08-19-2017, 02:51 PM | #1 |
But Found Her 25yrs Later!
Upgrades In Proper Order...
I'm starting this thread because I sometimes lose direction and purpose.
I will continue to update this thread with links to threads that address these more important matters. Feel free to post comments, links, and threads that you feel should be top priority, and I'll try to keep things updated. I'll start with a rough draft and dial it in as this thread grows. Reliable Stopping and Tight Steering should be Top Priority. Brakes: (E-Brake, Split Brake Lines, Power, Discs) Steering: (Gear Box, Linkage, Tie-Rods, Ball Joints, Alignment, Caster, etc.) 1. Safety First 2. HOW TO: Split the Brake Lines 3. Make It Handle .
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 08-19-2017 at 03:02 PM. |
08-19-2017, 04:16 PM | #2 |
Re: Upgrades In Proper Order...
Agreed, I would suggest safety would be 1,2 & 3!
Great to make this a stickie also!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-19-2017, 04:37 PM | #3 |
Moderator
Brakes
fuel system lights tires steering suspension cooling wipers everything else |
09-20-2017, 07:12 PM | #4 |
E-Brake: http://67-72chevytrucks.com/vboard/s...ghlight=brakes
Drums vs Discs: http://67-72chevytrucks.com/vboard/s...ghlight=brakes Keeping the drums: http://67-72chevytrucks.com/vboard/s...d.php?t=459752
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 09-20-2017 at 07:19 PM. |
09-20-2017, 10:52 PM | #5 |
Well mine is a little different then everyone else.
Cheeseburger and a coke Slurpee and a slim jim Tune in the radio |
09-21-2017, 10:16 AM | #6 |
50 plus year old trucks have crappy wiring, and trust me, an electrical fire will end your truck in a most horrible way.
Brakes and suspension will park your truck if they go bad, most of the time they go bad to the point you can't drive it until you fix it. In other words it is not a surprise if you are even slightly paying attention, however faulty electrical issues rarely show themselves until the smoke appears. |
09-21-2017, 11:14 AM | #7 |
My truck has several upgrades. A bigger aluminum radiator (it was the cheapest), radial tires (would prefer 7.00x15 bias plys, but it had decent tires on it when I bought it). Better outside mirrors. Baby moon hubcaps. Polyurethane body mounts.
A bigger engine (250 instead of 230). Other than that, still pretty much stock.
Everybody has to believe in something. I believe I'll have another beer. |
09-21-2017, 11:25 AM | #8 |
Right after
Brakes Steering Electrical I would strongly recommend seat belts. Even simple lap belts would be better than nothing. I put lap belts in my 63 and 3 point seat belts in my 65. Here's my contribution. SEAT BELT LINK
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
09-21-2017, 11:34 AM | #9 | |
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-31-2017 at 11:12 PM. |
09-21-2017, 11:38 AM | #10 |
Fortunately, my 64-3/4 came from the factory with 2016 American Autowire wiring.
09-21-2017, 04:14 PM | #11 |
Moderator
I think there was either a pharmaceutical issue then or a medicine issue now in that other situation.
