12-28-2009, 12:15 PM | #1 |
My Carbon Footprint
How much air PSI can a standard propane bottle safely hold????
I have an older style 5 gal propane bottle that doesn't have the safety valve. I thought it would be a great candidate for a small air bottle to air up tires and what not. Just didn't know how much they can safely hold. I think my compressor goes to 125 or so. THANKS!
12-28-2009, 12:36 PM | #2 | |
Re: How much air PSI can a standard propane bottle safely hold????
It can handle well above what your home compressor can produce.
@ 70 degrees the propane vapor pressure is around 125 PSI and it goes up with the temperature. The vent valve of a normal gas grill type tank is set for 375 PSI so the tank can take at least that.....but your home compressor will never pump that much.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
12-28-2009, 12:49 PM | #3 |
My Carbon Footprint
Sweet! my fastback has a flat tire and my hose won't reach. Problem solved and thanks for the good info!
12-28-2009, 01:28 PM | #4 |
Gone to greener pastures
FWIW: I have read at least 1 account of somebody using a popane tank in air service & having an explosion.
I don't know what the source of ignition was except maybe heat of compression.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
12-28-2009, 06:16 PM | #5 |
Professional Grade
I have heard of so called explosions as well but I think its just air pressure do to a shotty weld when people cut holes and weld on their own fittings, same with old freeon tanks have seen that to. I think if you dont modify the tank any you can use it as a air tank all day long and not worry. The shotty modified ones I have seen on many a farm scare me a bit though.
61 GMC 9' Step Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828 67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531 71 GMC Street performer in the works Waiting for warm weather http://67-72chevytrucks.com/vboard/s...d.php?t=341946 1990 GMC Sierra GT-sold 1983 chevy 4x4-project on hold maybe sell 1969 Triuph GT 6- sold 1996 Ford I-6 5 Speed 4x4 2004 Dodge Intrepid- milage maker 1959 Ford Fairlaine, factory a/c 292Yblock- sold 1982 Honda XL500R Always lookin for other old trucks! |
12-28-2009, 08:33 PM | #6 |
My Carbon Footprint
So much for the propane bottle idea.......I'm the black thing to the left!!!
12-28-2009, 08:38 PM | #7 |
we had 2 freon tanks with a steel bar welded across the handles. just unscrewed the valves and added air valves with a crossover. my dad had them around as long as i can remember. they would hold whatever you could put in them. think each tank was rated around 300psi
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
12-28-2009, 09:04 PM | #8 |
Someone around here did die from using the propane bottle as an air tank. They had a wheel problem and welded on the wheel with the tire on and aired up. The tiny amount of propane left in the tire did explode killing both the man doing the welding and the farmer standing next to him. The man doing the welding had young kids at home. Very sad accident.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-28-2009, 09:26 PM | #9 | |
My Carbon Footprint
Okay....none of that made sense. Why was there propane in the tire? How many beers have we had?? |
12-28-2009, 09:36 PM | #10 |
thats a very highly unlikely set of circumstances for that explosion. in any case the tank should be vented or at least left open.for a while
12-28-2009, 11:43 PM | #11 |
i converted a 20 lb LP tank to an air tank. i removed the tank valve and purged and washed with soap and water two or three times then left it to dry. i used pipe fittings and a psi relief valve rated at 125 psi with a small psi gauge and the open close valve with a quick coupler. this is all flush with the top of the tank protection handles on the tank. the 20 lb tank at 120 psi will fill one 15" tire from flat to 35 lbs. the time and money i spent 8 years ago on it was worth it. today the portable air tanks are cheaper to buy than retro fit a lp tank. these tanks are rated for 375 lbs or what the stamp on the top of the tank says.
Trueman |
12-29-2009, 03:25 PM | #12 | |
I am a Referee of life.
In a lot of farm areas the old farmers use propane burners to get rid of weeds.Since the tank is in the truck they build an adapter to fill those farm tires.So the tire has propane instaed of air.Most tire guys in farm communities are very careful of smoking while working.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
12-29-2009, 09:30 PM | #13 |
It's a catastrophic success.
In the old days( when propane was cheap) farmers would use propane to air up tires,(tractor tires hold a lot of air) you had 100+ psi and lots of volume that a regular air tank cant compare to but it was dangerous if you had a very big leak.
12-29-2009, 10:27 PM | #14 |
I am in the propane business and yes the propane pressure is far greater than what your compressor will produce, that being said I have people pick up old tanks that we can not fill for one reason or another mostly old valve regulations and they will grab them and change the valve and use that for an air tank. I do not feel comfortable myself doing that just because it is not what it was made for but it does work. The real chance for a problem is the propane vapor in a tank and static electricity that can be caused during the purging of the propane vapor from a tank, propane vapor is heavier than air so open the tank urn up side down and leave it for a few days and if you are a chicken like myself get a little nitrogen purge the tank and off you go. Sorry to be so long winded.
