Old 02-21-2017, 09:53 PM   #1
gmc1971harwich
gmc1971harwich's Avatar
What size lift kit does my jimmy have? Any help
I just bought a 72 gmc jimmy with 1 ton axles and suspension is the front end on each side is 31inches from center of hub to top of wheel wheel arch and the rear on each side is 28" from center of hub to top of center of wheel arch. Can anybody tell me what size lift kit I have? I have 37 inch military surplus tires and 16 inch rims. I would like to lower the truck a little.
gmc1971harwich is offline   Reply With Quote
Old 02-21-2017, 10:09 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: What size lift kit does my jimmy have? Any help
if there are lift blocks on the rear then just measure the blocks
69chevytrucker is offline   Reply With Quote
Old 02-21-2017, 11:26 PM   #3
gmc1971harwich
I think most of the lift was done with shackles and leaf spring perches here's some pics it has a shackle flip kit
Old 02-22-2017, 07:42 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
The front spring perches look like B52 from diy4x
http://diy4x.com/product.php?product...cat=250&page=1
Rich
1972 K5 Blazer CST Click HERE
Old 02-22-2017, 11:10 PM   #5
13jraven
13jraven's Avatar
If you are going to ask, at least right side up your pictures.
Did someone cut the whee openings?
How long are the front and rear shackles?
How long are your front and rear leaves?
The front looks like a B52 kit but it is on the rear most hole so those aren't 52" springs.
http://diy4x.com/product.php?productid=17716
The rears look like 4.5" shackles with DIY4x rear shackle flip.
http://diy4x.com/product.php?product...cat=250&page=3
The front and rear don't look they are zero rated but one ton axles will add about 3/4" to your overall height.
I would guess at least ~7" of lift to clear those 37" unless those fenders are trimmed up.
And if you ask me how I know, I recently installed a B52 and shackle flip in a 69 blazer on 1 tons.
13
13jraven is offline   Reply With Quote
Old 04-02-2017, 03:06 PM   #6
gmc1971harwich
Yea it does have the b52 kit I will have to measure the springs are they measured from eyehole to eyehole? No the fenders were never trimmed
Old 04-02-2017, 03:07 PM   #7
gmc1971harwich
Also anybody know how to flip the pics around these were right side up on my phone when I took them
Old 04-02-2017, 03:16 PM   #8
gmc1971harwich
Measurement on both front and rear springs along surface from front eyehole to center bolt is 26"
