Old 01-19-2019, 05:06 PM   #1
kens65fb
Best battery for 64
I recently purchased a 64 C-10.
The battery was very weak, and was definitely not the right one, as it was just plopped in.
What battery group was originally in these trucks, and is there a newer, or better size available?
Also I was thinking of a side terminal battery, as I feel it will make a cleaner looking engine compartment. Any comments or suggestions
kens65fb is offline   Reply With Quote
Old 01-19-2019, 06:13 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Best battery for 64
I did a site search and this thread is very informative - http://67-72chevytrucks.com/vboard/s...d.php?t=628596
Old 01-19-2019, 06:27 PM   #3
kens65fb
Seems like this post mostly mentions Optima & deep cycle batteries, I'm not considering either of these.
Seem like a group 24 battery is a good fit ?
Old 01-19-2019, 06:32 PM   #4
The Rocknrod
Moderator
Where did you get that information? Optima doesnt make group 24 so I hear.
Old 01-19-2019, 06:44 PM   #5
kens65fb
In the link you referenced in your earlier post
Old 01-19-2019, 08:24 PM   #6
franken
Your local parts store has a website where you can search for parts based on your vehicle. This isn't a secret and will provide more accurate info than you'll get from 50 opinions from the internet.
franken is offline   Reply With Quote
Old 01-19-2019, 11:47 PM   #7
AcampoDave
AcampoDave's Avatar
I used to have a Caddy with a side post battery and I always found it to be a p.i.a because you couldn't roll with the terminals only half ways kinda tight. It had to be firmly tightened with a 3/8 wrench or it wouldn't crank...i don't like my terminals to be so tight that i cant yank 'em loose in the event of a wiring short....it happened once on my c10....my ignition switch on my later model g.m column had a wire pinch up under there while i was working on it and nasty smoke started billowing. Thankfully i was able to disconnect the battery in a hurry by yanking it loose which minimized the damage.
AcampoDave is offline   Reply With Quote
