Old 09-03-2013, 07:38 AM   #76
86Eric
Re: Lets see your seat swaps....
Originally Posted by bohmankid View Post
I like these swaps guys. I went a little newer then most of you..
I put a second row seat out of a 2011 Tahoe into my 86 GMC. I had to take off ALL the original mounting brackets and make my own out of angle iron. drilled new holes in my floor as well.
Attachment 1033761
Attachment 1033762
Attachment 1033763
That is exactly what I am trying to do in my 86! I wanted a leater bench seat style with some comfort and a faold down console. I am actually looking to use the back seats from a King Ranch ediction Ford (I know, sort of sacriligious, but they look real nice).
How much leg room do you have compared to the original seat and how much modification did you need to do to make them work in the cab? Plus, any more pictures you could provide would be greatly appreciated. Thanks!
86Eric is offline   Reply With Quote
Old 09-03-2013, 10:58 AM   #77
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Originally Posted by superwade57 View Post
Looking good.... what did you use for mounting brackets? Looking to put a set of 91 k5 buckets in my 86 swb t56 swap
Sorry I missed your question 8 months ago
I actually used a Hi-Lift Jack mounting bracket to help create the inboard mount. I cut the bracket in half then welded it to the Suburban seat frame.
Hi-lift jack bracket that I cut in half. Worked perfectly
Here are the seats after re-upholstery
2010 GMC center fabric
DirtyLarry is offline   Reply With Quote
Old 11-04-2014, 05:43 PM   #78
SeniorVerde
SeniorVerde's Avatar
2007 Subaru Impreza buckets and a Blazer console in my '71 stepside. Not a 73-87, but I've done the same thing with an 85.
I did a how to, that works for most odd-ball buckets from wrecking yards.
SeniorVerde is offline   Reply With Quote
Old 11-05-2014, 09:38 AM   #79
carboncrew
carboncrew's Avatar
These are 2nd row seats from a honda odyssey ('take outs' from handicap conversion vans). Cheap, new and matched the 91 chevy light gray perfect led me to this decision.
These are the brackets I had to make:
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 11-05-2014, 10:47 AM   #80
Houston Ben
Houston Ben's Avatar
Carboncrew, I like those, how wide are they? I tired to fit an early 90' series bench in my 86' but it was not wide enough and didn't line up with the steering wheel.
Thanks!
Houston Ben is offline   Reply With Quote
Old 11-05-2014, 11:18 AM   #81
tylervalo
Here are 2 I have of mine:
tylervalo is offline   Reply With Quote
Old 11-05-2014, 01:03 PM   #82
carboncrew
carboncrew's Avatar
Thanks!
These are the same width as a stock bench.
These are the new seat sitting on an old bench frame. The seats are actually pushed tight together in this pic so once mounted and proper gap between the seats adjusted they were a little wider than what this shows.
________________
My very own build
Old 11-05-2014, 01:04 PM   #83
tylervalo
I check with the guy in Arizona you bought those seats from, he charges $220 to ship. GAH!
Old 11-05-2014, 01:07 PM   #84
tobytuttle
tobytuttle's Avatar
[QUOTE=carboncrew;6904553]These are 2nd row seats from a honda odyssey ('take outs' from handicap conversion vans). Cheap, new and matched the 91 chevy light gray perfect led me to this decision.
Once again very clean truck , Im not into aftermarket seating,,,, though you nailed it, and that truck all aroud, with your burb upgraded burlwood interior, mirrors. and of course black, that pick-up would fit in at my house.
70 SS 454 Monte
69 355 C-10 Shortbed
90 454 Crew dually 4x
76 454 Dually 2x
75 454 K5
77 468 Kona
tobytuttle is offline   Reply With Quote
Old 11-06-2014, 10:42 AM   #85
carboncrew
carboncrew's Avatar
Ouch! That pretty much takes away the cheap part. I think he's selling them for a lot more nowadays too.
I could maybe carry a set halfway (oklahoma) when I visit my sis this spring, if that helps.
________________
My very own build
Old 11-06-2014, 10:48 AM   #86
tylervalo
I appreciate the offer, I'll probably stick with my buckets for a while though. I have to use them for my center console that holds the tablet and camera system.
Old 04-11-2015, 12:37 PM   #87
kidd79
kidd79's Avatar
I did pretty much the same thing 86jimmy4x4 did with his seats, except i threw in a center jump seat from a 2003 pickup that I got from Ebay. Everything bolted in. No cutting and welding involved. I slid the center jump seat front brackets underneath the bucket seat brackets, and drilled the inside mounting holes through the floor, and got creative with some clamp style bracket for the back of the center jump seat. All in all it took me about 4 hours to do everything by my self. Went from factory torn up bench and red carpet to black carpet from LMC, Procar bucket seats and adapter brackets, purchased from summitracing. I think it turned out all right. The seats aren't sitting too high, and the steering wheel can be used inline with the steering column. I don't have to tilt it up more than center with the column.
kidd79 is offline   Reply With Quote
Old 10-20-2016, 07:07 PM   #88
jojogambler@gmail.co
I just got bucket seats and rails from a 75 k5 blazer will the bolt right in a 1973 c10 or do I need different brackets
jojogambler@gmail.co is offline   Reply With Quote
Old 10-20-2016, 07:11 PM   #89
Trying to get them in my 1973 Cheyenne super short bed.
Old 04-15-2018, 08:11 PM   #90
mcrich65
I'm looking for some manual bucket seats. Straight swap replacements for a 89 GMC suburban....anyone have any ideas????
mcrich65 is offline   Reply With Quote
