01-22-2017, 11:21 PM | #1 |
Door skin patch panel question
1970 c10
I'm replacing the lower door skin. I already cut and got the panel. I'm welding the seam where the body molding will be. Question is what is the best way to fold over the edge that goes on the inside of the door. Hammer and dolly or is there a better way? Thanks mark |
01-23-2017, 12:47 AM | #2 |
Re: Door skin patch panel question
Well, there are two ways to do this if you aren't going to butt weld it. If you are going to use a stepping tool or a backing plate, I suggest you do this under where the moulding goes so it will be hidden by the moulding. There is a very good chance there will be a "ghost line" there after it's painted.
You can step it with pliers like these that I have. With the piece clamped to the door it would look like this. If you do this, be sure to seam seal it on the inside to protect it from water. Here is a nice little article on using a "butt welding with backing." http://www.autobodystore.com/door_rust.shtml Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
01-23-2017, 08:40 AM | #3 | |
01-23-2017, 09:18 AM | #4 |
01-23-2017, 11:44 AM | #5 |
The Older Generation
I think he is wondering about rolling over the sides and bottom. LockDoc
01-23-2017, 01:08 PM | #6 |
Photos are nice Are you talking about "hemming" the edge?
Brian
