12-05-2019, 12:52 PM | #1 |
Motorhome BBC oilpan will it fit?
Do you know if the motorhome 8 quart oil pan will fit our trucks 71 model ?
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
12-05-2019, 04:58 PM | #2 |
Re: Motorhome BBC oilpan will it fit?
I don’t know but there’s a thread on hotrodders right now about oil pans.
https://www.hotrodders.com/forum/ext...bc-524021.html |
12-05-2019, 07:56 PM | #3 |
I have my doubts, because the 6qt I had for my L31 had to be traded out for a 5 qt in order to clear the front crossmember on my K5. I know it's apples to oranges, but my point is that there doesn't seem to be a lot of room there.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-06-2019, 12:44 PM | #4 |
Yep, but it's tight. Have one on my 69 flat bed
I just remembered that I had to get a long pick-up tube for the added depth Last edited by kwmech; 12-06-2019 at 10:31 PM. |
12-06-2019, 02:01 PM | #5 |
Moderator
Ya sure it will fit
12-07-2019, 01:09 AM | #6 |
OK. So I have a IDK; A sure it will fit with a laughing smiley face; and a yea;but its tight. Health issues keep me from crawling under the lowered thing right now.That is why I asked. Thanks.Mabey someone with a build thread photo could help.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished Last edited by 71cheyennesuperlongb; 12-07-2019 at 11:03 AM. Reason: Old Fart 64 yrs |
12-07-2019, 10:24 PM | #7 |
60-66 Nut
I don't have a definitive answer for you but I am familiar with that oil pan and couple things to consider. 1) In what position is your engine mounted? Stock SBC or '68-'71 BBC location? 2)Are you going to be installing an auto trans at the same time or after the engine is in place? 3) Or are you installing a manual trans?
12-08-2019, 10:52 AM | #8 |
I don’t have a definitive answer for you, either. But I did put a 454 from an RV in my ‘66 C20 and it fit fine. I had swapped the crossmember out for a ‘79 3/4 ton front crossmember.
12-11-2019, 01:00 PM | #9 |
Thanks for your reply CAPTAINFAB.The engine is on a stand in garage.Just bought it,you know all that fresh rebuilt stuff.I had to pull pan to see for myself. Did not want to reinstall pan if it wont fit.Will be 400 turbo.I read where you recomend smallblock stands and mounts with balancer washers under the center bolt.I would like to put the engine as far back as possible,as against the firewall.I know my driveshaft wont work,700R now.Thanks for your help.
12-11-2019, 10:20 PM | #10 |
60-66 Nut
For a big block I typically recommend either the '68-'71 BB mounts or the '73-'87 brackets and mounts for a BB.
