04-09-2010, 12:29 PM | #1 |
L31 crank position sensor hole on new long block
On the bottom of the timing cover is what I believe to be the crank position sensor... Can this hole just be plugged if the engine is being used without a computer?
This is on a brand new L31 long block being used with a carb and TH350 -- |
04-09-2010, 12:42 PM | #2 |
Re: L31 crank position sensor hole on new long block
Yes sir, we purchased a small plug (freezer plug)from the NAPA store... put silicone sealant around it and tapped it into place... works like a champ.
04-09-2010, 01:00 PM | #3 | |
From your description, it sounds like this isn't a threaded pipe fitting, but a smooth thing you just need to press into the hole? I just know the hole exists, I don't have the engine in front of me to look Thanks Last edited by Jim_PA; 04-09-2010 at 01:01 PM. |
04-10-2010, 10:46 AM | #4 |
No No
Yeah just a small freeze plug works fine. I used a small freeze plug when I did the engine in the truck and used some plastic weld epoxy to make sure it stayed. In the birdy when I had the vortec 305 in it I just left the old CPS in. I just for the life of me cant remember what size the plug is.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
04-10-2010, 12:41 PM | #5 |
Thanks-- I think it's 3/4" Should be a sealed power # SEP3819013 from napa
04-12-2010, 09:14 AM | #6 |
just so you know.... if u look on the back of the cover there are part numbers for 2 covers... 1 with the hole, 1 with out the hole...tis my understanding both are available from GM...
04-13-2010, 12:03 AM | #7 |
60-66 Nut
The non-sensor hole composite cover is available online for $50.00. I would opt for either a steel cover or the freeze plug fix for the sensor hole.
