05-13-2018, 03:27 PM | #51 | |
Re: gm create motor ?
Thanks |
05-13-2018, 05:21 PM | #52 | |
I looked seriously at the LS and the only way you can do it for the same money is with a used LS motor. The L31 is brand new, not a rebuild and it has a warranty. With a used LS there is no warranty if you have a bad one. Plus there is a lot more work involved swapping in the LS. So it is not as cut and dry as it sounds. For me I figured I am going to get 80% as much for 25% of the work. Last edited by Kudzupatch; 05-13-2018 at 07:23 PM. |
05-14-2018, 07:05 PM | #53 |
any idea if this is a drop in cam for this crate motor ?
i can get it for less than retail and not much more than the gm cam . https://www.summitracing.com/parts/cca-07-502-8
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-14-2018, 07:59 PM | #54 |
Also Jegs has the L31 for $1899
https://www.jegs.com/i/GM-Performanc...SABEgKRIfD_BwE |
05-14-2018, 08:32 PM | #55 | |
It is NOT. Too much lift for the stock vortec heads. REALLY if you're looking for "drop in" cam. I'd recommend running the one that comes in your motor. A drop in cam won't improve your motor enough to "cost justify' IMO. If you were willing to change your springs, keepers, and retainers you could run that cam you selected. Google "ghetto grind". These guys sell a complete kit (and it's reasonably priced) https://www.alexsparts.com/valve-spr...seat-pressure/ BTW, mine has arrived! I just tucked it away until I get some parts. Last edited by supercheyenne; 05-14-2018 at 08:39 PM. Reason: Show a picture! |
05-14-2018, 08:55 PM | #56 | |
https://www.ebay.com/itm/GM-OEM-NEW-...4AAOSwysRas9qX
05-14-2018, 08:59 PM | #57 | |
05-17-2018, 01:14 AM | #58 |
If anyone comes up with a way to run an in tank fuel pump please share!
Or if someone could share what fuel pump would fit through the tank bulkhead I'm open to making my own stuff. I'm going with a Carb so I don't need high volume or pressure. Thanks |
05-17-2018, 07:11 AM | #59 |
I have the Boyd welding EFI tank in mine with the Aeromotive pump. I had EFI on this truck for a bit till it quit and went back to a carb. I used Aeromotives return style regulator for running a carb and it sits dead on 6psi all the time. I like the idea of having the return as it helps keep the fuel temp down and that reduces the chance of vapor lock.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-18-2018, 07:38 PM | #60 | |
driving is in my blood
As for the distributor gear, just go to GM and get the oem melonized gear from a late 90's vortec 5.7L. I ran a take out vortec in my old 79 with a 200-4R behind it. Put a normal timing cover on, removed reluctor wheel. RPM intake. Melonzied distributor gear. Adjustable vaccum advance [way too much ignition timing for vortec heads stock, they want about 34* max] and ramhorns 2" manifolds [2.5" wont clear 73-87's]. Super easy.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-22-2018, 02:32 PM | #61 |
update: leaving it as is out of the create .
water pump question . can i just bolt on a 88-95 water pump for factory serp belt that i am going to run or do i have to mod anything ? and any quick easy way to plug off the crank sensor hole in the timming cover ? as i dont plan to swap it over and my engine has a harmonic balancer on it from new out of the create .
07-22-2018, 11:16 PM | #62 |
60-66 Nut
Yes you can bolt up any small block long water pump.
Look here regarding the crank sensor. http://67-72chevytrucks.com/vboard/s...d.php?t=396643
07-23-2018, 12:08 AM | #63 |
60-66 Nut
07-26-2018, 01:48 PM | #64 | |
Also consider putting in a one piece oil pan gasket while it is out. People rave about those so I plan on replacing the factory gaskets with one and doing the timing cover all at one time. |
07-26-2018, 11:16 PM | #65 | |
60-66 Nut
Those crate engines as well as the factory installed Vortec engines have a one piece pan gasket from the factory. In fact I think all 1 piece rear main seal engines have a one piece pan gasket from the factory.
07-27-2018, 07:33 AM | #66 |
09-11-2018, 12:47 PM | #67 | |
Romans 10:9 - The Truth |
09-11-2018, 03:32 PM | #68 |
But Found Her 25yrs Later!
Score!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-12-2018, 10:12 AM | #69 |
Romans 10:9 - The Truth Last edited by RDrancher; 09-12-2018 at 10:24 AM. |
09-17-2018, 11:56 PM | #70 |
What minimum octane fuel can the L31 run?
09-18-2018, 09:08 AM | #71 |
09-19-2018, 08:19 AM | #72 |
I just purchased a GM turn key performance 350, going to install it into a 1971 blazer with a 700R4/NP205.
What is a create motor ? |
09-19-2018, 08:51 AM | #73 |
A ‘create’ motor is similar to your ‘turkey’ performance 350!
Add a letter, drop a letter! |
09-19-2018, 09:16 AM | #74 |
Is there a formula to know which letter to add and which to drop ? LOL!!!! Funny Forum.
Thought maybe this forum had a special create your own engine, changing camshafts and other parts to create your own, Thanks for the add and drop method |
09-19-2018, 10:06 AM | #75 |
There is a formula!
It does involve some ‘metric’ calculations and a couple ‘french’ translations but otherwise easy to do. Where is ‘X’ that it marks the spot and ‘Y’ do you live there? |
