Old 05-31-2017, 06:47 PM   #1
jbgolden
Floor Shifter Boot trim rings
Guys Im building a 1972 4X4 pickup. Is the trim ring the same on the 4sp floor shifter as the transfer case shifter? I have one that is oval. I need one more or someone to tell me which one I have. I don't need a Chrome one. Just
an original Thank you!
jbgolden is offline   Reply With Quote
Old 05-31-2017, 09:38 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Floor Shifter Boot trim rings
23 views and no replies. I will move this to the 4x4 Tech And Off Roading forum to see if you get some help....
LockDoc
Leon
Old 05-31-2017, 10:18 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My K20 has an auto trans, so no help there... However, that looks exactly like the ring on my t-case boot. Measures about 5 1/2" x 7".
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-31-2017, 11:22 PM   #4
BlueBullet
BlueBullet's Avatar
Looks like 205 transfer case boot ring
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 06-01-2017, 12:05 AM   #5
hotsam
hotsam's Avatar
I have an original 72 4x4.. my transfer case ring is exactly like the pic you have. The trans shifter ring that I sourced from a 72 is perfectly round, but I have no idea if it was the original one. Mine looks like ( the round ring) all pics i have seen of shifters in these trucks though. Mine was 3 ott I changed it to 4 spd
hotsam is offline   Reply With Quote
Old 06-01-2017, 01:19 AM   #6
El Dorado Jim
will have to check mine and let you know
El Dorado Jim is offline   Reply With Quote
Old 06-01-2017, 06:27 AM   #7
jbgolden
Thanks Guys.....So I have one that is perfectly round and one that is oval like in the picture. Do I have what I need? Looking at the Floor pan it looks like I need two oval's. The round looks two small for a SM465 4sp floor shifter.
Old 06-01-2017, 08:09 PM   #8
jeffahart
jeffahart's Avatar
The small round for the transfer, the big oval or square for the transmission. the big one may have 4 or 6 holes. the more rectangular ones have a screw hole at each corner and the long sides for 6. But you will know by the hole sizes of the openings in your hump also.
White K20
jeffahart is offline   Reply With Quote
Old 06-01-2017, 10:28 PM   #9
mike16
sorta looks like one for a 65 GTO 4 speed too
mike16 is offline   Reply With Quote
Old 06-02-2017, 12:09 PM   #10
hotsam
hotsam's Avatar
I was driving mine this morning and looked down and realized I made a mistake.... The boot is perfectly round but the ring is somewhat oval but different than the transfer case. Ill post pics sorry bout that
Old 06-02-2017, 07:15 PM   #11
Brad54
Brad54's Avatar
It also looks like one for a '70s Duster that YearOne sells... black oval. They also have the rubber boot that goes with it.
It's what I put in my '62 Suburban.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-03-2017, 01:01 AM   #12
Jcfcamaro
Jcfcamaro's Avatar
My k10 with a auto trans has one just like it for the transfer case shifter
Jcfcamaro is offline   Reply With Quote
Old 06-04-2017, 01:33 AM   #13
El Dorado Jim
I checked mine, the one in your pic is for the transfer case, the one for the 4 spd is oval also, just bigger with 6 holes
Old 06-09-2017, 12:51 AM   #14
El Dorado Jim
https://issuu.com/truckandcarshop/docs/ts_60-72_web they have the one you need for $11.00 on page 65
floor shifter trim ring
