Old 03-09-2011, 08:25 PM   #1
OlBlue85
OlBlue85's Avatar
Rim help
I have a 2000 GMC sierra 1500 1/2t 4x4 i know the bolt pattern and the rims on my truck are 16" i wanna know if i can put a set of 6 bolt 15" rims off a 84 chev there is a tire/rim combo for sale in my area anybody knows if this will work or not
OlBlue85 is offline   Reply With Quote
Old 03-09-2011, 08:33 PM   #2
onebadbowtie
onebadbowtie's Avatar
Re: Rim help
the easiest way to tell would be to go look at your wheels and see how much clearance you have between your brakes and wheels. if the distance between is more than 1/2 an inch then they should work just fine. but my guess is no they wont fit...on my 01 there is less than a 1/2 inch of clearance between the 2. hope this helps
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 03-09-2011, 09:59 PM   #3
463
463's Avatar
Re: Rim help
here is a site for you http://www.roadkillcustoms.com/hot-r...e-Database.asp
Trueman
463 is offline   Reply With Quote
Old 03-09-2011, 10:55 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Rim help
15" rims won't fit, brakes are too big. The bolt pattern is the same though 6 on 5.5"
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-09-2011, 11:54 PM   #5
loudnlifted88
loudnlifted88's Avatar
Re: Rim help
this is 67_C-30's truck
http://67-72chevytrucks.com/vboard/s...=255001&page=3 #51
IM ONLY 18 AND LOVIN IT
IF MUD AINT FLYIN YOU AINT TRYIN!
1badgmc- Just think. Someone worked hard to make it look that bad.
1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945
1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873
1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build
1998 GMC K-1500 ECSB 305 auto partd truck
1999 GMC K2500 suburban 350 4x4 Dads project
1981 Corvette 350 auto Also Dads project
1989 Corvette 350 auto ^^
1998 GMC K1500 ecsb 305 auto Brothers project
loudnlifted88 is offline   Reply With Quote
Old 03-10-2011, 08:13 AM   #6
usmcchevy
usmcchevy's Avatar
Re: Rim help
I stand corrected!
I tried a set of aluminum 15's and they went on, but the caliper was tight to the rim so the wheel wouldn't turn.
Build thread
LSx Swap FAQ index
