04-08-2014, 07:55 AM | #1 |
Name that bolt/nut/screw size
I've been having problems finding fastener information while rebuilding my ride. I thought it would nice to have all this information in one thread. Since this is the blazer/jimmy section, lets try and get mainly info for them, but info that's the same for trucks is welcome.
So, what the bolt is for, size-thread pitch, type head. Qty needed may be helpful as well. Double wall top visor bolt, 5/16-18, 2.375 long with 1.375 shoulder, hex, qty 2 bed bolts, 5/16-18, .875 or 1.00 long, w/washer, hex, qty 10 top to bracket, 5/16-18, .625 long, w/lock washer, panhead phillips #3, qty 4 frame to bracket, 5/16-18, 1.00 long, w/small washer, hex, qty 2 rear plate, 5/16-18, 1.00 long, hex, qty 6 Single wall top Bed bolts, 3/8-??, ?? long Visor bolts, 5/16-18, 1.00 long, oval head with custom .50 dia head, #2 phillips (cant find these anywhere) gasket to top of a-post, ??? qty 6 door sill plate screws, #8x1.00 panhead #2, qty 8 Pass Seat to floor, 5/16-??, 1.00 long, qty 6 Drivers seat to floor, 5/16-??, Rear seat to floor front bkt, ??, ??, Qty 2 Rear seat to floor rear bkt, ??, ??, Qty 4??
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
04-08-2014, 11:00 AM | #2 |
Re: Name that bolt/nut/screw size
I have to pull my 1/2 top off to get to the windshield bolts, might take awhile as im elbow deep in my build. Ill try to get to it Saturday
04-08-2014, 01:46 PM | #3 |
since I cant edit the original post
04-08-2014, 01:55 PM | #4 |
ADD:
Rear Interior Spare Tire rack to floor? qty 4,???, ??? |
04-08-2014, 02:12 PM | #5 |
If you know it, add it. Mine has the holes, but no rack or bolts.
04-08-2014, 03:58 PM | #6 |
Subscribing. I need all the rear seat bolts as well.
04-08-2014, 05:47 PM | #7 |
04-08-2014, 06:00 PM | #8 | |
04-08-2014, 06:58 PM | #9 |
Actually got one out w/o messing up threads. 1/4-20, roughly .50 long, pan head??
04-09-2014, 12:38 AM | #10 |
Awesome, thanks! I am sure I will think of more.
04-09-2014, 06:53 AM | #11 |
This was meant for everyone to post what they know. But since I need help, I help others back.
04-09-2014, 08:56 AM | #12 |
Sub'd. Great post.
06-10-2014, 07:53 AM | #13 |
Visor to windshield post screw
5/16-18 jackson panhead phillips screw, around .75 or 1.00 long. Very hard to find, however thanks to user bluek5, he found a place here. At the moment they are out, but I have a feeling if many people start placing an order, some will come into stock. http://www.msc-stainless-fasteners.c...on-screws.html Anyone know what screw is used to hold the hatch handle to the hatch? |
06-13-2014, 08:21 PM | #14 |
Carpe manana
Good idea for a thread! Pics are a huge help and salvage yard trucks are a wealth of OEM screw/bolt info with regard to type, size, and finish.
Here's the correct bolt w captured washer to affix the e-brake bracket at the dash. Pics show one I just had Parkerized and another installed. There are a few other such unique bolts/screws I can think of, will try to post more.
06-13-2014, 09:08 PM | #15 |
This is a great thread idea. Subscribed. I'll contribute where I can.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
06-13-2014, 09:40 PM | #16 |
Carpe manana
More unique screws/bolts: 12 point screw to attach the hood latch to rad support (note the cool anchor on the head! - not all had these), Phillips head screw to attach the door latch, and trim screw/ferrule to attach a 72 door panel all shown in correct finish
06-14-2014, 08:55 AM | #17 |
I wondered how the ebrake release was attached. Mine just flops around. Now I know
06-14-2014, 08:24 PM | #18 |
Carpe manana
Example pics of the screws used to affix the cowl: stainless on top, Parkerized with a captured washer (same as those used to affix the glove box hinge to the dash) under the hood at the cowl to hood seal.
06-14-2014, 10:25 PM | #19 |
deadhead, could you post thread size and lengths on some of these?
Specifically, I'm interested in the one for the ebrake setup. But would like all of them for others restoration projects, even if they cant get the originals. Atleast some off the shelf. |
06-14-2014, 10:48 PM | #20 |
Carpe manana
Would if I had any clue
06-15-2014, 12:00 AM | #21 |
Carpe manana
Correct (non)finish on the 9/16" bolts for the door striker plates, which use star washers
06-21-2014, 05:22 PM | #22 |
Can anyone hook me up with specs for the original hatch handle screws?
06-23-2014, 09:12 AM | #23 |
could also use info on the correct gravel guard nuts/bolts.
06-23-2014, 11:11 PM | #24 | |
Carpe manana
06-24-2014, 07:07 AM | #25 |
Ty
