10-13-2009, 02:33 PM | #1 |
Need to help my brother find a part
My brother is restoring his 1978 Suburban and is looking for some sort of part that he says is designed to hold the rear of the hood down flush with the cowl. Here's what he writes, "Meanwhile I am in need of the hood hold down brackets . This is a two part piece that pulls the rear of the hood down when you lower the hood from the front. The part that mounts to the firewall has a cone shaped apparatus on the end that engages a simple u-shaped bracket mounted to the underside of the hood. The cone shaped end slides into the bracket and pulls the rear of the hood down flat with the body as the hood is lowered. I need both pieces."
I searched LMC's catalog and just don't see anything close to that. I know this is in the wrong forum so I apologize for that, but for some reason I'm blocked from any other forum but the 67-72 group. Can someone help me first identify this part and then possibly direct me to a source for one? Last edited by Baby John; 10-13-2009 at 02:34 PM. |
10-14-2009, 05:18 AM | #2 |
Re: Need to help my brother find a part
Having never seen one on the later trucks, I have to believe that it is an aftermarket assembly.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-14-2009, 05:29 AM | #3 |
I'm not sure what heis talking about, but I moved your thread to the board aea you will have a better chance at find your answer.
10-14-2009, 06:16 AM | #4 |
its all about the +6 inches
i have a 78 suburban, and there is nothing like what he describes.
If the trear of the hood sticks up, then it needs the hood/hinges adjusted, or new springs on the hinges. |
10-14-2009, 06:18 AM | #5 |
i have never seen such an animal... i've had MANY on and off in the 80s when i worked in dealer body shop .. when the back of your hood does not lay down with the cowl i believe your stock hinges have issues. binding up or loose and sloppy. lube the h3ll out of them. those hoods had a tendency to buckle just in front of the hinges due to tight hinges.
10-14-2009, 08:02 AM | #6 |
Happy to be here
I believe what he is looking for is a piece that was early 80's. It may have been 80 only to work with the 73-80 style hood.
It was designed by GM to prevent the hood from lifting up on impact. It mounts in the center of the firewall and the bottom rear of the hood.
10-14-2009, 12:58 PM | #7 | |
yeller
Have a pic there Ken?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
10-14-2009, 01:24 PM | #8 |
Thanks, it sounds like you recognize the part. Now to locate one for him. First to identify the name of the part. If you do have a picture I might could send it to my brother and confirm if this is the part he's looking for.
10-14-2009, 01:33 PM | #9 |
yeller
Actually, I never heard of or seen one of these...but would like to.
I am hoping Ken might, since he knows a little about them.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 10-14-2009 at 01:33 PM. |
10-16-2009, 08:49 PM | #10 |
Truck Nut
I know what you are talking about. I believe I have one. I will check for you if you haven't already found one. I will take some pics. Its still on a truck I have I am parting out.
Tony Kee Texas Square Bodies Last edited by texassquarebodies; 10-16-2009 at 08:50 PM. Reason: edit |
10-16-2009, 09:06 PM | #11 |
My 79 Blazer has one and so does the 80 1ton that my dad just bought. Up until I got my Blazer I had never seen or heard of one either. If it wasn't dark out right now i'd take a picture of them.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
10-16-2009, 09:47 PM | #12 |
I was able to take the pictures anyway.
Gotta love the canon rebel. The part in the hood The part on the firewall My dad told my that these were to keep the hood from going through the windshield in a head on collision.
10-17-2009, 05:23 PM | #13 |
never seen one... never too old ....
10-17-2009, 11:12 PM | #14 |
Happy to be here
Thats it.
texassquarebodies-Tony you have/had one on that Blazer we pulled the core support from. Was that an 80 Blazer?
10-21-2009, 01:14 PM | #15 |
my 78 K5 2WD has this on the fire wall but the hood is from onther year and doesn't have that half.
10-22-2009, 04:34 PM | #16 |
Thanks very much. I am going to send these pics to my brother and see if this is in fact what he's talking about. If so, how much do you want for it?
