11-16-2017, 04:22 PM | #1 |
pics of 2 or 2 1/2 inch lifts and give tire size
I Am looking to drop my 84 Silverado down from 4" to 2 or 2.5 " with maybe
32x10.5x75r 15;s . this 84 I have RANCHO 4" and 33x12.5r 15's for over 30 years and now getting older and want a softer ride and lower it so its easier to get into!. heres the truck now. I thank you all,dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
11-16-2017, 08:49 PM | #2 |
Re: pics of 2 or 2 1/2 inch lifts and give tire size
Put some steps on it, and get a good suspension system. I thank Rancho is thee stiffest out there.
2000 GMC CCSB 454/4L80 6 lift SAS 1999 Chevy CCSB 454/NV4500 6 lift 1999 GMC Yukon 350/4L60 4" SAS |
11-17-2017, 09:28 AM | #3 |
tuff country is about the best off the shelf for price / ride / quality .
or call www.offroaddesign.com and have a set of there custom spec built springs made .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-17-2017, 11:02 AM | #4 | ||
agree. but was a good choice 30 yrs ago.. thx for reply, Quote:
11-17-2017, 11:51 AM | #5 |
I run the Skyjacker 2.5 springs frt and back on my '69 GMC 1500. Overall I am satisfied with their performance. I live on a small farm and use it for farm activities, some off-road stuff like going through cornfields rounding up cattle. I would like to post some pictures but don't have any right now. I run a stock 16 inch steelie. Hercules Traildiggers I think they are 31".
11-17-2017, 03:42 PM | #6 |
If ur running a lift then you don’t want to run 31s, they came stock with them and would look goofy with any lift n small tire. 32 lil better but still small for lift.
11-18-2017, 11:07 AM | #7 | |
thx for the reply b454rat. I found out these came with 235x75xr15 and I did a comparison between the factory tire and 31x10.5xr15, looks to be a bit different. chart below... thx for your reply, dave https://tiresize.com/comparison/
11-18-2017, 10:30 PM | #8 |
On my 81 the best thing I did for the ride was put a adjustable shock on and dumped the quad shock setup. I installed procomp mx6 shocks and it was night and day difference, my truck also has the 4" Rancho lift. However, if you really want to drop to a 2.5" lift I would get the tuff country EZ ride springs.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
11-19-2017, 07:39 AM | #9 |
If you want to go with a mild lift, you could run stock springs with a long add a leave, a zero rate and longer shackles. With the add a leave, it will be slightly stiffer, but better than the springs currently have. Or could do 52s, but that might be more lift than what you want/need.
11-20-2017, 11:54 AM | #10 |
I thank you both for the advice. its very helpful. now on the 52" spring? not sure what that is all about? my rear factory springs are 52" eye to eye. dave
11-20-2017, 02:09 PM | #11 |
offroad flex and cheep 4" lift in the front is to use 52" rear springs with a set of hangers on the front .
your use of the truck dosn't require this mod .
11-21-2017, 11:46 AM | #12 |
i fell into the same situation a few years back, they pretty much shut down all the local off road places and needed new tires soon. so figured whats the point of buying new 38s that are never going to see snow.
i basically just put the stock suspension and and put on a 2 inch body lift before 33 12.50s on 2 inch lift apparently i should have bought a better camera back then. for some reason thats the only two pictures i have after lowering it |
11-21-2017, 06:11 PM | #13 |
thank you all for the interesting info,... leaning tward 2.5 inch all spring on
31x10/5 xr15
11-21-2017, 06:16 PM | #14 |
FWIW- Have you considered a six lug 16 steelie widened to 8 inches. I think these rims make a 1/2 look like a boss, but as you probably know these rims are not just hanging around. Bruce
11-22-2017, 11:16 AM | #15 |
I just got my orig ralleys powder coated, will be using them.
thx for the input, dave
11-22-2017, 08:58 PM | #16 | |
My Blazer is 2.5" Tuff Country front leafs and a 3" block in the back with 33x12.50x15. |
11-22-2017, 09:01 PM | #17 |
Stock height K10 with 31's
11-25-2017, 04:05 PM | #18 |
Here is my 69 with a 2 lift. I have 33x11.50r15 on it right now. I do get a slight amount of rub if Im on the stops and hit some bumps.
11-26-2017, 11:01 PM | #19 |
Still a few weeks away from completion of build. Truck has a 2" Tuff Country spring lift, that seems more like a 4" lift. It turned out higher than I wanted. The tires in the picture are 33x12.50's that only measure 31.2 inches with weight of truck on them.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
11-30-2017, 12:06 AM | #20 |
BlahBlahBlah
Really like the colors of your truck. And you are right, that does look like a four inch lift from the pictures.
12-08-2017, 11:12 PM | #21 |
2 1/2 " blocks on rear of 3/4 ton camper special.
4" front sprgs, 35 " tires
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 12-11-2017 at 10:53 PM. |
12-11-2017, 01:00 AM | #22 |
This is an old Rancho 2.5in I had in my 74 with 33x12.50r15 on 15x8s
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 Last edited by bmchevy1979; 12-11-2017 at 01:11 AM. |
12-24-2017, 12:50 AM | #23 |
Pretty sure this was 2" lift, 33x12.50 on 15x10 ralley.
12-26-2017, 09:43 PM | #24 | ||
http://www.67-72chevytrucks.com/vboa...d.php?t=753217 Quote:
