Old 03-13-2018, 02:47 PM   #1
MHeffeGMC71
Unhappy Truck wonders
Morning all, well my question is what do I need to add rack and pinion to my truck. I did a LS 6.0 swap in my truck and want it to be more user friendly when I drive. I replaced all the suspension back to factory new. But the truck still wonders and has bump steer when I let off the gas. Thanks
MHeffeGMC71 is offline   Reply With Quote
Old 03-13-2018, 03:09 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Truck wonders
Your problem might be because your center link is installed backwards. The nuts on the joints should be facing forward. That changes everything....
LockDoc
Leon
Old 03-13-2018, 03:41 PM   #3
demian5
demian5's Avatar
Re: Truck wonders
Originally Posted by LockDoc View Post
Your problem might be because your center link is installed backwards.....
LockDoc
See above
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-13-2018, 04:22 PM   #4
KevinR
Re: Truck wonders
I am in the midst of a bolt in install from Flaming River. I will update you on any difference in driveability. Also, I can’t speak to fitment with an LS. I am installing with a 250 L6 and will require a roughly 1/2 in motor mount lift.
Kevin
KevinR is offline   Reply With Quote
Old 03-13-2018, 04:28 PM   #5
LockDoc
LockDoc's Avatar
Re: Truck wonders
Originally Posted by demian5 View Post
See above
Not understanding what you mean....
He said his truck "still wanders and has bump steer when I let off the gas" and I said the problem might be because his center link is installed backwards, which it is, and which could cause the problems he is seeing. He may not need to go to the trouble and expense of installing a rack if correcting that regains his "driver friendliness"
Cryptic posts don't add anything to the thread.
LockDoc
Leon
Old 03-13-2018, 05:12 PM   #6
demian5
demian5's Avatar
Re: Truck wonders
LockDoc
x2
Is that better? LOL!
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-13-2018, 05:28 PM   #7
weq92f
Re: Truck wonders
It's a wOnder the truck doesn't wAnder with that thang thataway.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-13-2018, 05:38 PM   #8
harpo231
harpo231's Avatar
Re: Truck wonders
see above = what Doc said or x2
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-13-2018, 05:45 PM   #9
clay68c10
clay68c10's Avatar
Re: Truck wonders
Flip that center link and save a few bucks! With everything new it should drive pretty well.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-13-2018, 06:57 PM   #10
LockDoc
LockDoc's Avatar
Re: Truck wonders
x2
Much better. Thanks.
LockDoc
Leon
Old 03-13-2018, 07:42 PM   #11
MHeffeGMC71
Re: Truck wonders
First off thanks for all the helpful replies. I just came from my new mechanic who's going to switch it around for me we'll see if that solves the problem.
Take a sec to enjoy how far I've come from when I first got this suspension redone on this truck true craftsmanship
Old 03-13-2018, 08:23 PM   #12
HO455
HO455's Avatar
Re: Truck wonders
Yup, don't see that everyday. Reminds me of the Burban I looked at buying that had the springs removed to lower it.
Good job on cleaning that mess up.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 03-13-2018, 09:07 PM   #13
LockDoc
LockDoc's Avatar
Re: Truck wonders
Good deal. Keep us up to speed on the outcome.
LockDoc
Leon
Old 03-13-2018, 10:14 PM   #14
superhondaz50
superhondaz50's Avatar
Re: Truck wonders
Ok well ****, now I just realized my centerlink is on backwards. More work for me. Yay.
superhondaz50 is offline   Reply With Quote
Old 03-14-2018, 11:34 AM   #15
superhondaz50
Re: Truck wonders
Any advice on removing the pitman arm and idler arm from the centerlink without ruining my brand new parts and dust boots?
Old 03-14-2018, 11:39 AM   #16
AK49Watson
Re: Truck wonders
Use the right tools. Pickle fork or ball joint remover. They're brand new, shouldn't be hard to remove.
1970 GMC C2500, Vortec 406SBC, TH350
AK49Watson is offline   Reply With Quote
Old 03-14-2018, 12:49 PM   #17
randy500
Re: Truck wonders
To try to save the boots I would use an air chisel. I would pad it with brass or aluminum and hammer on the threaded end of the pitman and idler arm. Do the same on the tie rod end if you can get to it.
Or, use the pickle fork as a pry bar while using the air chisel on the tie rod arm. Try to not let the pickle fork contact the rubber with this method.
Lastly you could put force pulling the tapered joint(tie rod, Idler, pitman) while hitting the side of the female taper with a large hammer.
randy500 is offline   Reply With Quote
Old 03-14-2018, 01:12 PM   #18
leddzepp
Moderator
leddzepp's Avatar
Re: Truck wonders
You need a puller for the pitman arm. Local autozone loans the tool for free. You can also buy it at harbor freight for about $8. Smack the side of the centerlink with a sledgehammer to remove the idler arm, it should pop right out since it’s new. I use a pickle fork on old stuff that’s coming out to be replaced, where damage to the rubber boot doesn’t matter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 03-14-2018, 01:30 PM   #19
superhondaz50
Re: Truck wonders
Ok cool. I have a pitman puller, but wasn't planning to pull the pitman arm off the gearbox.
Was thinking:
Unscrew each tierod connector, leave the tie rods on the centerlink. Then remove the centerlink from the idler and pitman (tapered side). Then flip it 180. That'd put the tierod bolts frontwards.
I can prob make a brass rod to fit into my air chisel. Since they're new, make just smacking the centerlink with a dead blow hammer would free it? IDK, just don't wanna ruin $100 worth of new Moog parts.
Old 03-14-2018, 04:39 PM   #20
randy500
Re: Truck wonders
Hitting it will knock the tapered joint loose but hitting it without pressure pulling it outwards will probably not do anything. They also make a screw type tie rod puller which may fit the idler and pitman arm, I'm just not sure of the fit, they usually don't fit well. If you can borrow one at oreillys or autozone it would be worth a try.
I suspect you have a recent alignment....you could save that alignment by measuring the toe in before you change the parts out and then adjusting to the same spec after the switch.
To replicate the toe in, roll the tires over 2 layers of plastic sheeting, thick black garbage bag pieces(reduces friction of tire on the ground), wire a board across each tire through the wheels, measure the distance front and rear of the tire using the boards, subtract front from rear distance to get current toe in.
Adjust each side equally to replicate this distance once you switch the parts out.
Old 03-14-2018, 06:19 PM   #21
superhondaz50
Re: Truck wonders
Hasn't been aligned yet, still assembling it.
Old 03-16-2018, 10:35 AM   #22
MHeffeGMC71
Re: Truck wonders
So after some more looking around we found this too
Old 03-16-2018, 11:43 AM   #23
Perpendicular
Re: Truck wonders
Wait, are the A-Arms connected to the frame with U bolts?
-Paul
Perpendicular is offline   Reply With Quote
Old 03-16-2018, 12:33 PM   #24
LockDoc
LockDoc's Avatar
Re: Truck wonders
Ooops! That doesn't look good.
LockDoc
Leon
Old 03-16-2018, 12:42 PM   #25
Artofdeath
Artofdeath's Avatar
Re: Truck wonders
subscribed, wanna see how this turns out!
Artofdeath is offline   Reply With Quote
