05-28-2016, 10:52 AM | #1 |
1972 C10 clutch fork and clutch linkage issues
Purchased a new clutch fork boot and clutch rod boot.
I know where the fork boot goes but where does the clutch rod boot go? The LMC diagram does not show where it goes. I also noticed that mine is missing the clutch fork return spring. Where does it go? It seems to be working just fine without it. Also in looking at the clutch linkage diagram it appears that someone has taken the pushrod "wing" nut and placed it behing the clutch fork and then just put a regular nut on the end. Is this correct? |
07-15-2016, 02:19 PM | #2 |
Re: 1972 C10 clutch fork and clutch linkage issues
A little late, but I will try to help as I'm working on the same stuff:
The wing nut is correct, mine has one as well, though a photo of yours would help, as there is no nut between the fork and the wing nut. In fact, the fork is grooved to accept the wing nut, a regular nut would be wrong. I'm trying to figure out how to but my spring back, will have a pic in my thread when I do. Here is a link to the thread. It has a good diagram of the linkage that should help you. http://67-72chevytrucks.com/vboard/s...clutch+linkage
1967 C-10 4-speed, 350v8 |
10-16-2023, 12:45 AM | #3 | |
10-16-2023, 10:33 AM | #4 |
the wing part goes on front side of fork and nut on back side. Return spring goes to DS frame rail and clips in hole
Leave the rear nut lose so the fork does not bind on the wedged spacer on the front side of it |
10-16-2023, 11:00 AM | #5 | |
The Older Generation
The rod at the clutch arm on some of them doesn't have threads. (unless it has been replaced) That wedge piece that everyone calls a "nut" isn't really a nut because it doesn't have any threads in it, it just slides onto the end of the rod. The long spring holds it all together. The spring goes from the end of the clutch arm to a hole in the bottom frame rail. LockDoc
10-16-2023, 11:17 AM | #6 |
I think all the nut was for was to keep from losing the wedge if the linkage somehow came apart.
10-16-2023, 11:23 AM | #7 | |
I moved the swivel forward and then I could not get it back in the hole to secure it with the carter pin. Therefore, I have to remove it from the fork and discovered this issue with the placement of the so called push rod wingnut. |
10-16-2023, 11:29 AM | #8 |
Linkage adjusts on the other end of the linkage with the 2 jam nuts. Further adj (if absolutely needed) can be made by putting a few washers under the wedge. Adjustment is made by controlling clutch pedal end play inside the cab.
10-16-2023, 12:17 PM | #9 |
On/at the firewall where the clutch rod passes through to interior.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
10-16-2023, 12:36 PM | #10 |
Thank you. I am assuming you loosen the two jam nuts and move the swivel piece forward thus reducing the amount of threads on the front end. When you say putting a few washers under the wedge are you referring to in between the wing nut and clutch fork itself?
10-16-2023, 09:14 PM | #11 |
Under the wedge up against the step in the rod. Forget about the nut on the end, it has nothing to do with adj... Wedge rides against the fork with the spring holding it together ---nothing in between the 2
10-17-2023, 09:23 AM | #12 | |
Just getting the wedge back in the correct location has made a bit difference. |
10-17-2023, 11:13 AM | #13 | |
10-17-2023, 12:11 PM | #14 |
Here's the pedal pushrod boot on the firewall.
10-17-2023, 03:37 PM | #15 | |
10-17-2023, 04:25 PM | #16 |
A lot of the early trucks had the transmission suspended by the 4 bolts without a cross member underneath it. My 68 GMC was like that. That got changed when I installed an overdrive and converted to an SM465 trans. The original Rear engine mount was the bell housing. Clutch gets adjusted by the clutch pedal end play in the cab. Usually about 1-1/2''to 2'' of end play
10-17-2023, 04:38 PM | #17 |
so just because the tranmission tail has 2 open screw holes doesn't mean the cross member is missing? I'll have to take a picture.
10-17-2023, 05:10 PM | #18 |
Yes a pic would show a lot
10-18-2023, 11:01 AM | #19 |
My 72 3 OTT 250 6 cyl did not have an X member. The Saginaw 3 speed did have trans mount to X member holes.
10-18-2023, 01:58 PM | #20 |
Here are two pictures. There does not appear to be any holes on the frame that would align with a cross member.
10-18-2023, 11:00 PM | #21 |
Senior Moment
Unless your going for original, Go hydraulic and eliminate all the bracketry. I’ve done 2
My LS and my sons 383 with Muncie 4 speed. Works perfect
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-19-2023, 09:08 AM | #22 |
Pictures of your hydraulic setup?
But I am missing the cross member correct? |
10-19-2023, 09:18 AM | #23 |
Location: Herculaneum MO (20 minutes south of St. Louis
Take a picture of the front of the transmission and the bellhousing. If there are mounts on the bellhousing then it doesn't get a cross member at the back of the transmission. It's one or the other, not both.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
10-19-2023, 10:39 AM | #24 |
will take a few pictures.
can you explain the two bolt holes in the transmission tail that could bolt to a cross member? Looks like I have the 4 speed saginaw. |
10-19-2023, 11:22 AM | #25 |
Normal. Same transmission was used in other applications that required the cross member. Nothing to worry about. If you didn't have the bell housing mount the entire engine would be bouncing around creating a ton of other issues
