02-05-2017, 04:31 PM | #351 |
Re: Plus Five
not a great picture, but this one better shows the angle that
it leans back....
53 Chevy Pickup |
02-05-2017, 06:40 PM | #352 |
Re: Plus Five
Do you have a fuel pressure gauge, that should tell you if your system is sealed.
Just cycle the key/power a few times you will know quickly is your fuel system is tight!
02-06-2017, 06:47 AM | #353 | |
Re: Plus Five
I'll probably just crank it up outside. If I do have a leak it won't end up on my floor. I HATE the smell of gasoline!
53 Chevy Pickup |
02-06-2017, 09:02 PM | #354 |
Re: Plus Five
"I HATE the smell of Gasoline"
Use race gas, that is what I plan to use
1950 3100 5 window |
02-07-2017, 02:18 PM | #355 |
Re: Plus Five
It's raining and cold outside so I did some more work on
the cover panels. I cut out the vent panels and used round head rivets to rivet a piece of perforated aluminum to the back side.
53 Chevy Pickup |
02-07-2017, 05:08 PM | #356 |
Re: Plus Five
Very cool. I love the industrial look of the mesh.
Nicely done. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-07-2017, 05:14 PM | #357 |
Formerly- 1972SuperCheyenne
Re: Plus Five
Agreed, that's awesome
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-07-2017, 07:40 PM | #358 |
Re: Plus Five
Thanks everyone,
I'm planning on just painting it the satin color of the dash. I'm trying to keep some of that plain old metal feel in the cab.
53 Chevy Pickup |
02-10-2017, 03:46 PM | #359 |
Re: Plus Five
I spent a good part of the day putting in some sound
proofing and insulation behind the seat enclosure. I also finished up the two side panels. They will hold the 6 x 9 speakers. Just need to cut the holes and install the last rivnuts.
53 Chevy Pickup |
02-10-2017, 03:51 PM | #360 |
Re: Plus Five
I bent the aluminum over a 1 inch pipe by hand.
I used some thick paper for a pattern, then filed them to fit.
53 Chevy Pickup |
02-10-2017, 04:11 PM | #361 |
Re: Plus Five
the gaps around the corners are pretty tight, just magic marker
on the tape that looks like too big of a gap. I should finish this up tomorrow.
53 Chevy Pickup |
02-10-2017, 05:11 PM | #362 |
Re: Plus Five
That is clean..
02-11-2017, 07:12 AM | #363 |
Re: Plus Five
Really nice!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
02-11-2017, 03:34 PM | #364 |
Re: Plus Five
I finished up the Radio speaker enclosure.
6 X 9 just fit with a foam baffle behind them. Hope it sounds OK. Next up, I think I'll put the tweeters in the headliner.
53 Chevy Pickup |
02-20-2017, 07:57 PM | #365 |
Re: Plus Five
I finished up the stereo install.
I had previously made a three piece aluminum headliner and I put the tweeters in the side panels.
53 Chevy Pickup |
02-20-2017, 08:02 PM | #366 |
Re: Plus Five
I also bled the brakes and got the truck back on
it's wheels. It may be a bit high sitting yet, but I'll wait til I get the stainless steel box floor and a tank of gas in it, before I adjust the ride height.
53 Chevy Pickup |
02-20-2017, 08:32 PM | #367 |
Re: Plus Five
Coming along nicely...as usual
02-21-2017, 06:02 PM | #368 |
Re: Plus Five
03-02-2017, 02:49 PM | #369 |
Re: Plus Five
thanks to MIKESAD50 for showing his tool for
installing the door weather strip. I made some similar tools from an old plastic cutting board and installed mine. I also installed the lower trim and stainless steel retainer that I made earlier. I'll peel the paper off later. I'm going to wait for good weather to start the engine. We got snow today in western New York.
53 Chevy Pickup |
03-17-2017, 02:34 PM | #370 |
Re: Plus Five
I'm still waiting for warm weather to fire up the engine, we got about
10 inches of snow. In the mean time, I made the final pieces for the inner fenders up front. They are made from .060 aluminum and will be powder coated with black wrinkle finish to match the air intake. Hopefully they will stop most of the road debris from hitting the fender and denting or chipping them. Also the powder coat wrinkle finish should hold up to the abuse from leaning against it or setting tools on them and won't show finger prints or dirt.
53 Chevy Pickup |
03-17-2017, 02:38 PM | #371 |
Re: Plus Five
starting to look like a truck again...
53 Chevy Pickup |
03-17-2017, 03:32 PM | #372 |
Re: Plus Five
Amazing work as usual. Keep at it!
03-17-2017, 07:55 PM | #373 |
Re: Plus Five
Sweeeeeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-20-2017, 06:08 PM | #374 |
Re: Plus Five
Today I installed the headliner panels.
I put sound deadening and insulation on the roof skin and on the back side of the headliner panel. I also cut a small hole for the microphone for the blue tooth up front just above the mirror. The dome light is from a Subaru and is wired like new cars to the door switch or manual on.
53 Chevy Pickup |
03-20-2017, 06:15 PM | #375 |
Re: Plus Five
That turned out great, what material did you use for the headliner?
