Old 04-04-2015, 02:11 PM   #1
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
73-87chevytrucks.com's Triple Pillar Pods are now available.
73-87chevytrucks.com Triple Pillar pods are now available. We will be shipping these starting next week. I am currently packaging them and have 1000 on hand. This will be a regular production Item, so we will keep these in stock. Right now I have to figure out the demand on these.
You can purchase yours here at this link for $105.95 + $10 shipping to Continental Lower 48 States. Please email us at webmaster@73-87chevytrucks.com for shipping outside of the lower 48 States:
http://store.73-87chevytrucks.com/me...y_Code=7387INT
This is what comes in the box. Instructions (basically this information on our recommended install procedure), the pod, (3) #6 Stainless trim screws and washers. Note that it is expected that the pods will be painted to match as they ONLY come in one color, gray.
On the back of the pod there are 2 injection "bumps" that will have to be filed off. Note below the top has them, and the bottom does not. These will need to be removed prior to fitting to the pillar. I suggest using a round file to remove it.
Once you have these removed it is recommended that you position it in the vehicle to your liking as far as height. There is a limited amount of height available and you do not want to cover the screw hole as shown below. Mounting this too high will cause it to not seat well on the pillar.
Once you determine where you want them to go you will need to drill pilot holes through the pod and the pillar. The opposite side of the Injection "bumps" is where it is recommended to put these holes. It is recommended that you clamp the pod down over the pillar so when you drill through both it will not move. You can see the points to drill below:
Once the pod is where you want it drill the 2 holes.
For the best optimum fit it is recommended to drill a hole at the top side. This is especially true if you mount it high. You can see the screw at the top back edge here:
Painting/texturing
This is left to the purchasers discretion, but this is how we did this. What was needed was a can of Duplicolor bedliner and a can of either SEM or Duplicolor Vinyl and Fabric.
Painting the pillar is just a matter of following the instructions on the can. Make sure you clean the pillar off. If it has been previously dyed used Lacquer thinner, otherwise you can skip straight to dishwashing soap and water. Adding ammonia will help strip off any oil. Once washed, rinse it off and let it completely dry.
For the pillar pod, you want to completely scuff the whole exterior surface. There is the possibility of mold marks, just sand them off. We used a red scotch brite pad. When you are with the surface wash it off and dry it. Now is the time to add the texture. For best results I recommend holding the can of bedliner at least 16" away and spraying and start and stop well after the part. Typically 2 or 3 light coats should give you a good texture. This is up to the purchasers discretion
We sprayed the pod both laying down and hanging up to get an even coat. Once satisfied it was time for the Vinyl spray of your choosing.
Here is the original pillar with the triple pod mounted to it installed in the truck. Along with a close up for the texture.
Note: The pillar pod holes were sized to allow for the smallest 2-1/16" generic gauge we could find. Some might require a bracket so you may want to confirm prior to purchasing. For the Autometer gauges they will require some light sanding to open up the hole. They are very tight fit and ramming one in without sanding will end in it being VERY difficult to remove.
For routing the gauge or wiring this will require holes to be drilled per the sender required. Keep in mind how tight a bend you can turn and how you need to get it out. We designed these with enough airspace at the back to allow turns for the typical Autometer gauges.
Here are some more pictures of the pods themselves
Here is the pod with a boost gauge installed for reference:
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-04-2015, 07:00 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: 73-87chevytrucks.com's Triple Pillar Pods are now available.
Nice work Chris!
bigblock73 is offline   Reply With Quote
Old 04-04-2015, 08:10 PM   #3
S10Fan
Old Heap Driver
Very nice!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 04-04-2015, 08:20 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Originally Posted by bigblock73 View Post
Nice work Chris!
Yeah no doubt!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-05-2015, 12:59 AM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work. When I get back on my 76 I may be getting one.
Ryan
1969 Chevy milk truck
Old 04-06-2015, 12:17 AM   #6
bbbc10
Diggin The SquareLife
2" gauges fit?
bbbc10 is offline   Reply With Quote
Old 04-06-2015, 08:16 AM   #7
jdf915
jdf915's Avatar
I might have to put some money aside for one of these.
1980 chevy c30 6.2L diesel swap
1995 chevy c3500 6.5L diesel
1997 land rover disco I 6.2L diesel swap, MPG rumored at 26-28
jdf915 is offline   Reply With Quote
Old 04-07-2015, 09:02 PM   #8
Captkaos
Captkaos's Avatar
bbbc10 sorry, didn't get a notification on this for some reason. This is for 2 1/16" gauges, I made the opening fairly tight. You have to force an autometer in the opening. It was the biggest size.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-07-2015, 09:03 PM   #9
Captkaos
Captkaos's Avatar
Thanks for the kind words. Got a lot of time and money in this.. Hope everyone likes it.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-09-2015, 01:10 AM   #10
mike in mo
Can this be mounted in a truck without the factory plastic trim?
mike in mo is offline   Reply With Quote
Old 04-09-2015, 02:26 PM   #11
Captkaos
Captkaos's Avatar
Mike, they mount to the existing pillar in the trucks. I am working on a potential solution for trucks without the a-pillars but currently these require a factory one.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-30-2015, 09:07 AM   #12
arrover
arrover's Avatar
Thanks again Chris for building these. I did a mini review on them:
1982 GMC Crew Cab 4x4 - "River Truck" build thread
1973-1987(91) Chevy/GMC How-To Videos
arrover is offline   Reply With Quote
Old 06-18-2015, 01:10 PM   #13
Captkaos
Captkaos's Avatar
arrover, thanks for the review!
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-18-2015, 02:04 PM   #14
bigblock73
yeller
bigblock73's Avatar
Nice work Arrover!
Old 06-18-2015, 02:18 PM   #15
arrover
arrover's Avatar
Thanks guys! Chris did a good job on these and I just wanted to give people a different look at them.
Old 01-07-2021, 02:40 PM   #16
csa daddy
csa daddy's Avatar
Chris is their any chance yall will do a complete a pilar pod replacement instasofjust the pod add on piece
csa daddy is offline   Reply With Quote
Old 01-07-2021, 04:28 PM   #17
Captkaos
Captkaos's Avatar
We are currently looking at that right now. No updates of any kind as this is a complex injection mold.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-08-2021, 08:27 AM   #18
csa daddy
csa daddy's Avatar
That would be awesome my OCD says I can't use the one you have now . It would drive me nuts looks good though can't wait to see the whole one
Old 01-08-2021, 08:52 AM   #19
Captkaos
Captkaos's Avatar
Not sure why if the seam bothers you it can be blended in.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-08-2021, 09:36 PM   #20
blazer2007
Looks likes a blind spot for me but very nice work. Maybe a smaller LED gauge and lower or inline with the pillar. Be good for off road or racing. Sorry but just my 1 cent ,not 2 ,just 1
blazer2007 is offline   Reply With Quote
Old 01-09-2021, 12:48 AM   #21
Captkaos
Captkaos's Avatar
I haven't experienced "blind" spots more than when they weren't there, but it isn't for everyone, however I am not really sure why you are commenting.
Compare this to say a GMT800, which has a 5" wide factory pillar, Or compare it to any modern vehicle like my 2006 LJ or wifes 2015 JKU.
This is in my daily driver and has been for 5+ years (w/ right at 50K miles) and currently we have sold 700+ of them. They were designed by me to allow full direct view to the gauges from anyone from 5'-4" to 6'-4". The pillar on these trucks are way to thin to allow mounting directly in front of the pillar unless they are almost 6" out/forward and even wider which intrudes with the door seal/door and forward view.
below is me driving it with passenger holding the camera by my face simulating looking toward them followed by another picture with me stopped in PowerTour traffic with the phone directly in front of my face where they are not seen
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-09-2021, 08:53 AM   #22
Dieselwrencher
How would this be more of a blind spot than any newer truck with a wider A pillar and huge tow mirrors just behind it?
I put one of these on a customer's truck a while ago and he never complained about anything to do with the pod. He was just glad there was something available for these trucks.
Ryan
Old 01-09-2021, 03:32 PM   #23
Captkaos
Captkaos's Avatar
I like reading this kind of feedback, Thanks Dieselwrencher!
Chris Lucas
1973 Chevy C-10
Captkaos Customs
73-87, 73-87chevytrucks, roundedline, squarebody, triple pillar pod
