02-21-2020, 12:03 AM | #26 |
The Older Generation
Re: Fan switch problems, Please help!!
Is there a ground wire from the blower motor housing to the screw that holds the heater box to the firewall? (short black wire in picture) LockDoc
02-21-2020, 08:49 AM | #27 | |||
Old member
The AC trucks have a few more parts to them. The fuse has to be swapped as well. This link shows the heater only schematic not the AC. It is a great schematic and I refer to it often. http://67-72chevytrucks.com/vboard/s...185856&page=16 I use the breaker fuse instead of the normal 25 amp fuse. It will heat up and kick off then cool down and come back on. You need to get power to the switch first though. You stated in your last post you have the AC back running. Quote:
Also you said Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-22-2020, 04:55 AM | #28 |
I might just buy another fan switch and install it, even though you can hear the air con click when you flick the switch to low and medium, it might be the problem.
02-22-2020, 04:56 AM | #29 |
02-22-2020, 05:03 AM | #30 | |
And when I flick the fan switch to low or medium it doesn’t work but you can hear the aircon click in , so I’m hoping it’s a crap switch now on medium and low, high works fine. The auto electrician said the switch is fine, Don’t believe him yet. Stay tuned ....... |
02-22-2020, 07:22 AM | #31 |
Old member
The wires that you found off the push button on the back side is the compressor switch. The bottom cable on the controller has to be set for AC which you know and the wires must be connected.
Now with both of these in the right positions the AC should work. By your last statement you don't have low are medium fan speed correct? Take a close look at the wiring on the switch. I would just about bet it's not correct.
02-22-2020, 07:33 AM | #32 | |
It worked when I first bought the truck now and then but ALWAYS worked on hi ......correct , no medium or low. |
02-22-2020, 08:14 AM | #33 |
Old member
It looks like you need to swap the light blue and yellow wires.
Mine is on the left yours is the right side. Due to our wires not being all the same you may need to just try different combination's and see. I added my AC to this truck so the brown wire is my orange wire. I did this 30 some years ago.
02-22-2020, 10:05 PM | #34 | |
02-23-2020, 12:27 PM | #35 |
Old member
Ok this should help and clear up the wiring colors and where they go.
Looking at our pictures. Bottom terminal should be the brown wire are the hot feed wire. Next up from it should be Yellow for low speed Then beside the yellow is the Light Blue for medium speed. Then on top the orange wire for high speed. Now if you look at yours you have the 2 yellow wires going to the same place. This I think is one of the problem's on yours. You also show no orange wire and the light blue are in the wrong spots.
02-23-2020, 06:53 PM | #36 | |
03-11-2020, 09:18 PM | #37 | |
03-12-2020, 08:23 AM | #38 |
Old member
Man you did get pissed!
Glad you figured it out though! Thanks for letting us know!
03-12-2020, 10:22 AM | #39 |
03-12-2020, 07:19 PM | #40 |
Well I had to fix 5 problems when I bought it.... now it’s someone else’s turn. Fan still works anyway.... I’m chasing a short bed .... long beds to long for me, and it was a bit to good to throw things in the back of it .
