-01-2018, 08:39 PM   #94
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Very nice!
ChuckDriver is offline   Reply With Quote
Old 01-02-2018, 09:56 AM   #95
SalvagedSouls
SalvagedSouls's Avatar
Nice work!
Looks awesome - I like the seat.
1949 - 3600 Update suspension, engine and drive it.
http://67-72chevytrucks.com/vboard/s...d.php?t=691034
1953 - 3100
1955.1 - 3100 Bare Metal Build
http://67-72chevytrucks.com/vboard/s...d.php?t=691261
1965 - Buick Special & 1965 Buick Skylark
SalvagedSouls is offline   Reply With Quote
Old 01-02-2018, 12:39 PM   #96
joedoh
joedoh's Avatar
looking very nice!
Old 01-03-2018, 07:59 PM   #97
Desert1957
Desert1957's Avatar
Can't wait to see this one finished , Nice work..
Desert
Desert1957 is offline   Reply With Quote
Old 01-04-2018, 09:34 AM   #98
Mains52
That thing is sick!! I spent too much time looking at pictures and didn't read it all. Did you have your Control Arms Powder coated?
Mains52 is offline   Reply With Quote
Old 01-05-2018, 11:29 PM   #99
gigamanx
Looks like you and I are running the same wheels. I had the same tiny bit of tire on the bed side. I used 3" spacers to get the tire out as far as possible, but I still need tubs. They look like the fenders I've seen at Tractor Supply. Thinking of getting one of those myself and cutting them down to size.
Curious to know about your front wheel and tire size? I have 18" Riddlers with 4.5" backspacing for the front. I haven't checked to see what tire size I need, but yours look pretty darn close.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
