Old 12-03-2014, 10:39 PM   #526
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
BucK, I assumed you got this version of the rear coilover dropmember?
Why such a small rear notch?
LOL, I should have, it's too late now! I went with the mild drop because I don't want to deal with cutting or raising the bed floor. I thought I was getting outboard mounted coilovers but after looking at some of my parts I don't think that is the case. Matters not, I am going to press on and get this thing done because crawdadfox threw down the challenge... Cruisin' the Coast 2015!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-03-2014, 11:05 PM   #527
C10_ustacould
Re: Project: Shiro
Well, I didn't really get anything done to the truck tonight but I did make progress. The I6 is GONE!! Thanks to Track70's Dad for giving it a second chance! So with that gone I was able to get the cab stowed in the garage so my queen can park her inside... Happy wife, happy life. I also received my CPP Big Brake kit from Tommy at TnT-MotorSports (ksbrktracer).
So maybe tomorrow night I can get at that notch.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 12:30 AM   #528
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Originally Posted by Bucks68 View Post
I have a set of NOS outter rockers and a set of TriPlus cab corners I got from AMD. I need to order the rest but I'm not sure how far I need to go into the floor on each side. The floor is pitted on bothsides between the toe board and were it kicks up at the seat mount and the passenger side cab mount whole is cracked/torn. What do you think is a good plan for replacement? Should I cut it all out and go back with the new or do it in stages?
Personally, I prefer to keep as much Gm metal as possible. Your best bet might be to just use patches. The whole floor is nice but it's pretty big deal to drill all the spot welds.
Old 12-04-2014, 12:57 AM   #529
1980c-10 mybaby
1980c-10 mybaby's Avatar
Re: Project: Shiro
if your looking to sell your old trailing arms let me know... my 69 suburban trailing arms are done. one just snapped in half from all the rust
im hoping they are the same length if you are looking to sell them
1980c-10 mybaby
1980c-10 mybaby is offline   Reply With Quote
Old 12-04-2014, 11:11 AM   #530
C10_ustacould
Re: Project: Shiro
I'm going to buy replacement floor panel sections for both the driver and passenger side, the outer extensions (inner rocker), and the foot-well panels (kick panels). When I have my Porterbuilt parts installed and my chassis back together I will put the cab back on the frame with new bushing, torque it down, and do my rust repair. My plan is to start by removing the rockers (inner/outer) and then the floor section. After that I will work my way back out to the outer rocker with my new panels. Make sense? Or should I cut out sections, replacing only the damaged areas and not necessarily the entire panel?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 11:31 AM   #531
C10_ustacould
Re: Project: Shiro
I will inspect them and let you know what condition they are in, no cracks etc. The shipping may be a little steep. If I do sell them I will list them in the classified section offering you first refusal on them, sound fair?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 12:31 PM   #532
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
The plan you have mapped out is probably the best option in my opinion. I like the idea of doing the repairs on the frame with it level and mounted solid. Before you start any cutting of spot welds, I would recommend rebuilding your door hinges (with GM pins and bushing) then mount your doors and adjust your gaps as close as you can.
Also, I would tack weld in some braces in the door opening before you even cut anything loose. On mine I just took a bunch of measurements and it worked out okay. I also have a few extra cabs laying around that I can measure for reference, which is handy.
In hindsight, I would have spent more time fitting my doors. I had a few issues with the rockers and the door gaps that really should have been addressed before I finished bodywork. I ended up adjusting my passenger side door up after the truck was assembled. What a pain! I didn't even know the door was hitting the rocker until it started scuffing the clear coat.
For reference HERE is where I tried to fit up my driver side door for the final time. For the record, I also only used GM panels, no aftermarket stuff. This tells us back in the day GM had pretty loose tolerance for fit up of our trucks.
I fit the passenger side too, I just didn't notice the door was contacting the rocker until it was shiny
Sorry for the novel but just know this, I learned a ton about what not to do. I will help you any way I can when you go to making sparks.
Old 12-04-2014, 01:32 PM   #533
C10_ustacould
Re: Project: Shiro
Mike, as I have said before I am going to rely on your experience so you can write as much as you care to! Thanks for taking the time!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 01:40 PM   #534
C10_ustacould
Re: Project: Shiro
I got taken in by the cyber Monday hype...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 01:44 PM   #535
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project: Shiro
Sweet^^^
Keith
Convert to disc brakes.
Old 12-04-2014, 01:47 PM   #536
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Shiro
Sweet^^^
X2!
Very nice
Old 12-04-2014, 02:14 PM   #537
1980c-10 mybaby
Re: Project: Shiro
its only about a 5 hr drive from where im located at. but yes let me know how they look. im not in a rush honestly the burban sits for months at a time anyways lol
1980c-10 mybaby
Old 12-04-2014, 02:32 PM   #538
C10_ustacould
Re: Project: Shiro
I'll let you know.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 03:34 PM   #539
GAc10boy
GAc10boy's Avatar
Re: Project: Shiro
Wow those are beautiful! Some of my favorite wheels! Expected arrival date?
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 12-04-2014, 04:03 PM   #540
nlped
nlped's Avatar
Re: Project: Shiro
I dig the wheels!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-04-2014, 04:36 PM   #541
Bennett68C10
Bennett68C10's Avatar
Re: Project: Shiro
Nice looking wheels
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-04-2014, 07:49 PM   #542
smbrouss70
smbrouss70's Avatar
Re: Project: Shiro
I love those wheels! What sizes? Are you gonna use up all that room in those bed tubs?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-04-2014, 08:09 PM   #543
68basket
Re: Project: Shiro
Love those wheels, I thought you already purchased some for this project though
68basket is offline   Reply With Quote
Old 12-04-2014, 08:21 PM   #544
C10_ustacould
Re: Project: Shiro
Sweet^^^
X2!
Very nice
Originally Posted by nlped View Post
I dig the wheels!
Originally Posted by Bennett68C10 View Post
Nice looking wheels
Thanks guys I REALLY like these, so I had to go for it.
They should be here in time for Christmas.
I do, but I changed my mind!
20x8.5 (5.25" bs) and 20x10 (6.0" bs). The tubs could house a little more but not much so I didn't see a reason to push it and cause myself any issues.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 08:23 PM   #545
nlped
nlped's Avatar
Re: Project: Shiro
What are you going to do with the current wheels?
Carter
Old 12-04-2014, 09:30 PM   #546
C10_ustacould
Re: Project: Shiro
They are for sale, just haven't listed them yet.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 09:41 PM   #547
slowcpe
slowcpe's Avatar
Re: Project: Shiro
Nice choice on the wheels!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-04-2014, 11:01 PM   #548
C10_ustacould
Re: Project: Shiro
Worked on the notch for a little bit tonight...
Rear bridge removed.
Passenger side notch partially installed.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 12-04-2014, 11:06 PM   #549
nlped
nlped's Avatar
Re: Project: Shiro
All those holes are crazy fun to drill out, HUH?
Carter
Old 12-04-2014, 11:36 PM   #550
C10_ustacould
Re: Project: Shiro
Oh yea!! Gonna have to pick up a few 7/16 drill bits and some of what we call "Duck Butter" to keep them sharp.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
