09-17-2015, 10:19 AM | #1 |
Winshield frame to roof
Does anyone know if there is a replacement panel or frame for these trucks?
Where the windshield seat meets the roof I have some rot and would like to replace. Its at the point on the roof and windshield come together. Thanks.
1964 GTO 1931 MODEL A 1950 3600 |
09-18-2015, 07:35 AM | #2 |
Re: Winshield frame to roof
I cut mine from a donor cab.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
09-18-2015, 08:41 AM | #3 |
Hollister Road Co.
if your not replacing the roof then you make that panel or cut it from a donor. be aware that that particular area is different between years so a panel cut from a 47 will not work on a 50. its shaped differently.
09-18-2015, 11:14 AM | #4 |
A section out of a donor cab would be the simple way to fix it. I'd suggest hunting down an otherwise junk cab that I could cut the roof off or possibly Dave or one of the other premium members has a section of a cab that they can cut out and sell you.
It might help if you take and post some photos of the area you need as some of the guys might be able to come up with other options too.
09-18-2015, 11:39 AM | #5 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-18-2015, 11:41 AM | #6 |
I actually have a section of roof I am not using that may have a good one. Of course we have to find out what would be different as mine isn't a '47. But honestly I don't think there is a difference that would matter.
Brian
09-18-2015, 12:02 PM | #7 |
Yuppers, Inquiring minds would like to know what the difference in that area of the cab is. The only differences I know of are the front of the cowl between the 47 and later trucks and the windshield area of the two piece windshield trucks and the 54/55 first series trucks plus the side vent no side vent thing.
09-18-2015, 12:10 PM | #8 | |
But I sure as heck have been surprised before so I am not saying it isn't different, I have just never known of anything. Brian
09-18-2015, 12:44 PM | #9 |
I ll get a couple of pic to post later on. I would be interested in what you have getting is the only question? Thanks
09-18-2015, 03:28 PM | #10 |
I hope I did this right??? Im looking to Replace 2 inches up staring from the edge of the inner front roof brace up into the roof. Down the left post 8 inches and down the right post 4 if possible. I am more worried about the upper than the posts. that is manageable. Thanks in advance.
Brandon
1964 GTO 1931 MODEL A 1950 3600 Last edited by blm64Goat; 09-18-2015 at 03:33 PM. Reason: wanted to be more clear. |
09-18-2015, 03:49 PM | #11 |
You don't need the inside, you need the outside?
Brian
09-18-2015, 04:26 PM | #12 |
Hollister Road Co.
It does matter and its a big difference. The area where the pinch weld is where the rubber meets the roof has a stepped edge in 50 and later. 47, 48 have a sloped edge, Unsure about 49.
09-18-2015, 05:08 PM | #13 |
Hollister Road Co.
here is what it looks like, this picture has a 47 roof and a 50 pillar post we grafted. it took a lot to get it to look right. Notice the gray roof sloped down and the bare metal pillar stepped
09-18-2015, 05:47 PM | #14 |
Good info / tutorial. I didn't know that. Thanks for sharing.
Interested in ideas for the best way to fix that rust. Would be less weld area to just replace the roof at the A and B pillars? Maybe more hours that way...dunno. |
09-18-2015, 05:56 PM | #15 |
Hollister Road Co.
I'd do a roof and the inner brace along with it. The pillars you may get away with just doing the pillar covers. But I suspect that there may be more rot inside the pillar.
Reason for doing a roof is its quicker, looks better when finished, you get no more rust through in that area. With a roof panel costing about $400 shipped, if you keep track of your time it costs about the same for cutting the existing rot out , getting a roof that matches, cut it out and clean up all of it then weld it in and finish the surface. Its way more than $400. The roof comes off in a few hours and goes on a few and next to no body work when your finished and it looks right. |
09-18-2015, 05:57 PM | #16 | |
Just cut the bottoms of the "A" pillars at the sill and then cut the "B" pillars at the tops of the doors all the way around the top of the rear window and take the whole thing off in one piece and replace it with a good donor.
My Build: 57 Chevy Pro-Street |
09-18-2015, 06:12 PM | #17 |
Yes the outside. The inside is the front roof support the 2 are spot welded together
09-18-2015, 09:23 PM | #18 |
Just to clarify this is a 50 3600 not 47
09-19-2015, 12:21 PM | #19 | |
Brian
09-19-2015, 01:06 PM | #20 |
Hollister Road Co.
There are a lot of little subtle changes like that every 2 years. Everyone thinks these trucks are all the same, appearance wise they are but each year has a little something different.
09-21-2015, 01:20 PM | #21 |
Can someone tell then if a 52 or 53 GMC windshield set in the frame same as a 1950 Chevy?
