Old 09-24-2017, 07:31 PM   #526
chewychevy67
Re: 67 GMC super custom build
Starting to reassemble the steering column
chewychevy67 is offline   Reply With Quote
Old 09-27-2017, 07:10 PM   #527
chewychevy67
The 1 1/4" ton front sway bar v's original 1967 7/8" bar. It's Double the size. The big one is going in!
Old 10-09-2017, 06:37 PM   #528
chewychevy67
Rear tire difference. Same size rims.
Old 10-19-2017, 09:23 PM   #529
chewychevy67
Got my rotors back from powdercoat today. They took longer cause I had to wait till they had enough stuff to do in silver high heat powder. I'll have them turned when I get to the point where brakes need to be functional.
Old 10-20-2017, 12:50 AM   #530
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Nice
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-22-2017, 12:03 PM   #531
chewychevy67
Got the rest of my zinc plating done. Some of the brake parts weren't colored to the theme of the chassis so I had the rest of it finished up. Now I can assemble a ton of stuff. Got the original door hinges done. No paint. All done in zinc.
Old 10-22-2017, 12:22 PM   #532
Already Gone
When you start putting your truck together it'll be like assembling a new one.
Old 10-22-2017, 12:54 PM   #533
chewychevy67
Yep. Can't wait till that starts. Dang bodywork standing in the way lol
Old 10-23-2017, 05:23 PM   #534
chewychevy67
Got the tilt telescopic column completed. If you didn't know you would think it could have been factory.
Old 11-05-2017, 08:38 PM   #535
chewychevy67
I got my washer bottle finished up tonight. I riveted a terminal to the bottom of the bottle and a rod thru the top. When there is water in it and it is above the metal rod the light will stay off. When the water level is below the metal rod the light will turn on letting me know the fluid is low. The fluid itself completes the ground circuit. The terminal on the bottom goes to the washer pump ground so the light will only come on when the washer is pumping.
Old 11-06-2017, 01:52 PM   #536
67 Burb
67 Burb's Avatar
I like the washer fluid low-level indicator setup. What kind of circuit are you using to turn the indicator light on? Got a schematic?
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 11-06-2017, 03:23 PM   #537
68Gold/white
Is that a factory deal??? Just wondering, I have not heard of such. Where is the indicator light?
I like that setup. The mickey mouse pump situation on the motor is a pain.........
68Gold/white is offline   Reply With Quote
Old 11-06-2017, 08:23 PM   #538
chewychevy67
It's actually a 71 to 74 gm coolant level accessory. I just adapted it to washer fluid and made the light work next to the wiper wording on the gauge bezel. Gm Part # 364002. The pump is from a 75 Vette. They are common on ebay and relatively Inexpensive swap.
Old 11-09-2017, 04:10 PM   #539
chewychevy67
The radio is now completed as well. Had the face re-chromed and all the buttons re-chromed as well. New truck style lens. I also sent it back to Greg at electro tech and had him install a auxiliary from the back of the radio so I can play my phone. I'll prob run a cable to my console when I get that far. I am super happy with how this turned out. I would recommend electro tech for all your radio needs. Greg is great to work with. I used his speakers as well. Here is a video as well of it all working together.
https://youtu.be/Gw6kgttLmhw
Old 11-09-2017, 04:36 PM   #540
cericd
cericd's Avatar
Nice setup!!!
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 11-10-2017, 02:16 PM   #541
Low Elco
Awesome!
Low Elco is offline   Reply With Quote
Old 11-12-2017, 08:57 PM   #542
chewychevy67
Rear sway bar finished! And cleaning up the front disc brakes as well.
Old 12-06-2017, 09:06 PM   #543
chewychevy67
Picked up this spare tire lock for my spare I'd I mount it in the bed instead of underneath. I think I could use it for a underneath one as well if I got creative.
Old 12-08-2017, 11:39 PM   #544
chewychevy67
Here is how the spare tire lock looks installed.
Old 12-08-2017, 11:46 PM   #545
Kronald_70GMC
Kronald_70GMC's Avatar
That is a very cool touch Keep up the good work uncle!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-09-2017, 05:02 PM   #546
Already Gone
Looks like it belongs
Old 01-09-2018, 08:04 PM   #547
crakarjax
crakarjax's Avatar
What kind of paint did you use for that steering wheel center cap? Looks great!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-10-2018, 10:16 AM   #548
hewittca
hewittca's Avatar
Your attention to detail is amazing. I LOVE the wheel/tire setup. I can't wait to see this thing completed.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-10-2018, 01:23 PM   #549
nuke1
nuke1's Avatar
Looking great!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-11-2018, 01:12 PM   #550
chewychevy67
I used the same paint the body shop used on my interior. Jut mix it all together and used a syringe to apply while it's laying flat. It turned out nicer than I thought.
