Old 02-21-2021, 07:14 PM   #1
BigBird05
steering column spring
I am getting ready to rebuild my steering column and need to find the large spring that is at the bottom of the column. It is above the gear selector lever ( automatic column ). It looks to be about 2 1/2" in diameter. I don't know how long because it is rusted in half. Any body have or know of one?
BigBird05 is offline   Reply With Quote
Old 02-21-2021, 07:58 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: steering column spring
PM me your address and I will send you one....
LockDoc
Leon
Old 03-09-2021, 07:10 PM   #3
LockDoc
LockDoc's Avatar
Well, because I didn't read the first post close enough I sent BigBird the wrong spring. After checking, I can't seem to locate any extras like he needs in my parts stash. There are actually 2 springs in that location, one fits inside the other. Here is what he needs in case someone can help him out.
Sorry for the confusion on my part.....
LockDoc
Leon
Old 03-09-2021, 07:34 PM   #4
BigBird05
Lock Doc, Logical mistake, no problem. After studying the problem some more. I deduced that the bad spring looked a lot like a starter solenoid spring. It took me a couple of days to find a donor starter. After tearing it apart it is indeed the the same size. It might be a little stiffer but I can live with that. Thanks for all of the help. Some times it just doesn't work out the way we planed.
Old 03-10-2021, 01:10 AM   #5
LockDoc
LockDoc's Avatar
OK, glad you came up with a solution. Let us know how it works out after you get it together and installed.
LockDoc
Leon
