07-01-2015, 04:06 PM | #1 |
Re: Bushings
I honestly don't think a difference would be noticed between Poly bushings used on 73-87 C10 arms vs the OE rubber lined sleeve style arms (63-72 C10; 63-91 C20/C30).
If you plan to use C10 arms from a 73-87, the Poly bushings will yield less deflection vs the standard 73-87 rubber bushings.
