Old 10-01-2017, 10:35 AM   #326
ironman3452
ironman3452's Avatar
Re: What did you do to your truck today part IV
started to install new uppers and lower ball joints, next will be tie rod and linkage
ironman3452 is offline   Reply With Quote
Old 10-01-2017, 10:51 AM   #327
Backpayne
Painted some parts black and prepping for bags
Just waiting for later model lca u-bolts.
Backpayne is offline   Reply With Quote
Old 10-10-2017, 12:11 AM   #328
TJ's Chevy
TJ's Chevy's Avatar
Been sand blasting....
Old 10-10-2017, 10:34 AM   #329
jbgroby
jbgroby's Avatar
"I" did not do anything, BUT my wife decided to use the bed to hold 3,000+ Easter eggs for this springs Easter egg hunt for our local community.........Rascally rabbit.....
jbgroby is offline   Reply With Quote
Old 10-10-2017, 12:17 PM   #330
Robert Haas
Installed the Wide ride front end from No Limit Engineering,..
All I can say is wow, Rob builds nice stuff.
Robert Haas is offline   Reply With Quote
Old 10-10-2017, 06:19 PM   #331
Yeah howdy, Easter Bunny Crewzin in STYLE!
Old 10-14-2017, 11:39 PM   #332
Alberta65
threw a little brush action down
C10 paint by Craig Warren, on Flickr
Alberta65 is offline   Reply With Quote
Old 10-15-2017, 10:47 AM   #333
67pete300
Finally got the control arms off. Now to try to get them apart.
67pete300 is offline   Reply With Quote
Old 10-18-2017, 11:24 AM   #334
TJ's Chevy
TJ's Chevy's Avatar
Couple days late, but got the inner fenders and core support primed in. Love having a sand blaster.
Old 10-22-2017, 08:31 PM   #335
Ratman74
Ratman74's Avatar
filled random holes in the floor
Ratman74 is offline   Reply With Quote
Old 10-23-2017, 03:00 PM   #336
TJ's Chevy
TJ's Chevy's Avatar
Working on small stuff. Really happy with how the pedals turned out. Matches the lokar pedal nicely.
Old 10-23-2017, 03:11 PM   #337
Malo83
Cruzzzn' Vet
Malo83's Avatar
Bad A$$!
Malo83 is offline   Reply With Quote
Old 10-23-2017, 03:43 PM   #338
AngryPirate
AngryPirate's Avatar
I've been slowly getting the little bits done on the engine compartment.
I hand threaded the stainless wire through the existing staple holes on the inner fender seals. That was brutal.
I got all of the wiring cleaned up and done, got the radiator support in and the radiator.
I got the carburetor hooked up and tried to fire it up, and it cranked and wanted to start, but there was fuel leaking out on the top of the throttle body. So off came the carburetor.
AngryPirate is offline   Reply With Quote
Old 10-23-2017, 09:37 PM   #339
TJ's Chevy
TJ's Chevy's Avatar
Got the pedal mounted and adjusted in today.
Old 10-23-2017, 10:15 PM   #340
The Rocknrod
Moderator
The Rocknrod's Avatar
Sweet,
Old 10-24-2017, 11:12 AM   #341
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by The Rocknrod View Post
Sweet,
Thanks!
Old 10-26-2017, 09:42 AM   #342
La Zona Imagery
I am in the process of sanding down the bed. The wood is good but the previous owner never stained/sealed it so it looks weathered.
What's the easiest way to get all the grey muck off? I tried sanding with 40 grit but it was tedious for the small amount that it got off.
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 10-26-2017, 11:56 AM   #343
ApacheNick
Started building new front upper shock mounts for the 61. Kind of copied the old broken ones but with a few mods for more strength. Will post pics when I get then finished.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 10-26-2017, 11:59 AM   #344
forestb
forestb's Avatar
How nice do you want to get it. I would take the wood out maybe you some kind of paint stripper.
forestb is offline   Reply With Quote
Old 10-26-2017, 07:00 PM   #345
nsb29
nsb29's Avatar
I would try bleaching it if it's only from Weather try a small area first
nsb29 is offline   Reply With Quote
Old 10-28-2017, 09:07 PM   #346
jbgroby
jbgroby's Avatar
3 weeks back or so the truck started running rough at low idle, checking into it we discovered a broken exhaust spring. These were the original springs and we decided to change them all to new ones, with the heads in place. We started on the truck at about 8 am and by using a air pressure manifold, we were able to use air pressure to keep the valves up while removing the springs.
Took about 6 hours, the worse springs to get to were cylinder 6, because it's almost directly under the heater core. Instead of using a spring compressor, we used an open end wrench to press down on the springs so we could remove the keepers. Glad this job is over, took about another hour to set the lifter clearance and tune in the carb.
Old 11-03-2017, 09:15 AM   #347
65chevysub
65chevysub's Avatar
pulled all the window trim pieces and my glove box door out to repaint them all.
I have to stop using my Suburban to move. It's getting very tiring sanding and fixing the scratches for repaint. This is the last time and trying to get the interior done before next Saturday for the Walkin' on Main Car Show put on by the Mingus Union High School Auto Club.
65chevysub is offline   Reply With Quote
Old 11-03-2017, 09:59 AM   #348
vin63
It's Better With Nitro
vin63's Avatar
Had some pin striping done on the rear of the cab and leading edge of the hood...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-03-2017, 10:22 AM   #349
jchav62
1962 C-10
jchav62's Avatar
Very cool!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-03-2017, 01:45 PM   #350
65chevysub
65chevysub's Avatar
NICE!! Looks great
