Old 06-12-2018, 10:41 AM   #676
lowslow64
lowslow64's Avatar
Re: What did you do to your truck today part IV
This fiberglass dash for 60-66 C10 was purchased from US Body Source. Around $300 bucks plus shipping of $150. Took 8 weeks to receive it and comes very very rough. It needed a lot of work fitting and smoothing to get ready for paint. When it is all done I think it will be awesome, but if I had to do again for the price and work, probably not. Probably just weld on the original.
lowslow64 is offline   Reply With Quote
Old 06-16-2018, 12:58 AM   #677
TJ's Chevy
TJ's Chevy's Avatar
Installed the mid shift kit on the tremec this evening. Now the shifter won't be under the cab floor anymore.
Old 06-16-2018, 11:58 PM   #678
TJ's Chevy
TJ's Chevy's Avatar
Got the trans installed and both inner fenders painted.
Old 06-18-2018, 08:08 AM   #679
highwinger
highwinger's Avatar
Had my front fender, hood, grill, bumper and headlight straightened. First time I've ever seen one of these awesome machines work. It was fun watching a pro work and move it all back to its proper place, or at least close enough.
highwinger is offline   Reply With Quote
Old 06-18-2018, 10:08 AM   #680
Backpayne
Getting closer and closer...
Backpayne is offline   Reply With Quote
Old 06-20-2018, 12:50 AM   #681
allchevy58
allchevy58's Avatar
Finished up the bed last weekend, new headache rack, mud flaps and painted with POR-15, installed toolbox. One headlight was held in with the bezel, broken headlamp adjusters and rivots broke between grill and mounting bracket. Time to put used grill on I had bought. Finished that tonight.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 06-22-2018, 09:36 PM   #682
cwcarpenter98
cwcarpenter98's Avatar
Today I wired up the electric choke, and added on a little somethin that my buddy found when someone dropped of a donation to his dad's ministry. Maybe tomorrow Frankentruck will come to life again?
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 06-25-2018, 02:32 AM   #683
mfm3
stick on CHEVROLET
mfm3 is offline   Reply With Quote
Old 06-28-2018, 12:03 AM   #684
'65 chevy lover
Got more done this past weekend. The steering was jacked up because of the lower bearing in the steering column was worn out. It was one of the original bearings without sides or grease in it. We replaced it with one of the good, heavy duty bearings that should last a long time. We did have to weld on the steering shaft to fill in where the bad bearing had ground a groove in the shaft and then grind it smooth of course. Now the steering feels nice and tight without any slop. Along with that, we cut off the gear selector mounting lug and, removed the gear indicator, filled up the holes with bondo, sanded and painted it to make it a floor shift steering column. Then, we fitted a sheet metal patch that I purchased from LMC, in the hole on the left side of the cab where the old fuel filler was located. After grinding it down, putting on some bondo, sanding that down, we slapped on a couple coats of good primer. Next weekend, we're gonna finish the exhaust. Amoung the things left to do is, installing a tach, installing a horn, lining up the body panels and, doing a little touch up painting. I'm not going to do a full new paint job. Besides not having the money for that, I'd rather it have a rat rod type paint job. It's gettin there!!
'65 chevy lover is offline   Reply With Quote
Old 06-30-2018, 01:45 PM   #685
msgtmac
[attach]Name:  20180629_190803.jpg
Size:  34.4 KB[/attach]
Assembled front end
msgtmac is offline   Reply With Quote
Old 07-01-2018, 12:28 AM   #686
forestb
forestb's Avatar
Did a little more work on my guage cluster today. The little bow ties have chrome behind them and the bezel is going to be chrome.
forestb is offline   Reply With Quote
Old 07-03-2018, 05:57 PM   #687
Robert Haas
mocked up the firewall,
Robert Haas is offline   Reply With Quote
Old 07-04-2018, 08:35 AM   #688
msgtmac
I see you have the Clifford intake and headers. Did you do anything to the motor, ie cam head ect. or is it stock?
Old 07-04-2018, 12:18 PM   #689
The Rocknrod
Moderator
The Rocknrod's Avatar
I dont have a clifford intake...
Old 07-04-2018, 12:19 PM   #690
Backpayne
How do you like that steering wheel? I've been eyeing that same one for awhile.
Old 07-04-2018, 04:49 PM   #691
60short
60short's Avatar
CLR and red scotchbright by Keith, on Flickrtried the CLR and scotchbright thingy :
worked like a charm
60short is online now   Reply With Quote
Old 07-04-2018, 08:37 PM   #692
hambone61
hambone61's Avatar
I think he's referencing Ken Cook in post #657.
hambone61 is offline   Reply With Quote
Old 07-04-2018, 10:06 PM   #693
62chevy302
hillbilly
62chevy302's Avatar
Epoxy primed my inner fenders
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 07-05-2018, 05:36 AM   #694
msgtmac
Had 4 cars come to the Car Care Barn in need of help so front brakes and the axle install is all I got done this weekend.[ATTACH]Name:  hub2.jpg
Size:  102.8 KB[/ATTACH]
Old 07-07-2018, 05:54 PM   #695
made2drag
made2drag's Avatar
great thread!
made2drag is offline   Reply With Quote
Old 07-07-2018, 09:00 PM   #696
Clyde65
Clyde65's Avatar
A little sound/heat shield!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-08-2018, 02:32 PM   #697
vin63
It's Better With Nitro
vin63's Avatar
Windshield is in and bed back on...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-09-2018, 02:47 PM   #698
lowslow64
lowslow64's Avatar
I like the wheel so far, going from a stock custom wheel to this, should be rather different. Haven't had to chance to drive it yet, but give me a few weeks.
Old 07-09-2018, 03:00 PM   #699
forestb
forestb's Avatar
Was it vary hard getting the window in with the trim. I used Steel Rubber for the gasket and the glass guy had a real hard time getting it in. What brand did you use?
Your truck looks awesome by the way.
Old 07-09-2018, 05:50 PM   #700
vin63
vin63's Avatar
Thanks! I used Precision glass seals throughout, including the front windshield (back glass, vent windows, door channels, etc.). It took me a couple of hours with the help of a friend. I've had really good luck with Precision on the curved glass applications. I had good experiences with Steele on flat glass windshields in the past when they were the only premium seal maker around...not so much on the curved windshields recently.
