Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-27-2022, 03:52 PM   #1
72SUBGUY
72 Suburban rear trim panel project.
I took on a weekend project of replacing the rear trim panels from the cargo area this summer.
Attached are pictures of how it was done and how it turned out.
It was pretty straight forward as I had the original panels to template off of.
They're made from 1/4" birch ply available from any home store.
3M super 77 trim adhesive and a 1" roller.
I also covered the inside of the panels and body with Kilmat.
Every little bit of sound deadening helps.
Be sure to under cut the size of the panel by 1/16" to accommodate the thickness of the vinyl you use.
72SUBGUY is offline   Reply With Quote
Old 11-27-2022, 03:53 PM   #2
72SUBGUY
Re: 72 Suburban rear trim panel project.
Here it is all finished.
Old 11-27-2022, 04:03 PM   #3
nightmare
nightmare's Avatar
Looks good. Am planning to do the same to mine, just need to get the vertical mounting brackets refurbished.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 11-27-2022, 08:42 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Wow, That looks super! I keep putting off doing my Panel Truck. I have everything to do it. I bought 1/4" Luan (Mahogany) plywood for mine but it should work about the same.
Keep up the good work!
LockDoc
Leon
Old 12-03-2022, 12:05 PM   #5
kev2809
low n' slo
kev2809's Avatar
that looks good! what did you use to fasten them down?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-03-2022, 08:57 PM   #6
72SUBGUY
Currently their just pushed in place and stay jut fine.
I have the holes drilled in the ply for the original screw locations.
Which I'll be installing over the winter among many other changes.
Old 12-20-2022, 07:21 PM   #7
HO455
HO455's Avatar
How did the 1/4 plywood fit in the upper chrome strip? I tried 1/4" in mine and it wouldn't fit. I have read there are two sizes of pickup door panel chrome strips depending on interior options but I've never been able to confirm the same for Burbans.
P.S. They look great!
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 12-21-2022, 11:11 AM   #8
72SUBGUY
The ply I used fit great. I used 1/4" birch ply (It could have been a maple maybe) which measured @ .181 instead of say M.d.f. which measures at .250 (1/4")
I am also unsure of the different size chrome strips.
