03-27-2020, 08:33 PM | #1 |
remove all of front suspension as unit
Just wanted to ask if the front suspension can be removed as a unit. From looking at the way it is assembled it looks like it can be removed as a unit. However I also want to make sure I don't take a coil spring to the face. Thanks
03-27-2020, 08:56 PM | #2 | |
The Older Generation
Re: remove all of front suspension as unit
Yes it can. Remove the bolts holding it to the frame including the idler arm, pitman arm, and engine frame brackets. Disconnect front brake line from the combination valve where it connects to the front junction block. Depending on the year, your combination valve could be mounted on the cross member. You will have to determine that. If the truck has an engine in it the engine will have to be blocked up after the other jack stands have been put in place under the frame. Just be sure and leave enough room to slide the cross member out. I may have forgotten something so I hope someone else will chime in if I did. LockDoc
03-27-2020, 11:50 PM | #3 |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-28-2020, 10:49 AM | #4 |
Thanks for the info Lockdoc and HO455. I have the truck stripped down to a rolling chassis so access is not an issue. Since I can't go anywhere I will work at getting it apart. Thanks again
03-28-2020, 10:51 AM | #5 | |
No problem, keep us up to date on how you are doing on it or if you have any problems with it. LockDoc
03-28-2020, 11:05 AM | #6 |
Yeah thats what I did on my 69 then I took a 74 front cradle and put in its place .Easy way to add disc brakes if your doing a resto mod on your truck.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
