Old 04-07-2018, 06:14 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Wiper Transmission Arm Install
So I searched the pics on this site and the FAQ section. Can't seem to find the info on how the two transmission arms attach to the wiper motor. Does anyone have pics that show that anywhere? Thank you.
Old 04-07-2018, 07:09 PM   #2
The Rocknrod
Moderator
Re: Wiper Transmission Arm Install
Is this on our trucks? I found this on line but the page was just a pic, if so I'm missing the short arm.
Old 04-07-2018, 07:30 PM   #3
LT1 Burb
LT1 Burb's Avatar
Yes, that is the correct installation.
LT1 Burb is offline   Reply With Quote
Old 04-07-2018, 07:43 PM   #4
bj383ss
bj383ss's Avatar
Here are the pics I took of mine before tear down.
IMG_1494 by bjohnson388, on Flickr
IMG_1495 by bjohnson388, on Flickr
IMG_1497 by bjohnson388, on Flickr
IMG_1499 by bjohnson388, on Flickr
and yes that is a 4-5-6 you have pics of.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 04-07-2018, 07:55 PM   #5
Macdaddy1
Rocknrod
I have an extra set of arms for cheap if you needs them.
Pat
Macdaddy1 is offline   Reply With Quote
Old 04-07-2018, 08:23 PM   #6
The Rocknrod
Moderator
Cool guys that's great, thanks.
I "may" need your help Macdaddy1, I will PM you in the AM.
Thanks again guys.
Oh and this needs to be in the FAQ section it's not there.
Old 04-08-2018, 03:29 AM   #7
The Rocknrod
Moderator
This is what I bought on ebay in the first pic (arrow pointing to what was missing), in the second pic is what was sent. So I'm attempting to get the little short crooked arm from the seller now.
Old 04-08-2018, 09:24 AM   #8
Macdaddy1
Nice. Hope it works out. keep us updated and let us know how it turns out.
Pat
Old 04-08-2018, 10:34 AM   #9
LT1 Burb
LT1 Burb's Avatar
If it doesn't work out LMK because I lost mine and someone sent me one, I then found it.
Old 04-08-2018, 11:12 AM   #10
The Rocknrod
Moderator
I may do that, thank you.
Here is the Assembly manual page for the wiper linkage.
Old 04-11-2018, 03:40 PM   #11
Just-in-credible
Just-in-credible's Avatar
well i can tell you one thing...you want to make for damn sure that you've got them installed properly. I was missing a piece when i put mine together, and I wasn't smart enough to google it. I thought I had it all figured out, and it was working as it was supposed to. I was looking at the drivers side wiper only. So I put the wiper arms on and hit the switch, the drivers side went up the windshield, and the passenger side wiped down the cowl, taking all of the paint with it. So I called up the place that sold me the hardware, and he laughed, and said "yeah, just after you walked out, i realized that I forgot to sell you a piece, but i didn't have your phone number" So do yourself a favor, and make sure BOTH sides work properly...doh!
65 short step rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=621399
60 apache 4x4 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=824325
Just-in-credible is offline   Reply With Quote
Old 04-11-2018, 04:01 PM   #12
vin63
It's Better With Nitro
vin63's Avatar
I just went through all of this after having the transmission arms powder coated and forgetting to take a pic before I removed and disassembled everything. After wiring the wiper motor (which is a whole other series of threads in of itself), I cut a couple of strips of a sticky note and stuck them on the wiper arm knob just to verify operation and park location. Fortunately in my case, I just had the arm off of the wiper motor stud 180 off.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-11-2018, 04:06 PM   #13
The Rocknrod
Moderator
I can see how that could get nasty if you had the wiper arms installed on the first test run. Especially on a new paint job.
