10-28-2010, 12:41 AM | #1 |
do i undercoat my cab or just paint it?
do i undercoat my cab or just paint it? i was planning to put a real thin coat of undercoating and then paint it balack. or i might just paint hugger orange to match the truck. i dont want it to look like i am hiding anything cause it is an almost rust free cab with factory rockers and floor boards
1969 chevelle 350 numbers matching 1971 chevy lifted 4x4 (the break up build) http://67-72chevytrucks.com/vboard/s...d.php?t=423605 1993 subaru impreza 1969 blazer cst 8" lift |
10-28-2010, 06:49 AM | #2 |
Re: do i undercoat my cab or just paint it?
I went with Por 15 on the bottom my build . I'm on the Eastcoast but brought my build back from California , its really tough to find rust free trucks around here .
I don't think I would use under coat , I have seen guys use the spray in bed liner like xline ... rhino liner is crap IMO . Looks great buddy ! |
10-28-2010, 09:26 AM | #3 |
I just stripped one of my rustfree cabs to bare metal last month.I used two coats of Rustoleum Rust Stop primer and two coats of satin black Rustoleum.I'm not sure what color the truck will be and don't care if it matches since you never see it.I guess spray-on liner is good,but it scares me like undercoat and powder coat.If and when anything gets behind it,there it stays and eats.Paint crumbs off as the chip/scratch grows.Those other coatings are like a shell and I've seen worse damage because of those than without.
10-28-2010, 09:43 AM | #4 |
under coat because paint is not that strong up against rocks and sand and mud.trucks from the factory are under coated for a reason
R.I.P gm 1908-1986 1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f |
10-28-2010, 10:37 AM | #5 |
I have done it both ways. If its a driver> undercoat. If its a show truck> paint. (And dont hit any rocks or gravel).
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
10-28-2010, 11:10 AM | #6 |
The one I just did is for a 2wd street driver.it'll see miles but an easy life compared to a stone tossin' 4wd.I still may hit it with the Duplicolor spray on liner.
10-28-2010, 11:59 AM | #7 |
ok thanks this truck will be my tow rig and to play in the mud truck
10-28-2010, 07:09 PM | #8 |
ok i just undercoated my cab and painted the bottom
10-30-2010, 08:46 AM | #9 |
They have tintable undercoating as well...lizard skin I think?. I plan on epoxy primer and Raptor bed liner.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-30-2010 at 08:47 AM. |
09-08-2012, 06:34 PM | #10 |
I have the same issue right now. I was thinking about getting my buddy to spray Rhino on it because the primer he uses in unreal and I have had him spray stuff and cant find a way to get it off. The only other issue is that it will not match my frame. The local Car quest here told me to use farm implement paint which is just single stage no hardner. He said it is the same thing as chasis black.
09-08-2012, 09:53 PM | #11 |
I would never undercoat anything again, my Nova is done and I had a tranny case get blown open and that tranny fliud turned the undercoating to tar or something along those lines.
I would use bedliner or the POR 15 . Maybe with paint on it then it might not be effected by fluids but without it sure will. Posted via Mobile Device |
09-09-2012, 01:44 AM | #12 |
69gwc i think that happened because most factory style undercoating is rubberized.Its better then nothing but i like more of the modern kind or spray on bed liner.
09-10-2016, 11:43 PM | #13 |
hows everybody\
09-10-2016, 11:48 PM | #14 |
working on my 1967 all thats left is blast the cab everthing else done and prime takes time and money money money
li eft |
09-11-2016, 12:38 AM | #15 |
i did bed liner on both sides of my floor that way nothing can hurt it
09-11-2016, 09:31 AM | #16 |
I wire wheeled it then 2 coats of primer 2 coats of paint then sprayed 3M undercoating.
Did it 2 years ago looks as good as the day I did it & it's my DD |
09-13-2016, 10:42 PM | #17 |
I sand blasted it then POR 15 and rhino linered it
1970 K20 1967 Blown Stepside 2016 Chevy 2500 Duramax 1989 Jeep Cherokee 1995 S-10 2014 Infinity Q-50 AWD 1970 Chevy K20 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=634164 1967 stepside rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=684913 Shop build http://www.garagejournal.com/forum/s...d.php?t=225559 |
07-28-2017, 11:54 PM | #18 |
wire wheeled and POR15-ed
07-29-2017, 12:18 PM | #19 |
...probably rotated....sorry
