Old 04-30-2009, 10:15 AM   #1
lookingtobuy
lookingtobuy's Avatar
Smile Distributor recommendations??
Good morning,
I am looking to upgrade my distributor which appears to be original.
Definately has points : )
Can you guys give me recommendations for HEI that will fit in the 72 Blazer.
manufacturer and model number? As well as any tips for wiring mods?
Thanks... I 've only got about 100 miles on the new motor and want
to finish it right.
lookingtobuy is offline   Reply With Quote
Old 04-30-2009, 10:21 AM   #2
sdailey
The Few, The Proud
sdailey's Avatar
Re: Distributor recommendations??
Alot of members, myself included, are using a HEI from Skip White. Here's a link to their e-bay store. Do a search on the board and you'll find several threads about their HEI. Sorry, but I can't help you on the wiring conversion.
http://shop.ebay.com/merchant/skipwh...Q_fromZQQ_mdoZ
Shannon
sdailey is offline   Reply With Quote
Old 04-30-2009, 11:58 AM   #3
jaros44sr
jaros44sr's Avatar
The physical size is my biggest problem, with the locking ring, there is about a 1/4" to 1/2" clearance to the firewall. Other issue is the size of the yellow wire? from the starter. Needs 12 volts to the HEI, original wire has resistance (small size of wire = resistance)
Also, mine has the coil in the cap, and I think this is the problem with my space issue
Since mine is all apart, wouldn't be hard to get pics
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-30-2009, 11:59 AM   #4
Burt4x4
Burt4x4's Avatar
When I converted my old points dist to electronic I wanted to retain the "small" cap dist so I went with a "ready-to-run" MSD Billit 8360
Keep the can type coil too:
This setup worked great!
HEI is alot cheeper but I just didn't want that type.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-30-2009, 12:02 PM   #5
jaros44sr
jaros44sr's Avatar
nice setup
SAFETY FIRST
AS usual, off topic
Jim
Old 04-30-2009, 12:08 PM   #6
71jimmy
71jimmy's Avatar
Seen the ad before, very intriguing. Clearance to the firewall is a concern. I'm considering going TBI. The ad above states for "carburated" systems. Is there a difference when you go TBI, MPI etc? Is it something that can be retrofitted to this type of Dist.? Or do you need to by a Dist specifically for TBI, MPI etc? I'm thinking it's got to be wiring to the ECU that's different.
Sorry if this is a hijack, but I think general info all could use.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-30-2009, 12:20 PM   #7
Burt4x4
Burt4x4's Avatar
When I put Edelbrock MPFI on my 454 I used this Mallory Dist #6148201 because it was made to work with the Edelbrock MPFI. Direct plugin.
I think the ready-to-run is more distributer than what is needed for EFI, the reason I say that is my current Mallory dist is super simple compared to the MSD one I had om my 350, I would assume that is because the ECU does all the "thinking" that the dist. does for carborated engines.
I don't know jack about TBI other than it's a batch fire type EFI...
.02c
Old 04-30-2009, 08:30 PM   #8
pound41
I have a mallory unilite in my 71 blazer and 1969 camaro. Same size as a stock one No hassles
pound41 is offline   Reply With Quote
Old 05-01-2009, 05:46 AM   #9
jaros44sr
jaros44sr's Avatar
Got pics.?
SAFETY FIRST
AS usual, off topic
Jim
Old 05-01-2009, 10:11 AM   #10
lookingtobuy
Thanks for the input,
pounds41 on the Mallory unilite what was involved in the set up..
are there any extra things needed?
Old 05-01-2009, 12:50 PM   #11
Tynee
I miss this truck.
Tynee's Avatar
Correct. On later model engines with EFI, the spark advance is electronically controlled. On the later model, carburated motors with no ECU, it is vacuum controlled.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 05-01-2009, 08:18 PM   #12
pound41
My computer with my pic software crashed. The post up above of the mallory is what it looks like. Except mine are vac advanced they have a few wires to run. My camaro 69 rs/ss 350 came with the unilite in it. The man I bought it from was a justice dept guy who knew his cars.(researched everything) He saved every part that went on or off the car. example 14in rallys with original redlines on them. he gave me boxes there were GM HEI etc. He said the unilite was the best. Anyway I built a 72 blazer and put a 327/365 in it with a GM HEI and lived with the problems of clearance --the cap vibrating off etc. So when I needed a dist for my 71 blazer. I called a local racing friend to ask where to get a unilite. he happened to have one so I got it. He said they were great. I know they recommended upgrading the coil. My camaro and my blazer still have stock coils. I just put new top half of the motor in my 71 blazer(down cylinder)
I lifted the unilite out mulitple times getting the teeth lined up on #1
If I can get a decent pic of it sitting in there with my blackberry I will email to jaros and he can post.
Old 05-01-2009, 10:55 PM   #13
jaros44sr
jaros44sr's Avatar
Thanks Pound
SAFETY FIRST
AS usual, off topic
Jim
Old 05-05-2009, 02:40 PM   #14
lookingtobuy
pound41 and jaros.. did you guys get the pics yet?
Has anyone else used the unilite setup?
Old 05-05-2009, 09:58 PM   #15
jaros44sr
jaros44sr's Avatar
nope
SAFETY FIRST
AS usual, off topic
Jim
Old 05-05-2009, 10:02 PM   #16
msgross
msgross's Avatar
I have a skipwhite procomp HEI, it sits close to the firewall but still enough room it around for timing... bout 1/4" between the wires and firewall...
I'm putting it up for sale in the parts board tomorrow...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-06-2009, 04:03 AM   #17
powermad
Hillbilly Hotrod
Bear in mind that if your body bushings are shot you will have to make some room with a 4 lb hammer to clear the coil.
I am using an Accel Supercoil equiped HEI and I had to stretch the firewall a bit to get it to clear.
But my body mounts are wasted and need replaced. With new bushings and a 1" body lift it won't be an issue any longer.
Yeah I know it's a mess under there. It's one of many things to do on the list.
69 K5, .060 over 350/465/205.
powermad is offline   Reply With Quote
Old 05-07-2009, 07:44 PM   #18
pound41
jaros:
send me an email I have 2 pics on my blackberry that I will
send you. They will give you an idea of how it looks
Old 05-07-2009, 11:12 PM   #19
5150
C10 Club Tennessee
5150's Avatar
I bought one of the skipwhite ones on Sunday. It showed up at the house Tuesday and it works great.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 05-08-2009, 12:43 AM   #20
Skirkpat
Skirkpat's Avatar
if you want to keep the smaller cap, just modify your points distributor , the pro billet, and unilites are nice, but way overkill and a waste of cash on a mild street driven engine in my opinion, you can get rid of the points, use your old distributor for around 80.00 for a pertronix kit.
http://store.summitracing.com/partde...5&autoview=sku
Skirkpat is offline   Reply With Quote
Old 05-08-2009, 07:11 AM   #21
jaros44sr
jaros44sr's Avatar
jaros:
pm sent
SAFETY FIRST
AS usual, off topic
Jim
Old 05-10-2009, 07:01 AM   #22
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
B, PM me that linky or part number Please.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-11-2009, 09:34 PM   #23
pound41
Jaros:
Sent you 2 pics yesterday
Old 05-14-2009, 11:09 AM   #24
clos69
Its Topless Season!!!!
clos69's Avatar
I just bought my second dist from Skip White (heck of a product for a heck of a price)Does any one know if I am going to have clearance issues on my 4x4 blazer?
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 05-14-2009, 03:15 PM   #25
Yukon Jack
Yukon Jack's Avatar
Usually an HEI will fit, but every once in a while I read someone had to do a little massaging to get acceptable clearance. I put in a stock HEI from a 1978 and it fit without modification, but not alot of room back there for sure. I do have new rubber body mounts that I'm sure helped it fit.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
distributor, hei conversion
