Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-12-2018, 02:57 PM   #1
72ironmike
72ironmike's Avatar
Two Wheel Blazer Build
My brother Jim & I are joining the Blazer Project/Builders - We bought this two wheel drive blazer/parts over the weekend and plan to add rust free firewall/windshield frame, new blazer bedsides & new full front floor to create a new rust free body like "lks dcvn" did (New Woodall Industries full blazer rear floor not pictured but came with purchase). Nice to have the board resources. Between the two of us we hope to afford the build !
72ironmike is online now   Reply With Quote
Old 02-12-2018, 03:00 PM   #2
72ironmike
72ironmike's Avatar
Re: Two Wheel Blazer Build
Pics
Old 02-12-2018, 03:03 PM   #3
72ironmike
72ironmike's Avatar
more - going with a new LT or LS drivetrain
Old 02-12-2018, 03:44 PM   #4
twp1
Congrats on the 2 wheel drive find and will be watching the build!!!!
twp1 is offline   Reply With Quote
Old 02-14-2018, 10:00 PM   #5
lks dcvn
lks dcvn's Avatar
Yeah! Subscribed to this one. Congrats to you Mike!
Please reach out if you have questions along the way.
You keeping it as the 524 Red (Hugger) Orange?
lks dcvn is offline   Reply With Quote
Old 02-14-2018, 10:17 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Congrats on finding the real deal, Mike!
Keith
Convert to disc brakes.
Old 02-15-2018, 08:27 AM   #7
72ironmike
72ironmike's Avatar
Tom, Thanks. Thinking about Copper/Med Bronze exterior and Medium Saddle interior. But will probably go back & forth till ready for paint !
Old 02-15-2018, 08:31 AM   #8
72ironmike
72ironmike's Avatar
Thanks Keith. As soon as we get her inspected and titled the work begins. Other than drive train and a little drop she will be stock.
Old 02-15-2018, 08:32 AM   #9
72ironmike
72ironmike's Avatar
Thanks. Here we go !
Old 02-15-2018, 10:12 AM   #10
lolife99
lolife99's Avatar
Hey Mike,... I wondered if you needed these repair panels.
http://67-72chevytrucks.com/vboard/s...d.php?t=756030
Also Classic Heartbeat makes some hard to find repair panels for the B pillar area of these blazers.
Well worth the money.
Keith
Old 02-15-2018, 12:47 PM   #11
CTENTA1
Registered 1971 K5
Looks like a solid start.
CTENTA1 is offline   Reply With Quote
Old 02-15-2018, 06:57 PM   #12
72ironmike
72ironmike's Avatar
Yeah, We basically got a frame, body parts, title & vin tag. I think anymore that is a solid start if you want an original two wheel drive blazer !
Old 02-15-2018, 07:05 PM   #13
72ironmike
72ironmike's Avatar
Keith, Thanks. I just missed them. We are going to need everything not pictured in the parts to complete a new tub except firewall, windshield frame & one piece bed floor. Rocker box end caps, the parts you mention, two blazer bedsides & a blazer front floor if they make one ? Anything else ?
Old 02-16-2018, 08:29 PM   #14
lks dcvn
lks dcvn's Avatar
No Blazer floor yet - you will need to modify the truck floor at the rear where it meets the bed floor step up panel.
It will involve cutting off the rear of the panel (where the gas tank would be) and then bending up the rear floor to meet the rear floor. If you have the stock floor you can see how it should look when you get done.
Watch the progression as the 'cab' floor meets the step up and the bed floor in the pix below. The last picture is how it should look when you get done.
Old 02-17-2018, 10:13 AM   #15
72ironmike
72ironmike's Avatar
We have the one piece rear floor, the firewall/windshield frame, rockers, rocker boxes. We know we need rocker box end caps (are there two end caps ?). After we buy the complete truck floor, do we need any more undercarriage pieces ? Do the cab supports get removed from the truck floor ? Lookin forward to the day we get that far ! Thanks.
Old 02-17-2018, 10:32 AM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good luck with the build Mike. Pete
Old 02-17-2018, 10:34 AM   #17
lolife99
lolife99's Avatar
Look here for anything made for blazers,...
http://www.classicheartbeat.com/69-72_blazer.htm
These pieces are worth the money.
http://www.classicheartbeat.com/cata...nt%20panel.htm
Keith
Old 02-17-2018, 12:01 PM   #18
lks dcvn
lks dcvn's Avatar
There is 1 set of torsion box end caps (one per side) and then 3 other pieces of metal come together in the B-pillar.
The torsion box end caps tie into the pieces that Keith notes above. I did this work on a previous project back in 2010 when many of the aftermarket sheet metal parts below were not available.
The B-pillar stuff is easy to see starting in this post and then a bit more detail when I got the other side here.
Parts List for a new blazer
solid windshield frame
69-72 Firewall (if needed)
Cowl Panel (if needed)
outer rockers (2)
cab floor (1) - will need tweaked for blazer use or 2wd version
blazer bed floor (1)
Step Up panel between floor and bed floor (1)
Rear Wheel Housings (2)
Bedsides (2)
tailgate (1)
doors (2)
Torsion Boxes (2)
torsion box end caps (2)
B-pillar support parts (2)
B-pillar reinforcement parts (2)
Blazer Body Mount and Bolt kit (1)
Nuts/Bolts - Grade 8 - Fastenal or Tractor Supply
Most of the links above are from one spot (Classic Heartbeat) - I have purchased from several vendors (GMS Pauls, Tabco, and several different resources AMD, Goodmark, Apex, etc.) so shop around for price, shipping and customer service that fits your needs. Since much of this stuff is oversize - you may want to consider a shop closer to home to save a bit. Several of the board vendors use the sheet metal they supply so they know about updates to molds, which parts will fit and which ones to avoid. Disclaimer - many, if not all, aftermarket sheet metal parts will need to be tweaked to fit perfect. Nothing I used fit perfectly the first time.
Let me know what questions you have along the way Mike. Happy to help in any way that I can.
Old 02-20-2018, 10:27 PM   #19
ls1nova71
ls1nova71's Avatar
Well Mike, you didn't tell me you started a build thread..... Could have saved yourself a lot of work and just bought mine! But then, it's just a fake....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-21-2018, 05:43 AM   #20
lolife99
lolife99's Avatar
Beautiful blazer!^^^
Keith
Old 02-21-2018, 09:30 AM   #21
72ironmike
72ironmike's Avatar
Rick, You know I have to do it the hard way !
Keith is right, Beautiful Blazer !
Are you doing another blazer next ?
Old 02-22-2018, 06:00 PM   #22
lks dcvn
lks dcvn's Avatar
Mike - have a look here CA Blazer tub $1800 - http://67-72chevytrucks.com/vboard/s...d.php?t=757696
Old 02-23-2018, 04:29 PM   #23
ls1nova71
ls1nova71's Avatar
Oh..... Yeah...... Absolutely....... Because they're super easy to do.... Yeah, yeah that's it, they're super easy and the parts are so easy to find, and inexpensive..... yeah because... because I invented the Blazer, yeah.... and I have about a hundred of them... yeah that's the ticket.....
Old 02-24-2018, 11:27 AM   #24
72ironmike
72ironmike's Avatar
OMG - Tom Vogel steered me to a website called "roadster shop" ! Makes you think real hard about spending twice as much on suspension to get all new. Whoa - really nice stuff.
Old 03-04-2018, 08:09 AM   #25
smbrouss70
smbrouss70's Avatar
I'm in for this one!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
