09-11-2016, 03:56 PM | #1776 |
Re: Al's 71C10 Rebuild
In the next few weeks I'm tearing out the RideTech system off my truck and going to Accuair dual compressor elevel bigger tank system.
I will be taking out everything from the air control system including the elevel sensors harness compressor red block valves air tank everything but the bags which I'm re using. Nothing wrong with it just wanting a faster air up system with more capacity. All of this parts will be available for a fraction of the price.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-31-2016, 08:58 AM | #1777 |
Well the time is finally here Sylvester will be set,up,with accuair
Dual compressors,larger,air,tank bigger air line and elevel... Stay tuned
10-31-2016, 09:10 AM | #1778 |
Haven't heard much from ya. Cool about the Accuair. Just driving mine today. At alignment shop right now!!! I have the same Accuair setup you're goin to and it's so easy to figure out and operate I think I'm doing something wrong.
11-06-2016, 10:32 PM | #1779 | |
Is the accu air a better system than ride tech? Keep me in the loop on the sytem your pulling out.......
Thanks. Quote:
72 Cheyenne Super 350 Holley EFI/700R4 67 Camaro SS/RS 68 Corvette 427 Tri-power 4-speed convertible 55 Chevy Belair Hardtop |
11-07-2016, 09:01 PM | #1780 | |
My ridetech was just the simple system with elevel sensors except the bags
11-07-2016, 09:02 PM | #1781 |
Sylvester is done now putting some miles to be sure all is perfect
11-08-2016, 09:21 AM | #1782 |
Still Learning
Looking good Al!
11-08-2016, 10:09 AM | #1783 |
Im getting ready for some renovations to my old truck.......it has a mild drop coil springs, and Im looking at some type of air ride suspension......
I truly dont know who makes a better suspension, so please educate me..... what comes with your system you took off, and what will I need? Im assuming you keept your control arms, airbags? Thanks, Greg
11-08-2016, 06:39 PM | #1784 |
Looks great!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
11-10-2016, 09:36 PM | #1785 |
11-10-2016, 09:37 PM | #1786 |
11-10-2016, 09:39 PM | #1787 | |
Pm sent
11-13-2016, 01:23 PM | #1788 |
Ridetech kit is off the truck.
Let's see if I get something else to put this kit in.
11-13-2016, 01:27 PM | #1789 |
After modifying my rear wheels and having a local shop working the rear tubs I picked up about another 1 1/2 lower in the rear. Also had an accuair management system installed with dual compressors and eleven.
11-13-2016, 01:28 PM | #1790 |
Aired out in the rear
11-13-2016, 01:47 PM | #1791 |
Oh no upside down.
You driven it much or played with the elevel much since it's been in? I'm curious how much difference there is in the brands. |
11-13-2016, 03:50 PM | #1792 | |
Will edit. Systems basically the same Big difference is larger tank two compressors large diameter air lines. Biggest change was the work on the back wheels and rear inner tubs which now is about a inch lower
11-13-2016, 03:53 PM | #1793 |
This is the parking lot slow cruising stance
11-13-2016, 04:25 PM | #1794 |
67-72 parts collector,…
Looks perfect!
Did you machine the back side of the wheels to increase the backspacing?
11-13-2016, 05:36 PM | #1795 | |
Picked up about an 1 1/2clearance
01-06-2017, 12:30 PM | #1796 |
This is a SWEET truck! subscribed to watch the updates!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
01-07-2017, 01:49 PM | #1797 |
Al, your truck looks sweet!
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
01-07-2017, 01:54 PM | #1798 |
Thanks fellows!!!! I appreciate it
I have been enjoying it as much as time allows me to. Being on accuair now and it rides much lower at ride height
01-07-2017, 01:55 PM | #1799 |
9 years since the beginning
02-15-2017, 09:13 PM | #1800 |
I'm driving the truck as much as possible whenever possible....
