11-24-2019, 11:44 PM | #1 |
Transmission Woes
I just purchased my 1969 K20 with an SM465 transmission and 350 small block. Intend to make her a resto-mod long term but right now I just want to keep her running and do small upgrades as I can afford them.
Today I went to move the truck and the clutch pedal went all the way to the floor. I looked under the truck and the lower fork push rod (I've seen a few names for it... but the adjustable rod to the fork) was no longer connected and the push rod swivel nut was laying on the ground. There is literally no room left to adjust the rod - which makes me think a clutch replacement may be in order (although it was shifting great the 50 or so miles I've put on it). But now the gears are spinning in my head... and thought I'd ask the group some questions (please note money is fairly tight at the moment for me):
I appreciate any thoughts! Thank you! |
11-25-2019, 12:19 AM | #2 |
The Older Generation
Re: Transmission Woes
Here is my NV4500 install to replace my SM465. It would be different as far as the 4x4 but everything up front would be the same. http://67-72chevytrucks.com/vboard/s...d.php?t=673588 I used all of the stock bell housing and clutch components..... LockDoc
11-25-2019, 09:25 AM | #3 |
Might be better to figure out why the rod fell out.
Is the fork spring from the fork to the frame still there? Is the zbar still in place correctly? Is the motor mount still good? Broken mount allows the motor to twist enough to let the rod drop out. |
11-25-2019, 12:20 PM | #4 |
Proprietor of Dale's Corner
I want to see pics of the truck....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-25-2019, 12:26 PM | #5 | |
Is your assumption nothing is wrong with the clutch or transmission? That would certainly be a relief as it wasn't a project I wanted to tackle right now. |
11-25-2019, 12:55 PM | #6 |
Yup!
Best to look it over. Saves a lot of work and mulla sometimes. |
11-25-2019, 05:08 PM | #7 |
Some pictures of the truck in this thread. Will take some pictures of the linkage: http://67-72chevytrucks.com/vboard/s...d.php?t=796924
11-25-2019, 06:02 PM | #8 |
Here are some pictures of the clutch linkage
11-25-2019, 06:13 PM | #9 |
Is that your clutch fork in the first pic?
I see you don’t have anymore adjustment on the rod. Did you find a long spring from the fork forward to the frame? |
11-25-2019, 06:25 PM | #10 |
Equal opportunity joke ofender
You are missing a pc in the 1st picture
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
11-25-2019, 06:28 PM | #11 |
This should be on the end of the rod
11-25-2019, 06:40 PM | #12 |
I think he has that. He found it under the truck.
It appears someone used the wrong length throw out bearing and had to weld a higher mount to get the clutch to adjust. That’s the bad info as the trans needs to come out to fix the fork and maybe replace the tob. Short term cure would be make a new clutch rod that’s longer that will help with adjustment and stay togethor until he’s ready to spend the money to fix it right. |
11-25-2019, 06:59 PM | #13 | |
11-25-2019, 07:47 PM | #14 |
That might work if he has enough room.
Or slip a pipe nipple over the fork end to extend it. Not the best solution but doable. Pipe is easy to cut to get it close. |
11-25-2019, 09:25 PM | #15 |
I have it. Luckily it was under the truck on my driveway.
Also now that you mention it, no spring either. Not sure how I overlooked that. If I use a longer rod is that spring going to be critical? I've done a lot of work with threaded rod and unistrut in the past so I know exactly where that stuff is at. I appreciate all the feedback. I guess the transmission might end up being the first big project on this truck instead of replacing the front axle to get disc brakes :-) |
11-25-2019, 09:30 PM | #16 | |
Attached is another picture of the fork. This community is great. I really appreciate the feedback. |
11-25-2019, 09:32 PM | #17 |
No spring being there probably what helped it come apart. I have an extra here I can send you for shipping costs if u need one
11-25-2019, 09:48 PM | #18 | |
Should look more like the end on this one. https://www.4speedconversions.com/3765372.html Keep that link somewhere. You might need a new fork in the future. |
11-25-2019, 11:52 PM | #19 |
Thanks for the link to the pics. Ilike the truck.....aa lottt
11-26-2019, 12:10 AM | #20 |
Here is a good picture of the clutch linkage spring..... I think this is on a 6 cylinder but it should be the same. LockDoc
11-26-2019, 12:19 AM | #21 |
That is super helpful. Also, I don't have a nut between the rod and the nut to the fork. Maybe that is part of the issue as well. Thank you!
11-26-2019, 12:31 AM | #22 | |
No problem. You may have overlooked it but Richard said he had a spring in post #17. Even though it looks like it, there is no nut between the wedge and the clutch rod. That is just part of the wedge. LockDoc
